Test Drive Unlimited 2 (Lançado em 08/02/2011)
Kyuzo
Patch para PC disponível:
Last Update: February 17, 10:00AM PST
Hello Everyone,
The latest PC patch has been released, which contains the following changes:
•Clubs are ready to be enabled and should be turned on soon
•MyTDULife is now enabled
•Several connection problems have be corrected
•You can now access Co-op multiplayer races via the map
•Weather when offline is now operational
•“Lancia with purple wheels” has been fixed, and is corrected for players who are currently affected by the issue
•Clothing options no longer disappear in dressing-rooms
We will be monitoring the servers throughout the day. Please feel free to post your feedback here on the forums. Let us know if you feel like your the issues above have been fully resolved for you! Your voice is an important part of the process.
Once again, thanks to everyone who has taken the time to share their feedback here on the forums. Rest assured that we have been working diligently to get these issues resolved, and are very grateful for the support that we have received from our fans during the launch rush.
-GMDestra and the TDU2 Team
Hmm, saiu o patch, mas nada fala sobre melhorar o desempenho (pros que tão reclamando do desempenho baixo) e pros bugs dos controles...
Agora sim, o clima vai funcionar quando joga offline, bem que eu notei que eu joguei até agora e não caiu uma gota de chuva hehehe.
Gp150: tu tá usando o X360 Controler Emulator do Racer_S? Aqui funcionou normal quando eu testei, só copiei os arquivos xinput1_3.dll e x360cemu.ini pra pasta onde tá localizado o executável do jogo.
jcbotelho, tava jogando contigo ontem, mas aquele horário eu fico meio fora do ar
jogo dormindo no volante e bato em tudo que é curva
mas findi isso não acontece, e to tentando reunir a galera que conheço dos fóruns pra dar um rolé no jogo =D
Ok.
Jogo muito pouco a noite também. De dia quem joga é meu filho, fds jogarei mais, nos vemos lá. Preciso terminar a Ibiza Cup pra levantar uma grana e tirar as licenças do Havai...
Ok.
te prepara que o downhill com o mercedes é tenso pra caramba de fazer, fiz umas 30x pra conseguir
e o aston martin é o terror também
Galera...
To com um problema meio esquisito aqui...
Meu PC ta travando quando rodo TDU2 por algum tempo... Testei outros jogos e eles rodaram por horas numa boa...
Troquei os drivers e também nao deu...
Rodei com over e sem over e nada...
Depois disso formatei a maquina e reinstalei tudo de novo coloquei pra roda e de novo travo o PC :mad:
Ps: Quando rodei ele no modo offline ele nunca travou...
Cheguei minhas configuraçoes de rede e está tudo ok... Até porque nos outros jogos online tudo funciona numa boa :/
Ae o vídeo de gameplay aqui na minha configuração depois do patch.
ignorem alguns erros e saídas da pista, jogava com uma das mãos só, tava enrolado aqui.
Configuração da assinatura, e detalhes de como tava rodando na descrição do vídeo.
Ignorem a parte final do vídeo sem som.
O conversor bugou e repetiu o vídeo todo depois do fim do com som....
Depois de ter que reiniciar o jogo do zero, após estar no nível 29 (por burrice minha, pois comecei a jogar no dia do lançamento, e os servidores estavam todos caídos, aí comecei um profile off-line e só depois descobri que, INEXPLICAVELMENTE, não dava pra usar ele on...), o que encontramos de surpresa hoje?
Com a instalação automática de mais um patch (pelo menos, pela lógica é pra ser, pois baixou alguns arquivos totalizando essa quantia de dados quando usei o launcher pela primeira vez hoje), o que é que acontece?
Resposta: SERVIDORES OFFLINE.
Realmente, parabéns, Atari. Oitenta reais jogados no lixo pelo jeito até o momento. Mais de dez dias de lançamento do jogo que pretende ser um MMOR e os caras não conseguem deixar os servidores de pé pra galera jogar. Brincadeira.
Desde que voltei a jogar (já no modo online), na quinta-feira à noite, nas quatro oportunidades em que eu queria correr, em três delas os servidores estavam offline - na verdade, nessa última vez eu já estava jogando, quando os servidores caíram...
Vamos ver se essa porcaria volta, porque estou no nível 3 agora - ia terminar a última corrida do campeonato C4 "High", quando a m3rd@ do server caiu...
Isso se não corrompeu meu save, como já aconteceu com muita gente. Estou fazendo backup todo dia, mas na sessão de jogo de agora há pouco, tinha feito bastantinha coisa.
E vocês, estão conseguindo jogar?
Abraços.
Aqui melhorou bastante.
ganhei cerca de 10 frames dependendo da área da cidade.
Mas tenho um amigo que mesmo depois dos 2 patchs continua rodando quase rastejando. X2 4200+, 4670 ICE-Q e 3 GB. Estranho, por que tenho mais alguns amigos com 9500 GT que rodam melhor que ele.
Anyway, aqui os bugs terminaram, pelo menos os mais notáveis.
