Atenuação e SNR (Sinal-Ruído) - análise do seu sinal ADSL
Minha velox ta mt ruim na ultima semana, havendo muitas quedas e lentidão... uso um modem DLINK 2640B e tenho velocidade de 10mb +-... aqui estão os dados:
Mode: ADSL2+
Line Coding: Trellis On
Status: No Defect
Link Power State: L0
Downstream Upstream
SNR Margin (dB): 4.1 5.5
Attenuation (dB): 34.0 16.4
Output Power (dBm): 0.0 12.8
Attainable Rate (Kbps): 4872 488
Rate (Kbps): 3859 390
MSGc (number of bytes in overhead channel message): 64 66
B (number of bytes in Mux Data Frame): 13 12
M (number of Mux Data Frames in FEC Data Frame): 16 8
T (Mux Data Frames over sync bytes): 8 1
R (number of check bytes in FEC Data Frame): 16 16
S (ratio of FEC over PMD Data Frame length): 1.8408 7.8689
L (number of bits in PMD Data Frame): 1043 122
D (interleaver depth): 16 2
Delay (msec): 7 3
Super Frames: 134377 134375
Super Frame Errors: 14 2
RS Words: 4703200 1142187
RS Correctable Errors: 3540 345
RS Uncorrectable Errors: 127 N/A
HEC Errors: 14 0
OCD Errors: 0 0
LCD Errors: 0 0
Total Cells: 19700541 1990380
Data Cells: 822253 114307
Bit Errors: 0 0
Total ES: 9 2
Total SES: 0 0
Total UAS: 18 30
Obrigado ! =)
Desliguei por 10 segundos e religuei o modem ai melhorou...
Mode: ADSL2+
Status: No Defect
Downstream Upstream
SNR Margin (dB): 15.9 21.5
Attenuation (dB): 29.5 12.5
Output Power (dBm): 0.0 12.6
Attainable Rate (Kbps): 17076 676
Rate (Kbps): 11292 574
MSGc (number of bytes in overhead channel message): 59 68
B (number of bytes in Mux Data Frame): 174 17
M (number of Mux Data Frames in FEC Data Frame): 1 8
T (Mux Data Frames over sync bytes): 2 1
S (ratio of FEC over PMD Data Frame length): 0.4945 7.5740
L (number of bits in PMD Data Frame): 3090 169
D (interleaver depth): 64 2
Delay (msec): 7 3
Super Frames: 1057845 1057843
Super Frame Errors: 1524 482
RS Words: 137519894 8991665
RS Correctable Errors: 153655 629
RS Uncorrectable Errors: 93842 N/A
HEC Errors: 1369 2322
OCD Errors: 209 0
LCD Errors: 0 0
Total Cells: 452605764 23035427
Data Cells: 4364214 6212481
Bit Errors: 0 0
Total ES: 187 55
Total SES: 26 9
Total UAS: 17 44
Edit 2 : Voltou a ficar ruim novamente... melhora piora melhora piora... =(
eae galerinha, será que o pessoal mais entendido nessa area poderia dar uma olhada nos meus dados e me dizer se minha linha suporta 5 MBs mesmo com essa att não tão boa?
SNR Margin (dB): 28.8/31.0
Attenuation (dB): 49.0/ 29.0
Output Power (dBm): 11.3/18.5
Attainable Rate (Kbps): 6240/ 1336
Rate (Kbps): 1120/320
valeu pela atenção e se os dados forem insuficientes para uma analise eu posto tudo depois =)
Pessoal, tenho Velox 2MB mas suspeito que a linha aqui suporte 5MB, porém os atendentes sempre dizem que aqui só suporta até 2 Mega, vejam:
Banda (Cima / Baixo) [kbps / kbps]: 576 / 2272
Linha de Atenuação (Cima / Baixo) [dB]: 12.5 / 27
Margem SN (Cima / Baixo) [dB]: 23 / 31.5
Erros de CRC (Up / Down): 2 / 0
Erros de HEC (Up / Down): 1 / 0
E aí, até quantos mega vai essa "bagaça"?
Olá pessoal alguém me pode ajuda estou tendo muitos problemas com a net aqui em casa
Desse do dia 06/12/2011 vai fazer um mês amanha...
