mgoulart
Problemas para Gravação DVD+R DL
mgoulart    0
Comprei 3 mídias Multilaser DVD+R DL, para tentar gravar God of War 2.
Meu gravador é um LG 4160B A303.
Eu tentei gravar primeiro no Imgburn e deu isso abaixo:
I 21:09:57 ImgBurn Version 2.3.2.0 started!
I 21:09:57 Microsoft Windows XP Professional (5.1, Build 2600)
I 21:09:57 Total Physical Memory: 523.744 KB - Available: 240.412 KB
I 21:09:57 Initialising SPTI...
I 21:09:57 Searching for SCSI / ATAPI devices...
I 21:09:58 Found 1 DVD-ROM and 1 DVD±RW/RAM!
I 21:10:05 Operation Started!
I 21:10:05 Source File: C:\Arquivos de programas\eMule Plus\Incoming\PS2-God_of_War_2_USA_DVD-\e-godwr2\e-godwr2.iso
I 21:10:05 Source File Sectors: 4.166.832 (MODE1/2048)
I 21:10:05 Source File Size: 8.533.671.936 bytes
I 21:10:05 Source File Volume Identifier: GODOFWAR2
I 21:10:05 Source File Application Identifier: PLAYSTATION
I 21:10:05 Source File Implementation Identifier: DVD-ROM GENERATOR
I 21:10:05 Source File File System(s): ISO9660; UDF (1.02)
I 21:10:05 Destination Device: [1:0:0] HL-DT-ST DVDRAM GSA-4160B A303 (D:) (ATA)
I 21:10:05 Destination Media Type: DVD+R DL (Disc ID: RICOHJPN-D01-67) (Speeds: 4x)
I 21:10:05 Destination Media Sectors: 4.166.848
I 21:10:05 Write Mode: DVD
I 21:10:05 Write Type: DAO
I 21:10:05 Write Speed: MAX
I 21:10:05 Link Size: Auto
I 21:10:05 Test Mode: No
I 21:10:05 BURN-Proof: Enabled
I 21:10:05 Optimal L0 Data Zone Capacity: 2.083.424
I 21:10:05 Optimal L0 Data Zone Method: ECC Block Boundary
I 21:11:12 Filling Buffer... (20 MB)
I 21:11:12 Abort Request Acknowledged
E 21:11:12 Failed to Write Image!
E 21:11:12 Operation Aborted! - Duration: 00:01:07
I 21:11:12 Average Write Rate: N/A - Maximum Write Rate: N/A
I 21:12:10 Operation Started!
I 21:12:10 Source File: C:\Arquivos de programas\eMule Plus\Incoming\PS2-God_of_War_2_USA_DVD-\e-godwr2\e-godwr2.iso
I 21:12:10 Source File Sectors: 4.166.832 (MODE1/2048)
I 21:12:10 Source File Size: 8.533.671.936 bytes
I 21:12:10 Source File Volume Identifier: GODOFWAR2
I 21:12:10 Source File Application Identifier: PLAYSTATION
I 21:12:10 Source File Implementation Identifier: DVD-ROM GENERATOR
I 21:12:10 Source File File System(s): ISO9660; UDF (1.02)
I 21:12:10 Destination Device: [1:0:0] HL-DT-ST DVDRAM GSA-4160B A303 (D:) (ATA)
I 21:12:10 Destination Media Type: DVD+R DL (Disc ID: RICOHJPN-D01-67) (Speeds: 4x)
I 21:12:10 Destination Media Sectors: 4.166.848
I 21:12:10 Write Mode: DVD
I 21:12:10 Write Type: DAO
I 21:12:10 Write Speed: MAX
I 21:12:10 Link Size: Auto
I 21:12:10 Test Mode: No
I 21:12:10 BURN-Proof: Enabled
I 21:12:10 Optimal L0 Data Zone Capacity: 2.083.424
I 21:12:10 Optimal L0 Data Zone Method: ECC Block Boundary
I 21:12:13 Filling Buffer... (20 MB)
I 21:12:13 Writing LeadIn...
