Javascript Não consigo usar typed.js
Eu sei que é fácil de usar, mas por algum motivo eu não consigo. Esses erros aparecem quando eu inspeciono:
Código:
<!DOCTYPE html>
<html lang="pt-br">
    <head>
        <meta charset="utf-8" />
        <meta name="viewport" content="width=device-width, initial-scale=1, shrink-to-fit=no" />
        <meta name="description" content="" />
        <meta name="author" content="" />
        <title>Lucas C.</title>
        <!-- Favicon-->
        <link rel="icon" href="\static\img\favicon.jpg" />
        <!-- Font Awesome icons (free version)-->
        <script src="https://use.fontawesome.com/releases/v5.15.1/js/all.js" crossorigin="anonymous"></script>
        <!-- Google fonts-->
        <link href="https://fonts.googleapis.com/css?family=Merriweather+Sans:400,700" rel="stylesheet" />
        <link href="https://fonts.googleapis.com/css?family=Merriweather:400,300,300italic,400italic,700,700italic" rel="stylesheet" type="text/css" />
        <!-- Third party plugin CSS-->
        <link href="https://cdnjs.cloudflare.com/ajax/libs/magnific-popup.js/1.1.0/magnific-popup.min.css" rel="stylesheet" />
        <!-- Core theme CSS (includes Bootstrap)-->
        <link href="<?php \Core\Utils\Dir::staticDir('css/styles.css') ?>" rel="stylesheet" />
    </head>
    <body id="page-top">
        <!-- Navigation-->
        <nav class="navbar navbar-expand-lg navbar-light fixed-top py-3" id="mainNav">
            <div class="container">
                <class="navbar-brand js-scroll-trigger" href="#page-top">Lucas Cechinel</a>
                <button class="navbar-toggler navbar-toggler-right" type="button" data-toggle="collapse" data-target="#navbarResponsive" aria-controls="navbarResponsive" aria-expanded="false" aria-label="Toggle navigation">
                    <span class="navbar-toggler-icon"></span>
                </button>
                <div class="collapse navbar-collapse" id="navbarResponsive">
                    <ul class="navbar-nav ml-auto my-2 my-lg-0">
                        <li class="nav-item">
                            <class="nav-link js-scroll-trigger" href="/">Início</a>
                        </li>
                            <class="nav-link js-scroll-trigger" href="/textos">Textos</a>
                        </li>
                            <class="nav-link js-scroll-trigger" href="#contact">Sugestões</a>
                        </li>
                    </ul>
                </div>
            </div>
        </nav>
        <!-- Masthead-->
        <header class="masthead">
            <div class="container h-100">
                <div class="row h-100 align-items-center justify-content-center text-center">
                    <div class="col-lg-10 align-self-end">
                        <h1 class="text-white font-weight-bold">Lucas Cechinel</h1>
                        <hr class="divider my-4" />
                    </div>
                    <div id="typed-strings" class="align-self-baseline">
                        <class="text-white-75 font-weight-light mb-5 h3">Estudante</p>
                        <class="text-white-75 font-weight-light mb-5 h3">Programador</p>
                    </div>
                    <span id="typed"></span>
                </div>
            </div>
        </header>
        <section>
        </section>
        <!-- Contact-->
        <section class="page-section bg-custom" id="contact">
                <div class="row justify-content-center">
                    <div class="col-lg-8 text-center">
                        <h2 class="mt-0">Sugestões?</h2>
                        <class="text-muted mb-5">Envie suas sugestões para o email abaixo!</p>
                    </div>
                </div>
                <div class="row">
                    <div class="col-lg-12 mr-auto text-center">
                        <class="faz fa-envelope fa-3x mb-3 text-muted"></i>
                        <!-- Make sure to change the email address in BOTH the anchor text and the link target below!-->
                        <class="d-block text-decoration-none" href="mailto:lucascechinel9@gmail.com">lucascechinel9@gmail.com</a>
                    </div>
                </div>
            </div>
        </section>
        <!-- Footer-->
        <footer class="bg-light py-5">
                <div class="small text-center text-muted">Copyright © 2021 - Lucas Cechinel da Silveira</div>
            </div>
        </footer>
        <!-- Bootstrap core JS-->
        <script src="https://code.jquery.com/jquery-3.5.1.slim.min.js"></script>
        <script src="https://cdn.jsdelivr.net/npm/bootstrap@4.5.3/dist/js/bootstrap.bundle.min.js"></script>
        <!-- Third party plugin JS-->
        <script src="https://cdnjs.cloudflare.com/ajax/libs/jquery-easing/1.4.1/jquery.easing.min.js"></script>
        <script src="https://cdnjs.cloudflare.com/ajax/libs/magnific-popup.js/1.1.0/jquery.magnific-popup.min.js"></script>
        <!-- Core theme JS-->
        <script src="<?php \Core\Utils\Dir::staticDir('js/scripts.js') ?>"></script>
        <script src="<?php \Core\Utils\Dir::staticDir('js/typed.js') ?>"></script>
        <script>
            $('document').ready(function(){
                var typed = new Typed("#typed",{
                    stringsElement: '#typed-strings',
                    backSpeed: 40,
                    typeSpeed: 40
        </script>
    </body>
</html>
Acredito que se você usar uma CDN resolva seu problema:
troque
<script src="<?php \Core\Utils\Dir::staticDir('js/typed.js') ?>"></script> para <script src="https://cdn.jsdelivr.net/npm/typed.js@2.0.11"></script>