Já tive varias visita dos técnicos da telefônica aqui (è Speedy de 1 mega)
Antes do 06/12 a SNR Margin estava variando de 18 a 20
E a Atenuação de 45 a 48...
Obs.: nesta base a net por uns seis meses sem nen 1 problema....(ja tenho o speedy a 1 ano)
Aqui vai uma foto como esta hoje...
Depois de quatro técnicos...
Mode: ADSL2+
Status: No Defect
Downstream Upstream
Delay (msec): 7 3
HEC Errors: 14 0
OCD Errors: 0 0
LCD Errors: 0 0
Bit Errors: 0 0
Total ES: 9 2
Total SES: 0 0
Total UAS: 18 30
Obrigado ! =)
Mode: ADSL2+
Status: No Defect
Downstream Upstream
Delay (msec): 7 3
OCD Errors: 209 0
LCD Errors: 0 0
Bit Errors: 0 0
Total ES: 187 55
Total SES: 26 9
Total UAS: 17 44
Se melhora/piora apenas com o reboot do modem ADSL, as chances de a sua linha telefônica interna, microfiltos e até mesmo o próprio modem estar com problemas é grande. Recomendo que revise sua infra interna, e, na persistência do problema entre em contato com o suporte D-Link para verificar da possibilidade de atualização de firmware do seu equipamento.
O contato com a operadora, no seu caso, também é muito importante para verificar a integridade da sua linha ADSL desde a central telefônica até o seu modem.
Teoricamente sim, mas na prática (após atualização) pode ser que sua linha ADSL não comporte 5 Mb/s devido à Atenuação estar muito alta para esta velocidade. De qualquer forma, vale a tentativa com a sua operadora.
27/31dB (Atenuação e SNR respectivamente) sua linha comportaria sim 5 Mb/s sentido downstream. O problema é a sua operadora, que mesmo com estas medições pode restringir upgrade de velocidade por outros motivos, como indisponibilidade de DSLAM que suporte velocidades maiores à até a saturação do link disponibilizado em sua região.
Seu problema nem é o SNR, é a Atenuação que esta com medições 'sobrenaturais': +70dB é um valor extremamente ruim.
Se o que você diz é verdade, sobre estes valores terem sido melhores no passado, sem sombra de dúvidas é um problema da própria Telefônica.
Boa noite. Alguem poderia analisar meu modem?
D-Link DSL-2640B / Firmware BCM-4.02L.GVT-20110901
GVT 15 Megas
Uploaded with ImageShack.us
GVT 15 Megas
Modem caindo toda hora, tem vez que ele sincroniza e cai na mesma hora, e as vezes fica horas sem cair.
Mas as quedas são constantes
Ola Linio Alan premeiramente muito obrigado por me ajuda...
infelizmente estou falando a verdade...hoje veiu um tecnico aqui em casa passou unas 1:30 aqui falando na central e mexendo q aquela maquinha deles(nao sei o nome da maquinha) pois bem eu nao estava em casa, foi meu pai que adendeu ele, chengei ate fala com ele no telefone, pois ele me falou
"vou fazer todos os testes e reparo e dexarei meu numeiro de celular aqui, alguer defeito entre 30 dias voce me ligar que eu vejo pra voce"
Linio Alan tambem reparei que line mode estava antes adsl+2 ou algo parecendo agora esta READSL, tem alguma difereicia isso?
sobre a Atenuação o que pode ser ??? é da propria operadora o problema ???
obs.: ja troquei os fios tomanda e microfilto...
Boa noite pessoal, td bem!
Alguém poderia interpretar melhor os dados do meu modem(DLINK 2730B)?
Tenho GVT 15MB, mas tenho quedas diariamente aqui, ja liguei várias vezes para o suporte e nada de resolver.
Ja testei com outros modens também, mas é a mesma coisa, esse dlink foi fornecido pela GVT após a ultima visita técnica, antes eu usava um TP LINK TD 8616 e um router TP LINK TL MR 3420, mas caia da mesma forma.
