Python Período de uma onda senoidal
import cv2
import numpy as np
from skimage.io import imsave
import matplotlib.pyplot as plt
from statsmodels.graphics.tsaplots import plot_pacf
import statsmodels as sm
from PIL import Image
from PIL.Image import NEAREST
from PIL.Image import BICUBIC
import numpy as np
import pandas as pd
import seaborn as sns
from sys import argv
from math import pi, sin
from scipy import fftpack
#fs é a frequência de amostragem
fs = 20.0
t = np.linspace(0,17,17);
#t= np.array([0,1,2,3,4,5,6,78,9,10,11,12,13,14,15,16,17])#np.linspace(0,1 , int(1*fs), endpoint=False) #números com intervalos especificados.
#precisa especificar onde começar e onde parar.
#s is the sum of sine wave(1Hz) and cosine wave(10 Hz)
s = np.array([0, 0.707, 1, 0.707, 0, -0.707, -1, -0.707, 0, 0.707, 1, 0.707, 0, -0.707, -1, -0.707, 0]) #np.asarray #1.0*np.sin(8 * 2.0 * np.pi * t) #np.sin(np.pi*t)+ np.sin(np.pi*t*2)
plt.plot(t, s)
plt.xlim(0,17) #(0,10)
plt.xlabel("tempo")
plt.title('Original Signal in Time Domain')
plt.show()
# Compute the one-dimensional discrete Fourier Transform.
fft_wave = np.fft.fft(s)
# Compute the Discrete Fourier Transform sample frequencies.
fft_fre = np.fft.fftfreq(n=s.size, d=1/fs)
plt.subplot(111)#(211) #linhas, colunas e o número do gráfico.
plt.plot(fft_fre, fft_wave.real, label="Real part")
plt.xlim(-5,5)
plt.ylim(-10,10)
#plt.legend(loc=1)
plt.title("FFT in Frequency Domain")
plt.subplot(212)
plt.plot(fft_fre, fft_wave.imag,label="Imaginary part")
#plt.legend(loc=1)
plt.xlim(-5,5)
plt.ylim(-10,10)
plt.xlabel("frequency (Hz)")
plt.ylabel("Amplitude")
plt.xlabel("Time [s]")
plt.bar(fft_fre, np.abs(fft_wave), width=0.5) #np.abs é uma matriz de entrada
plt.show()
frequencias = fft_fre #Retorne as frequências de amostra da Transformada Discreta de Fourier.
period_time = 1 / frequencias
amplitudes = np.abs(fft_wave) #(0, 0.707, 1, 0.707, 0, -0.707, -1, -0.707) np.abs= calcula o valor absoluto por elemento
fpos=frequencias[frequencias>0] #mascara para só pegar valores positivos
apos=amplitudes[frequencias>0]
plt.xlabel("Frequency [Hz]")
plt.bar(fpos,apos, width=0.1) #plt.scatter p gráfico ser de pontos
plt.show()
idx=np.argmax(apos) #Retorna os índices dos valores máximos ao longo de um eixo.
print("Máxima amplitude corresponde a=",apos[idx])
tpCount     = len(apos)
timePeriod  = tpCount/fs
#peiodo = ii_arr[apos_max[0]:apos_max[1]] #priodo é a distancia entre duas amplitudes maximas
#print("O período corresponde a=", tpCount/fs)
Quero encontrar o período desta onda seno.. alguém consegue me ajudar a organizar o código para que isso seja possível?