Os caras estão trabalhando duro, isto não podemos negar:
PC - Open Issues and Service Status
Last Update: February 21, 7:00PM PST
Hello Everyone,
We recently released a PC patch which contained the following fixes:
•Friends list should no longer disappear
•Friend invites should now consistently work
•Club issue should be fixed. Clubs are now online.
•Further enhancements to prevent file corruption have been added.
•Additional back-end functionality to recover previously corrupted save files has been aded.
We are actively troubleshooting an issue where some users are unable to log in. While the servers are up, you may experience an inability to log into the game. If this occurs, multiple connection attempts may allow you to properly log in.
We have a potential server-side fix which is currently being tested. If things go well, we plan to release the fix on Tuesday morning (PST), after which we will monitor the results to see if we have improved the success rate of connection attempts.
Please feel free to post your feedback here on the forums. Let us know if the issues above have been fully resolved for you! Your voice is an important part of the process.
Clubs are on!
Sincerely,
Service Status:
•Online Play – Online, being monitored. Although the servers are online, we are receiving a small number of reports from players who cannot log in. Our research has shown that many of the players affected by this issue are able to log in after multiple attempts. We are actively troubleshooting this issue, and should be pushing a potential server-side fix on Tuesday morning, PST.
•UpLauncher Service Status – There is a known issue with the launcher where it is always saying that the servers are offline, even if they are online.
•DLC Purchasing – Online
•Pre-Order Code Redemption - Online
•Pre-Order Casino Code Redemption -Online
•Getting pre-order cars and Casino in-game - There is a bug where pre-order cars don't show up in the Used Car dealer if you are online. However, you can play Offline, purchase the car, then sign back on and you'll still have it.
•Casino Access - Online
•Friends list - Online
•MyTDULife - Online
•Clubs - Online
PuNiShEr;4872375']Alain' date='
Rodando como em 720P / 1080P? Média de Frames?
Só jogo esse jogo se na minha config pegar acima dos 40 FRAMES.
Vi um video de uma HD5770 que é inferior a minha, e achei bem "lagado"[/quote']
Na descrição do vídeo tá tudo detalhado
1440x900, sem aa, 24~55 fps, dependendo da área da cidade
Dá pra jogar muito bem.
Seu desempenho não ficará muito longe da HD5770 nao....vai depender tb, de qual resolução usará no jogo, e qual era usada no video da 5770 q você viu...
Com 30fps, você já consegue jogar o TDU muito bem...
PuNiShEr;4875004']Bom' date=' vou pegar então.
Pretendo jogar em 1440x900 também. mais com filtro de no minimo 2X[/quote']
Sugiro que espere um pouco, o jogo ainda está muito bugado...
A não ser que não tenha nenhum outro jogo para jogar, ou se, como eu, gostar muito de TDU...
Mas se prepare...:(
Para mais informações, dá uma lida no forum oficial do jogo... Para sentir o que os jogadores estão dizendo oficialmente...
poxa o pessoal ta trabalhando dia e noite la,
aqui com o jogo sem nenhuma atualizaçao rodo "legal",
porque assim, nao tem nenhum lag, mas os graficos estão tudo low (somente os carros com high), 1920x1080, com aa2x...
nunca tive paciencia de conferir com quantos frames roda em cada mudança das configuraçoes, mas assim, como eu to rodando deve tar 30-40
Edit:
Agora vi, sua GTX260 é de Note.
Então logo tá com um desempenho legal mesmo.
Vou ve se compro hoje pela steam.
Sinceramente, não gostei do jogo. Não gostei dos gráficos, não gostei da jogabilidade, não gostei de como o carro se comporta e tal... No geral, comparando o TDU com esse aqui, o TDU ganha de 1000x0... (_(
Nem tenho mais vontade de jogar... E ahh, so pra contribuir, aqui rodou legal. 1920x1080 tudo em Very High e AA4x. So não vi o fps, mas não travou e rodou bem fluido, ate mesmo nas partes mais "pesadas" digamos assim.
Abraços
Esse foi provavelmente o jogo mais aguardado por mim ultimamente, mas a quantidade de bugs meio que desanimou, sei lá, não vou chutar o balde e dizer que não gostei do jogo, continuo jogando, vou terminar, mas sei lá, sei lá se o primeiro TDU teve o gostinho de ser o primeiro, mas eu me encarnei bem mais no primeiro do que nesse...
Ainda tenho muita coisa pela frente, vamos ver se quando chegar nos "carrões" a coisa melhora!
Os bugs já eram esperados (eu ao menos esperava) vide o que aconteceu com o 1.
Vou pegar esse jogo lá pro segundo semestre, até lá acho que a maioria dos bugs vão ser corrigidos.
Certeza que esse, teve mais bugs que o 1. Na epoca que eu peguei o DVD com o meu amigo do 1, instalei-o sem os patchs e rodou muito bem. Na epoca não tinha essa maquina da assinatura, mas mesmo assim, rodou bem legal. Pelo que me lembro, foi em 1024x768 e AA2x.