Segue os dados de SNR e atenuação do dlink 2730B:
Statistics -- xDSL
Mode: ADSL_2plus
Traffic Type: ATM
Status: Up
Downstream Upstream
Line Coding(Trellis): On On
SNR Margin (0.1 dB): 104 40
Attenuation (0.1 dB): 170 84
Output Power (0.1 dBm): 231 104
Attainable Rate (Kbps): 22,804 1,192
Path 0 Path 1
Downstream Upstream Downstream Upstream
Rate (Kbps): 17,663 1,159 0 0
MSGc (# of bytes in overhead channel message): 67 66 0 0
B (# of bytes in Mux Data Frame): 244 36 0 0
M (# of Mux Data Frames in FEC Data Frame): 1 1 0 0
T (Mux Data Frames over sync bytes): 2 1 0 0
R (# of check bytes in FEC Data Frame): 0 0 0 0
S (ratio of FEC over PMD Data Frame length): 0.4429 0.9932 0.0 0.0
L (# of bits in PMD Data Frame): 4,425 298 0 0
D (interleaver depth): 1 1 0 0
Delay (msec): 0.11 0.24 0.0 0.0
INP (DMT symbol): 0.0 0.0 0.0 0.0
Super Frames: 0 0 0 0
Super Frame Errors: 3,961 12,091 0 0
RS Words: 0 1,266,130 0 0
RS Correctable Errors: 0 0 0 0
RS Uncorrectable Errors: 0 0 0 0
HEC Errors: 35,900 4,692 0 0
OCD Errors: 5 0 0 0
LCD Errors: 5 0 0 0
Total Cells: 724,026,521 47,491,943 0 0
Data Cells: 9,118,682 665,212 0 0
Bit Errors: 0 0 0 0
Total ES: 197 2,092
Total SES: 67 224
Total UAS: 42 265
Valeu...
Abraço.
Amigo Punk77...Seu problema é com a atenuação, muito ruido na sua linha. Você usa filtro? Essa atenuação é exorbitante não sei como você consegue conectar deste jeito. Veja.
SNR Margin - Relação Sinal ruído:
- 5db ou menos = ruim, impossível sincronia, quedas freqüentes
- 8db-13db = regular - sem problemas com sincronia do modem
- 14db-22db = muito bom
- 23db-28db = excelente
- 29db-35db = raro
Atenuação:
0 - 19dB = excelente,cabeamento excelente, bem próximo do ARD
20-30dB = Muito bom
30-40dB = bom
40-60dB = regular
60-65dB = pobre
65dB ou superior terão problemas
- 29db-35db = raro
Atenuação:
20-30dB = Muito bom
30-40dB = bom
40-60dB = regular
60-65dB = pobre
Bom dia,
Eu acho estranho esse valores...
Quando usava o meu modem, um TP LINK TD-8616, a minha atenuação era 16.0 db e nesse D-LINK que me foi fornecido pela GVT mostra 160 db :confused::confused:
Sim eu uso filtro de linha...
Quando viajei final do ano esqueci de tirar o cabo de telefone do modem, e chove pra dedeu aqui, o meu TP LINK não passa dos 6,3 db de SNR agora.
Estava pensando em diminuir a minha velocidade pra 10MB, será que adiantaria?
Não gosto desse modem DLINK DSL 2730B, principalmente porque vem com firmware da GVT, e não tem outra firm nem no site do fabricante.
Tenho muitas quedas de conexão, e isso me deixa:mad::mad::mad:.
Abraço.
Galera, briguei muito com a Oi para que eles aumentassem a velocidade da minha conexão. Hoje finalmente tive um sucesso, com pouca boa vontade, eles aumentaram minha conexão de 1mbps para um pouco mais que 3 mbps, vou mostrar os dados para vocês:
Os valores não são muito bons, mas isso não é novidade.
Mode: ADSL2+
Status: No Defect
Downstream/Upstream
SNR Margin (dB): 6.7 14.2
Attenuation (dB): 62.5 37.6
Output Power (dBm): 12.6 0.0
Attainable Rate (Kbps): 4020 912
Rate (Kbps): 3282 576
O modem é um 500B preto da Dlink, comprado há poucos meses.
Contudo, gostaria de perguntar aos amigos se vale a pena revisar a rede interna, visto que ela já tem um bom tempo, moro perto da praia e nunca foi reformada. Será que isso talvez reduza a attenuation e possa aumentar o attainable rate?
Mode: ADSL2+
Status: No Defect
Downstream/Upstream
Acho que seria bom sim trocar a rede interna, ainda mais que voce mora perto da praia. Imagino o estado desses fios... Se puder trocar por fios de cobre de boa qualidade, ótimo. Evite ao máximo emendar fios, e evite fios "baratos", ou seja, de metal comum.
