Dúvidas entre P7P55D-E e P7P55D-PRO
bruno korn
Olá,
Gostaria de saber qual a diferença entre essas placas mães
P7P55D-E
Descrição do Produto
ESPECIFICAÇÕES
MODELO
• Marca: ASUS
• Modelo: P7P55D-E
CPU SUPORTE
• CPU Socket: LGA 1156
• CPU: Core i7 / i5 / i3 (LGA1156)
• Supported CPU Technologies: Supports Intel Turbo Boost Technology
CHIPSETS
• North Bridge: Intel P55
MEMÓRIA
• Números de Slots: 4×240pin
• Memória suportada: DDR3 2200(O.C.)/1600/1333/1066
• Maximo suportado: 16GB
• Dual Channel: SIM
EXPANSION SLOTS
• PCI Express 2.0 x16: 1 x PCIe 2.0 x16 (single at x16)
1 x PCI Express 2.0 x16 slots (@x4 mode, 2.5GT/s)
• PCI Express x1: 3 x PCI Express 2.0 x1 (2.5GT/s)
• PCI Slots: 2
STORAGE DEVICES
• PATA: 1 x ATA133 2 Dev. Max
• SATA 3Gb/s: 7
• SATA 6Gb/s: 2 x SATA 6Gb/s
• SATA RAID: 0/1/5/10
VIDEO ONBOARD
• Chipset video onboard: Não
AUDIO ONBOARD
• Audio Chipset: VIA VT1828S
• Audio Channels: 8 Channels
LAN ONBOARD
• LAN Chipset: Realtek 8112L
• Max LAN Speed: 10/100/1000Mbps
PAINEL TRASEIRO
• 2 x PS/2 Keyboard/Mouse
• 6 x USB 2.0
• 2 x USB 3.0
• 1 x IEEE 1394a
• 1 x eSATA 3Gb/s
• 1 x S/PDIF Out Optical
• 1 x Portas LAN (RJ45)
USB ONBOARD
• Onboard USB: 3 x USB connectors support additional 6 USB ports
ASPECTOS FÍSICOS
• Modelo: ATX
• Dimensões: 30.5cm x 24cm
• Power Pin: 24 Pin
ACESSÓRIOS
• Disco de instalação
• Manual do Usuario
• Painel traseiro
• IDE/PATA Cable
• SATA Cable
• 3 in 1 Q-connector
e P7P55D-PRO
ESPECIFICAÇÕES
MODELO
• Marca: ASUS
• Modelo: P7P55D PRO
CPU SUPORTE
• CPU: Core i7 (LGA1156) / i5 (LGA1156)
CHIPSETS
MEMÓRIA
• Dual Channel: SIM
EXPANSION SLOTS
• PCI Express 2.0 x16: 2 x PCIe 2.0 x16 (single at x16 or dual at x8/x8 mode)
1 x PCI Express 2.0 x16 slots (at x4 mode, 2.5GT/s
• PCI Express x1: 2
• PCI Slots: 2
STORAGE DEVICES
• SATA 3Gb/s: 7
VIDEO ONBOARD
AUDIO ONBOARD
LAN ONBOARD
PAINEL TRASEIRO
• 1 x IEEE 1394a
• 8 x Portas USB 2.0
USB ONBOARD
ASPECTOS FÍSICOS
• Modelo: ATX
• Dimensões: 30.5cm x 21.84cm
• Power Pin: 24 Pin
ACESSÓRIOS
• Manual do Usuario
• Painel traseiro
• IDE/PATA Cable
• SATA Cable
• eSATA bracket
• Adaptador de energia serial ATA
A diferença entre usar CrossfireX qual seria a melhor?
notei que uma tem usb 3.0, vale a pena? apesar o preço é tão semelhante. queria saber qual posso comprar com segurança.
a diferença no preços está em R$: 35
a versão E é mais cara.
Valeu!
  • Administrador
A diferença de uma para a outra, está nos opcionais...
A questão de desempenho, inclusive no Crossfire, as duas, apresentaram, a mesma coisa, o que encarece aí, é só os opcionais, que cada uma apresenta...
Bom, se tem como você pegar, a que já suporta USB 3.0 seria uma boa...
Olá,
Valeu!
Tem coisa que são uma verdadeira piada....rs..rs...
Quem em sã consciencia usará [ Multi-GPU Support Supports ATI® Quad-GPU CrossFireX™ Technology ] na P7P55D-E " se depois do híven não vir as letras T ou V desconfie" Quad-GPU em dois Slots de 16x obrigatóriamente seriam duas VGAs bi-processadas. VGA bi-processada em slot de 4 lanes, não dá né??
Pior, se inserir uma plaquinha num dos PCI-E 1x o PCI-E 16x (preto) terá sua velocidade reduzida a 1x, imagine um multi-gpu a 1x...
Mais uma coisa, caso você insira uma VGA no slot PCI-E 16x(preto) o DMI que já é estreito para SATA 6 e USB 3.0 vai colher ainda o protuto dessa VGA pra transferir pro controlador PCI-E principal que fica no Processador, imagine o tempo que será gasto..
Pega P7P55D PRO mesmo porque SATA III e USB 3.0 os produtos ainda estão verdes e só farão diferença mesmo de desempenho daqui a um tempo e certamente essa placa já será o que hoje é um revolucionário P4, funciona, atende bem boa parte dos usuários, mas quem quer um?
LGA 1156 até Junho de 2011 será extinta, dando lugar a LGA 1155.
Quanto a Crossfire a P7P55D PRO faz dual VGA a 8x e até trio VGA 2 a 8x + 1 a4x e também dar suporte a SLI coisa que a P7P55D-E não faz.
Valeu pelas dicas! ficarei com P7P55D-PRO e um i7 860.
No começo usarei 1 HD 5770 e depois comprarei outra igual.
sata 3 e usb 3 não vão servir para mim agora. Já vou da um grande pulo. tinha um P4!! hahaha
hoje chegou a fonte e as memorias (:
650TX da corsair deve aguentar firmes 2 HD5770 ou 2 5850. right?
abraços, podem fechar.
