Placas atuais, boas e "baratas"...
Adriano Silva
:o o que vocês acham dessa aqui:
Alguem já viu ?? sabe como ela é?
KX18D ProII
<div class='bbimg'>%7Boption%7Dhttp://www.albatron.com.tw/images/product/it/mb/Picture/Big/KX18DProII.jpg' border='0' alt='Imagem postada pelo usuário' /></div>
Award
BIOS Update
Driver
Manual
Product News
Product FAQ
<< BACK
Feature
AMD Athlon™ / Athlon™XP / Athlon™XP Barton/ Duron™Processor
soquete 462 with FSB 200/266/333/400+(by overclocking)MHz :wub:
3 DDR400/DDR333/266/200 Memory Sockets
AGP 8X , 6 channel AC 97 Audio
2 ATA133 Channels, up to 4 ATA 133 IDE Devices
nForce2 MCP-T 10/100 Ethernet LAN
2 Serial ATA150 Channels, Serial ATA RAID 0,1 (Software)
2 IEEE1394a Ports
6 USB 2.0/1.1 Ports (4 ports by optional cable)
BIOS Mirror ™
Voice Genie™
Chipset with Hyper-Transport Technology
Bundle SPDIF Card ( optional )
Processor
AMD Athlon™/Athlon™XP/ Athlon™XP Barton/ Duron™Processor
FSB
200/266/333/400+(by overclocking)MHz :tantan:
Chipset
North Bridge: NVIDIA nForce2 SPP (Ultra 400)
South Bridge: NVIDIA nForce2 MCP-T
LAN Chip : LAN PHY ICS1893AF
IEEE1394 Chip : TI IEEE1394A TSB41AB2PAP PAP-64
Audio Codec: Realtek ALC650
Serial ATA Chip :Silicon Image Sil3112A
I / O Chip : Winbond W83627HF
Memory
3 *DDR Sockets:
DDR400/DDR333/266/DDR200 NON-ECC DDR SDRAM up to 3GB ( Single Channel) , up to 2GB ( Dual Channel )
Expansion Slots
1 x AGP 3.0 8X/4X slot (1.5V & 0.8 V Only)
6 x PCI slots (PCI 2.2 compliant)
IDE Connectors
2 ATA133 channels, up to 4 ATA 133 IDE Devices
Onboard I/O Connectors
1 x Floppy Connector
2 x USB 2.0/1.1 header (4 ports USB cable optional)
2 x IEEE1394 header (2 ports IEEE1394 cable optional)
1 x CD_IN header
1 x COM Port header
1 x S/PDIF in/out header (S/PDIF in/out cable optional)
1 x CPU fan header with fan rotation detection function
1 x System fan headers with fan rotation detection function
1 x10 pin system panel header (Intel spec)
1 x 3 pin Power LED header
1 x 4 pin Speaker header
1 x Front audio header (Intel spec)
1 x Case Open detection header
1 x Wake on LAN
I/O via Back Panel
PS/2 keyboard/mouse, 2 x USB(2.0/1.1), RJ45 ,1 x Com(serial), 1 x Parallel, 1x Game/Line-in/Line-out/MIC
Power
20-pin ATX power connector
BIOS Feature
4 Mb Flash EEPROM
Award BIOS with ACPI, DMI2.0, PnP, WfM2.0, Green Suspend to RAM (S3), Suspend to Disk (S4) Wake on keyboard / Mouse, Wake on LAN/RTC Timer
Hardware Monitoring
2 FAN sensors, CPU/System voltages and temperature monitoring
Special Feature
Zero Jumper Design
BIOS Mirror™ Protect BIOS by creating an original mirror image of itself
Voice Genie ™ Voice Troubleshooting system ( four-Language )
Adjustable CPU and AGP frequency by 1 MHz increment, Adjustable Vcore, VAGP, VMemory for overclocking.
Special design for CPU Over Temperature Protection.( OTP )
Certifications
FCC,CE, BSMI
Form Factor
ATX (244*305 mm)
Tópico destacado!
Mas ficará assim com uma condição, q respeitem seu propósito inicial, somente indicações/reviews e opiniões sobre placas d baixo custo serão permitidos, posts falando unicamente "Valeu! Muito bom! Ah Huuuuu!" não estão inclusos...