Aqui em casa infiltrou agua no fio que vem do poste até minha casa, aí o tecnico da oi trocou e voltou a funcionar, mas acho que ele pos um fio que não é de cobre, resultado: minha atenuação era 25, foi pra 28 e o SNR era 34, caiu pra 31.
Colega WMoreira, eu creio que seria fácil trocar os cabos que vem da rua até meu modem, mas qual o nome técnico desses cabos? Tem alguma especificação no pedido, além dessa de cobre, que devo ter em mente?
Vixe, o nome certo eu não sei... um técnico da oi/gvt/net etc pode te falar isso, ou talvez se voce for numa loja eletrica e explicar para o quê vai ser o fio o cara saiba. Ou voce pode perguntar nesse site: http://www.portaladsl.com.br/
Aquele fio externo que vem da rua é FE , aquele fio cinza de rede interna você acha por CCI tem 1 par e 2 pares e por ai vai...
Não é difícil não eu mesmo to trocando a minha rede interna.
você pode pedir pra sua operadora de telefonia fazer pra você, é obrigação deles, se eles não quiserem fala que você vai cancela a linha, fazer uma reclamação na ANATEL, que eles se coçam rapidinho...
Abraço.
Abraço.
Pois é, só depois de muito reclamar pra Anatel que a Oi aumentou minha velocidade, mas como minha attainable rate é baixa (por volta de 4000kbps) a minha conexão está oscilando entre 3000 e 3700 kbps, creio que se eu renovasse os cabos eu poderia obter melhores resultados.
Contudo, não tem como eu ir trocar o cabo que vem do poste para minha casa, não é? Eu acho que ele vem direto pra conexão com o modem, se não me engano.
Ele passa direto pela caixinha preta que tem nos postes residenciais?
Aqui em casa a fiação passa direto to pedindo pra eles colocarem essa caixinha...
assim quando você precisa trocar você mesmo pode fazer sem ter que ficar implorando pra operadora fazer.
Os chamados " técnicos " fazem cada gambiarra. Achando que você nunca vai subir no telhado e olhar o que eles fizeram.
Abraço.
Galera...
Hj pela manhã diminui a minha banda larga de 15Mb para 10Mb, para ver se o meu SNR dava uma aumentada...
Agora o meu modem esta assim:
Statistics -- xDSL
Mode: ADSL_2plus
Traffic Type: ATM
Status: Up
Downstream Upstream
SNR Margin (0.1 dB): 19,3 6,0
Attenuation (0.1 dB): 16,0 8,4
Output Power (0.1 dBm): 233 104
Attainable Rate (Kbps): 23,068 1,132
Path 0 Path 1
Rate (Kbps): 12,799 1,099 0 0 0
Por enquanto parece que esta mais estável, mais vou esperar mais um pouco pra ver se a conexão volta a cair...
A minha pergunta agora é: Com base nesses dados qual é o máximo que posso colocar aqui, visto que 15Mb ficou instável demais, eu atingia a velocidade contratada mais com muita instabilidade.
Quanto realmente é o meu limite...
Abraço.
Amigos, bom dia!
Estou com a seguinte dúvida: Tenho um oi velox de 10mb, mas não estou recebendo o fluxo total. Seguem os dados do modem-roteador (um TP-LINK TD-8901G):
ADSL Firmware Version: FwVer:3.11.2.175_TC3086 HwVer:T14.F7_5.0
Line State: Showtime
Modulation: ADSL2 PLUS
Annex Mode: ANNEX_A
Downstream Upstream
SNR Margin: 23.0 21.5 db
Line Attenuation: 11.8 7.8 db
Data Rate: 11294 573 kbps
Max Rate: 24888 1040 kbps
POWER: 19.7 11.3 dbm
CRC: 0 0
Por esses dados, realmente a localidade suporta 10mb?
Obs.: Fiz um cabo de telefone, usando cabo de rede com 2 pares, para ver se melhora mais ainda o sinal.
Grato desde já!
Amigos, bom dia!
Annex Mode: ANNEX_A
Downstream Upstream
CRC: 0 0
Grato desde já!
