Ryzen Overclock
Atretador
Fiz uma pesquisa e cheguei a esses resultados:
Listas de memórias B-DIE:
https://community.amd.com/thread/217871
https://www.overclock.net/forum/18051-memory/1627555-ryzen-memory-ic-collection-thread.html
https://www.reddi t.com/r/Amd/comments/62vp2g/clearing_up_any_samsung_bdie_confusion_eg_on/
(pus um espaço no link do edite porque ele está abrindo a lista toda dentro do tópico)
Listas de memórias testadas AMD:
https://www.amd.com/system/files/2017-06/am4-motherboard-memory-support-list-en_0.pdf
QVL da minha MOBO:
http://download.gigabyte.asia/FileList/Memory/mb_memory_ga-ab350m-d3h.pdf
Depois de ler e verificar essas informações, fui procurar alguns modelos que seriam compativeis com essas listas:
TODAS ESSAS SAO B-DIE
1- G.Skill FlareX (F4-3200C14D-16GFX) 3200Mhz CL14 14-14-14-34 (207,90$)
https://www.alternate.co.uk/G-Skill/DIMM-16-GB-DDR4-3200-Kit-RAM/html/product/1340678?
2- G.Skill Ripjaws (F4-3200C14D-16GVK) 3200Mhz CL14 14-14-14-34 (207,90$)
https://www.alternate.co.uk/G-Skill/16GB-DDR4-3200-16GB-DDR4-3200MHz-memory-module-RAM/html/product/1260868?
3- G.Skill TridentZ (F4-3200C14D-16GTZ) 3200Mhz CL14 14-14-14-34 (217,90$)
https://www.alternate.co.uk/G-Skill/16GB-DDR4-3200-16GB-DDR4-3200MHz-memory-module-RAM/html/product/1261018?
4- G.Skill TridentZ (F4-3200C15D-16GTZ) 3200Mhz CL15 15-15-15-35 (197,90$)
https://www.alternate.co.uk/G-Skill/16GB-DDR4-3200-16GB-DDR4-3200MHz-memory-module-RAM/html/product/1261015?
5- G.Skill Ripjaws (F4-3200C15D-16GVK) 3200Mhz CL15 15-15-15-35 (192,90$)
https://www.alternate.co.uk/G-Skill/16GB-DDR4-3200-16GB-DDR4-3200MHz-memory-module-RAM/html/product/1260864?
6- G.Skill TridentZ (F4-3200C15D-16GTZSW) 3200Mhz CL15 15-15-15-35 (182,90$)
https://www.alternate.co.uk/G-Skill/16GB-DDR4-3200-16GB-DDR4-3200MHz-memory-module-RAM/html/product/1283675?
ESSA É E-DIE MAS ESTA NA QLV DA MINHA MOBO
7- HyperX Predator (HX432C16PB3K2/16) 3200Mhz CL16 16-18-18-32 (172,90$)
https://www.alternate.co.uk/HyperX/DIMM-16-GB-DDR4-3200-Kit-RAM/html/product/1278977?event=search
Lembrando que os valores são em Libras (R$ 5,45~ na conversão) e não dólares, qual pente vale mais a pena?
Fiquei mais interessado nos FlareX CL14 de 207,90$, pelos ótimos relatos que vi na internet. Mas o TridentZ CL15 por 182,90$ é 125 reais mais barato e perde somente por 1 de latência.
Podem me ajudar?
@Atretador @LISMAO @Phoenyx
Pessoal vi esse Kit:
https://www.terabyteshop.com.br/produto/9367/kit-upgrade79-placa-mãe-processador-amd
Vou conseguir fazer OC com ela? Pelo menos chegar com ele a 3.9 ~4.0ghz, porque vi que os VRM's dessa placa são duplicados, apesar de os indutores parecerem medianos. Obrigado.
Queria economizar na placa-mãe...
Alguém aqui que possua uma Tuf b350m (ou qualquer b350 da asus) ta conseguindo usar suas memórias acima de 3200?? Peguei um kit b-die e não consigo deixar estável acima de 3200 de jeito nenhum, nem mesmo no perfil xmp.. Só consegui estabilidade no máximo em 3133 e to rodando aqui agora em 14 14 14 24 38 1.35v
Em 05/08/2018 às 20:49, VinyBr disse:
Cara não li nada, pois não entendo nada! Mas, compensa over no ryzen 5 2600? Sendo sincero nem sei a velocidade que ela roda, porque ele tem boost...
