dronan
Note HP DV8230 - Consigo R$3200,00 ??
Pessoal
Quero dar um upgrade no meu note (downgrade de peso lol ) ... preciso de um mais leve, esse acaba com minhas costas quando carrego :P
Sera que consigo R$3200,00 levando em considerção que paguei pouco mais de 4 mil a cerca de 2 anos...?
Product Name DV8230
US Product Number EZ701UA#ABA
Microprocessor 1.66 GHz Intel® Centrino® Duo mobile technology Intel® Core? Duo processor T2400
Microprocessor Cache 2MB L2 Cache
Memory 1024MB 667MHz DDR2 System Memory (2 Dimm)
Memory Max 2048MB
Video Graphics NVIDIA GeForce Go 7400
Video Memory 128MB Dedicado + 128MB compartilhado
Hard Drive 160GB 5400RPM Dual HDD
Multimedia Drive Super Multi 8X DVD±R/RW with Double Layer Support
Display 17.0" WXGA+ High-Definition BrightView Widescreen Display (1440 x 900)
Fax/Modem High speed 56k modem
Network Card Integrated 10/100BASE-T Ethernet LAN (RJ-45 connector)
Wireless Connectivity Intel® PRO/Wireless 3945ABG Network Connection
Sound Altec Lansing
Keyboard Notebook keyboard with scroll bar and integrated numeric keypad
2 Quick Launch Buttons (HP Quick Play Music and DVD buttons)
Calculator Launch Button
Pointing Device Touch Pad with dedicated vertical Scroll Up/Down pad
PC Card Slots 1 ExpressCard/54 Slot (also supports ExpressCard/34)
1 Type I/II 32-bit card bus (also support 16-bit)
External Ports 6-in-1 integrated Digital Media Reader for Secure Digital cards, MultiMedia cards, Memory Sticks, Memory Stick Pro, SmartMedia or xD Picture cards
4 Universal Serial Bus (USB) 2.0
1 Headphone out w/SPDIF Digital Audio
1 microphone-in
1 VGA (15-pin)
1 TV-Out (S-video)
1 RJ-11 (modem)
1 RJ -45 (LAN)
1 Expansion Port 2, 1 IEEE 1394 Firewire (4-pin)
1 Consumer IR (Remote Receiver)
Dimensions 11.1"(L) x 15.62"(W) x 1.48"(min H)/1.82"(max H)
Weight 8.1 lbs
Security Kensington® MicroSaver lock slot
Power-on password
Accepts 3rd party security lock devices
Power 90W AC adapter
8-Cell Lithium-Ion