Comentários injustificados como "Esta não presta, esta é ruim, bla bla blá..." também não serão tolerados...
[]'s
Essa ai deve ser caríssima icemario. Só observar as coisas. Dual channel, Nforce 2, Dual Bios, 4MB EEPROM, Firewire... E ainda, Albatron! Deve ser tão cara quanto uma Abit NF7-S Rev 2.0
Só para avisar. Em breve vou adicionar umas placas novas e dar uma melhorada no meu primeiro post lá.
Postado Originalmente por Spider_Rap@01 fev 2004, 18:04
Aliás eu nunca nem vi ela pra vender por aqui, alguém viu? Mas com certeza é beeeeem mais cara que as que estão aqui no tópico....
EDIT: Spider, não to conseguindo abrir os links que você postou...
Estou montando o meu PC e agora só falta a placa mãe. Não queria gastar muito dinheiro nela ( no maximo R$ 260,00). Estava dando uma olhada no preço das placas que vocês indicaram e percebi que a M848 é mais barata. Porém gostaria de saber se vale a pena pagar um pouco a mais pela N2U400 (Nforce 2) ou se é melhor mesmo ficar com a M848 ? Achei a K7S8X por 199 reais mas to achando que ela é usada. A n2u400 no ml estava por 250 reais e a m848 por 189 reais.
Então qual tem o mair custo/beneficio ? ou tem agora outras alem dessas que são melhores e baratas ?
Muito obrigado
Bundos
Deixa eu fazer um pouco a defesa da A7N8X-X.
Ela custa quase a mesma coisa que a Nforce 2 da ECS, paguei 280 reais na minha, mas dá pra achar até mais barato.
Ela tem todos, ou quase todos, os recursos pra overclock e pra timming de memória.
O único senão dela é o fato de ser single channel, mas isso definitivamente não faz a menor diferença, pelo menos não pra jogos, só em alguns aplicativos profissionais o dual channel faz diferença.
Quem duvidar veja aqui um review onde é testada uma A7N8X-X contra uma A7N8X com dual channel, o teste foi feito com um XP 3200+ e com duas memórias Corsair de 400Mhz e cas 2, ou seja o que há de TOP.
Veja que a diferença na maioria dos testes não passa de 3%, e em alguns jogos a A7N8X-X é até mais rápida.
Na minha opinião essa placa é muito melhor que a ECS.
Uma pergunta,
estava em dúvida entre a K7S8X e a M848LU pra montar um micro.
Acabei comprando a PCchips pra fazer um teste, mas já me arrependi.
Motivo:
Pelo que eu vi no site da Pcchips nunca saiu uma atualização de BIOS pra essa placa, a unica BIOS que tem é do começo de 2003.
Enquanto isso a ASROCK lança quase uma BIOS por mes pra K7S8X, sempre com melhora de performance, correção de BUGs e solução de incompatibilidade.
Não é possível que a PCchips tenha feito uma BIOS tão perfeita que não precise de melhorias.
Será que eu to errado e não achei uma BIOS nova ou é isso mesmo????
Postado Originalmente por Spider_Rap@20 fev 2004, 13:24
Nippon, usa o Cheepomemo. Ele funciona em qualquer placa com o SiS 746/746FX/748 e pode alterar os timming no windows. Eu comprei a Asrock K7S8X R 3.0, não vejo a hora de por a bicha pra funciona.
Ajeita ai essa bichinha spider... Quero ver como a rev 3.0 se sai nos benchs...
aí galerinha beleza???bom gostaria de um help........que placa é melhor?
a M848 ou a K7S8x.......tem umas versões mais nova das duas...tem uma K7S8x com SATA.....aqui em Campinas -SP as duas estão por 190,00 gostaria da opinião de vocês.....tenho 512DDR400 já, uma GFMX4000, e um XP2500+ só falta a mb.... vou comprar na quinta feira...por favor me ajudem.... :help:
Spider_Rap
não gostei não, porque no bios da pra resetar e no windows e mais
complicado. :muro:
Como a temperatura não tá muito quente aqui em Sampa subi um pouco o mult 12x200=~2400mhz e vcore 1,725 (to testando)
Era isso
falou!