Da para tirar uns 10-15% a mais de performance, caso voce nao esteja limitado pela GPU.
@Atretador em desempenho mesmo,tava vendo que um i5-8400 ,por exemplo , dava gargalo em jogo cpu bound mesmo com gtx 1080 , o que limitava totalmente o conjunto. No ryzen percebi que o uso de cpu era melhor mesmo q n seja melhor em single core que o i5. Em termos de fps por exemplo , eu possuo uma rx 580 com o ryzen 1600 e o uso em stock , no ac origins/odyssey mesmo no preset médio/high ele fica ali na casa dos 45-52 fps. Mesmo quando coloco em low ele fica ainda na casa dos 50-60 , sendo q a config é "suficiente". No caso se eu tivesse uma gtx 1080 não iria mudar nada ou pouca coisa ? Eu sei que Ac é um "câncer" dos jogos e não se deve nem usar ele como exemplo , mas estou usando para entender como funciona o desempenho de cpu/gpu em jogos de cpu bound.
PS: não ligo para fps desde q obtenha um equilíbrio jogabilidade/gráfico, priorizando jogabilidade. A pergunta é só visando um conhecimento básico e rápido sobre o assunto.
@Pedro Anderson Aqui tem um R5 1600 com uma GTX1070, os ultimos AC tem sido bem canalhas com CPU, tendo diferença ate de processador de 12 núcleos vs 16 nucloes.
adicionado 0 minutos depois
GPU fica nos 99% praticamente todo o tempo
porém, recomendo olhar a RX VEGA 56, que esta na casa dos 2100R$ e em muitro jogos ela entrega a mesma performance que a GTX1080, em alguns jogos como Forza e Battlefield V ela até ganha.
@Atretador
Os últimos AC estão vindo mal otimizados o uso alto do cpu é por conta de menos consumo da vram e mais uso da ram principal(alocada), fazendo o processador ser mais requisitado;  não importa se a gpu tiver 8gb, 11gb sempre o uso da ram principal vai ser maior e pouco consumo de vram, o porte é feito do console para pc, os devs não otimizaram essa parte.
Minhas configs são:
Ryzen 3 1200
MSI B350M
GTX 1060 3gb
4gb Mushkin 2400mhz
4gb Crucial 2400mhz
HD de 1tb
EVGA 430w
Bom, eu tentei botar 3.5ghz com a tensão AUTO, mas alguns jogos começaram a congelar, acreditei que foi por causa do OC, daí baixei pra 3.4ghz e ficou estável.
Depois de um tempo, eu fui dar uma fuçada na bios, e ativei o GAME BOOST, aí ficou 3,5ghz, mas a tensão subiu pra 1,2 alguma coisa. Nesse aí, a temperatura ficou no máximo 67º, cooler stock, uns 30º de temperatura do ambiente.
Eu gostaria de deixar ele em 3.7ghz pra não passar tanto de 70º e ter ganhos de performance, como todo mundo que faz OC :P.
Eu só tenho umas dúvidas:
Fazendo overclock iria causar algum problema no meu PC, já que a fonte é de 430w e tem que levar os outros componentes?
Como eu devo fazer o procedimento? Aumentando o clock 100mhz em 100mhz e testando, até ficar instável, daí eu aumento a tensão?
Se der tela azul, depois que eu fizer o OC, claro, eu devo ir na BIOS e diminuir o clock ou aumentar a tensão. Mas e se o PC resolver não ligar ou não bootar mais?
@P.D.R Bom dia!
Eu quando faço OC sempre parto de uma base. Teu proc é mais simples, eu tentaria, de cara, 3,8GHz com 1.35v, nisso abriria o cinebench e roda o teste, se passou e as temps ficaram baixas, aí eu iria para um aida FPU, entretanto, no cooler box isso não é recomendado.
Porém, tu ta usando qual cooler? o Cooler box? Se sim, então esquece OC alto, o máximo que irá pegar é uns 3.7 ou 3.6.
Mas se você comprar um aircooler de 150 reais como o m410p, ele irá segura esse proc até os 4ghz e você não irá ter problemas de aquecimento do proc nem da mobo.