W 21:12:40 Failed to Write Sectors 544 - 575 - Write Error
W 21:12:40 Retrying (1 of 20)...
W 21:12:40 Retry Failed - Write Error
W 21:12:40 Retrying (2 of 20)...
W 21:12:40 Retry Failed - Invalid Address For Write
W 21:12:40 Retrying (3 of 20)...
W 21:12:40 Retrying (4 of 20)...
W 21:12:40 Retrying (5 of 20)...
W 21:12:40 Retrying (6 of 20)...
W 21:12:40 Retrying (7 of 20)...
W 21:12:40 Retrying (8 of 20)...
W 21:12:40 Retrying (9 of 20)...
W 21:12:40 Retrying (10 of 20)...
W 21:12:40 Retrying (11 of 20)...
W 21:12:40 Retrying (12 of 20)...
W 21:12:40 Retrying (13 of 20)...
W 21:12:40 Retrying (14 of 20)...
W 21:12:40 Retrying (15 of 20)...
W 21:12:40 Retrying (16 of 20)...
W 21:12:40 Retrying (17 of 20)...
W 21:12:40 Retrying (18 of 20)...
W 21:12:40 Retrying (19 of 20)...
W 21:12:40 Retrying (20 of 20)...
E 21:12:45 Failed to Write Sectors 544 - 575 - Write Error
I 21:12:45 Synchronising Cache...
I 21:12:46 Closing Track...
I 21:19:01 Finalising Disc...
W 21:19:42 Potential 'WaitImmediateIO' Deferred Error - (0/2) - Write Error
E 21:19:50 Finalise Disc Failed! - Reason: Write Error
I 21:19:50 Finalising Disc (Last Attempt!)...
E 21:21:09 Finalise Disc Failed! - Reason: Write Error
E 21:21:09 Failed to Write Image!
E 21:21:09 Operation Failed! - Duration: 00:08:58
I 21:21:09 Average Write Rate: 0 KB/s (0.0x) - Maximum Write Rate: 0 KB/s (0.0x)
Depois tentei no Alcohol 120% e deu um problema semelhante.
Tambem tentei no Nero e a mesma coisa.
To surtando por não conseguir solucionar o problema me ajudem por favor!!!
Elmo    4
mgoulart,
Até então, eu não tentei gravar mídias DL... verifiquei no log que você postou que você está utilizando a velocidade MAX... isso é uma péssima ideia, até para mídias não DL... experimenta uma velocidade bem menor... tipo, 4x (se a mídia aceitar)...
fapari    0
você observou se esse DVD tem algum sistema anti-cópia, como os DVD's de filme? Pelos erros que aparecem acredito que deva ter.
Agora que eu ví.. você está tentando gravar de uma imagem no HD. Tenta gravar em outro micro, pode ser um problema no .iso
mgoulart    0
  • Autor do tópico
  • Bem eu tentei a pouco no Alcohol 120% com 4x e deu Write Error.
    Eu não queria comprar mais midias pois elas são muito caras, por isso to insistindo nas mesmas.
    Quanto ao que eu to copiando é uma imagem de DVD baixada pela internet mesmo.
    rickg    4
    Aconselharia voce a primeiro abrir a imagem usando o deamon tools, ele criará uma unidade virtual com o jogo. tenet instalar desta unidade virtual e veja se não dá erro e o jogo funciona.
    Aí com o próprio nero, alcohol, clone dvd voce pdoe clonar esta unidade virtual para um dvd.
    Elmo    4
    mgoulart,
    Primeiro, você tem que ter certeza de que o arquivo baixado está íntegro... siga a dica do rickq... se funcionar normal, então seu download está OK...
    Verifique no site que você utilizou se tem alguma dica de programa de gravação necessário... pode ser que essa ISO esteja com a proteção do original e então você deverá utilizar algum programa adequado para poder gravar... geralmente é com Clone ou Alchool, mas não necessáriamente...
    Alguém resolveu essa? Estou com o mesmo problema (Multilaser+LG 4160B) .
    Será imcompatibilidade?
    Aqui tem mais explicações.