Postado Originalmente por Pino@13 fev 2004, 06:53
Uma pergunta,
Motivo:
Tão perfeita não .....
Mas vamos dizer quase perfeita, pelo menos nesse item a Pcchips acertou, a Bios é simples mas pelo menos não tem nenhum bug conhecido até agora e nenhum caso de incompatibilidade.
Já a ASRock -_-
Quantas versões só para corrigir bugs já sairam mesmo ?
Postado Originalmente por diego.gimenez@21 fev 2004, 02:18
Eu optaria pela k7s8x, ambas são boas....a 848 que você viu também tem SATA? Se não tiver mais um motivo pra pegar a k7s8x....
bem eu sou um feliz (por enquanto...) proprietário de uma AsRock K7S8X. O som on-board é muito bom, é estável, o unico incoveniente que eu tenho com ela é que durante a inicialização o windows congela por uns 20 segundos, deve ser por causa do driver usb, sei lá. Ou porque eu uso o windows 98SE, quem sabe colocando o windows XP isso melhora...
:unsure: Ai thurma olha eu aqui de novo com mais uma duvida c possível me ajudem
tenho uma k725a pro com uma cpeu atlhon 2000+ e algumas pessoas me disseram que esta placa não so vai ate o 1.600, Sera que que eu comprei uma placa já com overclok por favor me ajudem quero saber se não fui enganado
brigado pela atenção
não ha neste mundo áis melhor que o nosso BRASIL :bandeira:
Abraços a toda a galera do Clube do Hardware
:muro::muro:
você quis dizer uma ECS K7S5a pro? Bom se for essa de acordo com as especificações do fabricante o fsb dela é até 266MHZ. O maior processador com fsb 266 é o Athlon XP 2600+ Thoroughbred, então eu acredito que ela funcione até este processador. Vai depender da bios e dos chipsets. Se no setup indicar um processador de 1.6 GHz então esta correto pois o athlon 2000 roda a essa frequência. A BIOS pode ser uma versão atual e por isso está rodando este processador.
E aí, pessoal, beleza?
Dei uma passada na Santa Efigênia na última segunda-feira e vi uma ECS N2U400A por 300 reais. Pergunta: não é melhor pagar R$270 em uma ASUS A7V8X-X (foi o preço que encontrei)? Aliás, tinha também uma A7V8X-MX (onboard) por R$280. Vale a pena pegar esa placa?
A Asrock estava na faixa de R250.
Parece que baixo custo mesmo é a PCChips, que achei por R$195.
É isso.
Abraço
Eu ajudei a um amigo meu a comprar o M848LU da PCChips, pois tinha visto e alguns tópicos que ela era muito boa e barata!! Que compensava mais ela do que a Asus a7s333 (que é a minha) e coisa e tal!!
Mas sinceramente, a minha placa da asus ta muito melhor do que a dele!!
E quase nem se discute, pois temos o mesmo processador, memoria e placa de video!!
A principal diferença se ve em jogos, em que a minha tem qualidade superior do que a dele!!
então, fica a pergunta: Será que essa PCChips ta estão boa assim??
Obs.: alem do mais, a gente não conseguiu instalar o XP nela, mesmo usando algumas dicas que deram nos tópicos do site!!
O "grande" problema da M848 é que o Vdimm dela é 2,5. Enquanto da Asrock é 2,7. Então, algumas memórias tem sérios problemas de funcionamento na M848, principalmente de estabilidade do sistema. Eu considero a Asrock K7S8X com alguns pontos de vantagem acima da M848, um deles é o Vdimm, outro é que ela tem 1 slot de memória a mais.
Há muitas coisas em questão. Configuração da BIOS, das memórias, latência, HD entre outras coisas.
Vale lembrar que nem todo sistema é igual ao outro, por mais parecido que for. Há muitas coisas em jogo além de clock, quantidade de memória e placa de vídeo. ^_^
Basile
Esses preços estão salgados. Acho que é mais negocio encomendar uma Asrock K7S8X R 3.0 (Como eu fiz :D ) no um pouco de tudo por R$ 193 + R$ 10 de frete (Encomenda Normal). No final sai mais barato. Já fiz duas compras lá, tudo chegou perfeito, dentro do prazo combinado e bem embalado. :-BEER
