Correr
AD - problema de sincronização.
Olá a todos,
Eu rodei o dcdiag no meu servidor AD e encontrei um problema de replicação na parte de logs devido a "hora não sincronizada".
Como posso manter todos os servidores AD (e se possível os computadores do domínio) com a hora sincronizada ?
Directory Server Diagnosis
Performing initial setup:
   Trying to find home server...
   Home Server = srv-ad02
   * Identified AD Forest.
   Done gathering initial info.
Doing initial required tests
   Testing server: Default-First-Site-Name\SRV-AD02
      Starting test: Connectivity
         ......................... SRV-AD02 passed test Connectivity
Doing primary tests
      Starting test: Advertising
         ......................... SRV-AD02 passed test Advertising
      Starting test: FrsEvent
         ......................... SRV-AD02 passed test FrsEvent
      Starting test: DFSREvent
         ......................... SRV-AD02 passed test DFSREvent
      Starting test: SysVolCheck
         ......................... SRV-AD02 passed test SysVolCheck
      Starting test: KccEvent
         ......................... SRV-AD02 passed test KccEvent
      Starting test: KnowsOfRoleHolders
         ......................... SRV-AD02 passed test KnowsOfRoleHolders
      Starting test: MachineAccount
         ......................... SRV-AD02 passed test MachineAccount
      Starting test: NCSecDesc
         ......................... SRV-AD02 passed test NCSecDesc
      Starting test: NetLogons
         ......................... SRV-AD02 passed test NetLogons
      Starting test: ObjectsReplicated
         ......................... SRV-AD02 passed test ObjectsReplicated
      Starting test: Replications
         ......................... SRV-AD02 passed test Replications
      Starting test: RidManager
         ......................... SRV-AD02 passed test RidManager
      Starting test: Services
         ......................... SRV-AD02 passed test Services
      Starting test: SystemLog
         A warning event occurred.  EventID: 0x0000008E
            Time Generated: 05/30/2018   09:51:03
            Event String:
            The time service has stopped advertising as a time source because the local clock is not synchronized.
         A warning event occurred.  EventID: 0x00000032
            Event String:
            The time service detected a time difference of greater than 5000 milliseconds for 900 seconds. The time difference might be caused by synchronization with low-accuracy time sources or by suboptimal network conditions. The time service is no longer synchronized and cannot provide the time to other clients or update the system clock. When a valid time stamp is received from a time service provider, the time service will correct itself.
            Time Generated: 05/30/2018   09:51:59
            Event String:
         ......................... SRV-AD02 passed test SystemLog
      Starting test: VerifyReferences
         ......................... SRV-AD02 passed test VerifyReferences
   Running partition tests on : ForestDnsZones
      Starting test: CheckSDRefDom
         ......................... ForestDnsZones passed test CheckSDRefDom
      Starting test: CrossRefValidation
         CrossRefValidation
   Running partition tests on : DomainDnsZones
         ......................... DomainDnsZones passed test CheckSDRefDom
         CrossRefValidation
   Running partition tests on : Schema
         ......................... Schema passed test CheckSDRefDom
         ......................... Schema passed test CrossRefValidation
   Running partition tests on : Configuration
         ......................... Configuration passed test CheckSDRefDom
         ......................... Configuration passed test CrossRefValidation
   Running partition tests on : dominio
         ......................... dominio passed test CheckSDRefDom
         ......................... dominio passed test CrossRefValidation
   Running enterprise tests on : dominio.CORP
      Starting test: LocatorCheck
         ......................... dominio.CORP passed test LocatorCheck
      Starting test: Intersite
         ......................... dominio.CORP passed test Intersite