Eu diria que aguenta até uns 15 ou mesmo 20 mega. SNR 23 com 10 mega e atenuação baixíssima... Com 15 mega deve cair pra uns 14 - 17 (só um chute, o pessoal mais experiente deve saber ao certo). Mantendo o SNR acima de 10 - 12 e atenuação abaixo de 35 - 40 é certeza de net boa.
Tenho Oi Velox de 4mb e de uma semana para cá minha internet cai a toda hora. Não sei se é problema do meu sinal ADSL ou se meu modem/router linksys wag200 já está entregando os pontos. Também a algum dias atrás tentei mudar a velocidade para 10mb, mas fui informado que minha linha não era qualificada.
Segue os dados do meu sinal DSL para análise.
Status de DSL: Conectado
Modo de modulação de DSL: ADSL2+ AnnexM
Modo de caminho de DSL: Intercalado
Taxa de downstream: 5661 kbps
Taxa de upstream: 572 kbps
Margem de downstream: 15 db
Margem de upstream: 33 db
Atenuação de linha de downstream: 35 db
Atenuação de linha de upstream: 9.5 db
Potência de transmissão de downstream: 15 db
Potência de transmissão de upstream: 22db
Fica no aguardo da análise. Valeu!!!
Desculpem eu postar completamente fora de lugar, mas não consigo postar na érea correta (nem responder a qualquer tópico e nem abrir um novo), o fórum não está deixando.
Eu tentei há pouco alterar meu email (mudei de endereço de email e o estou alterando em todos os lugares) e recebi a mensagem de que o administrador teria banido meu email!!
Como a própria mensagem dizia que no caso de digitação errada apareceria a mesma mensagem, achei que fosse isso -- retornei à página, redigitei e novamente deu o mesmo erro.
Não há dúvida alguma de que o endereço está correto, e ele simplesmente não poderia ter sido banido -- pois além de ser novo (recém-criado), nunca o usei neste fórum (obviamente).
Ao tentar abrir um novo tópico na área correta, onde se relatam os problemas, recebi a mensagem abaixo:
Lithos, você não tem permissão para acessar essa página. Isso pode ser causado por algumas das seguintes razões:
Sua conta de usuário talvez não tenha privilégios para acessar essa página. Você está tentando editar o post de alguém, acesso administrativo ou algum outro tipo de privilégio?
Se você está tentando postar, o administrador talvez desabilitou sua conta, ou precisa de ativação.
A MESMA mensagem aparece se tento responder a qualquer tópico lá.
Fico de mãos atadas, sem ter como fazer. Como venho muito pouco aqui estou meio perdido: não conheço moderadores nem a quem contatar.
Se alguém puder, por favor me dê uma ajuda (deem o link do post pra algum administrador/moderador, qualquer coisa).
Muito grato desde já.
Pessoal, Bom dia!
tenho uma lan aqui, e uso uma net Oi de 10Mb, e percebi que quando começa a lotar , tenho 20 maquinas, o msn começa cai muitooo, jogos online caem, e fica nessa. E to achando que porque 10mb para 20 maquinas ja ta no limite e fica puxando muita banda e acontece isso. Como eu não entendo muito, o que eu falei esta correto? Ou é 'defeito' na minha rede, caso existe alguma solução para não acontecer essas quedas? Aqui uso somente uma switch simples de 24 portas e o router adsl é o 2640B configurado para PPPoE.
Esse aqui é minha statistics do adsl, vocês sabem se estão normais os sinais ?
olhando pela imagem, da para aumentar para 20MB aqui numa boa?
e pessoal, o que é esse Output Power (dBm) ? teve uma hora aqui que ele ficou -25, maioria das vezes fica 0.0 ou 0.9, e as vezes dá 25 , estranho. o que ser? Print embaixo
Pessoal, minha net da OI 2mb anda oscilando bastante, num cai cai que só vendo, gostária que vocês (que entendem do riscado) dessem uma avaliada nos dados e ver se ta tudo "certo" ou tenho que fazer algo (chamar tecnico, trocar cabos, etc), e até quantos megas vai.
Mode: ADSL2
Type: Interleave
Status: No Defect
Downstream / Upstream
SNR Margin (dB): 11.2 / 17.5
Attenuation (dB): 31.0 / 15.7
Output Power (dBm): 1.0 / 12.6
Attainable Rate (Kbps): 4076 / 656
Rate (Kbps): 2272 / 568
