Como Fazer Um Overclock em minha Maquina
tacobr
Ola Pessoal gostaria de saber como posso fazer overclock na minha maquina
Placa-mãe: Intel DP35DP
Processador: Intel Core 2 Quad 2.3 Ghz
Memoria: 3 GB (667 Mhz)
Sistema: windows XP*32 bits SP3
HD: 160 GB
Placa de Video:XFX GeForce 9600 GT 512 MB DDR3
Desde já Muito Grato:lol:
Configuração completa
usando o CPU-Z
Processors Information
Processor 1 ID = 0
Number of cores 4 (max 4)
Number of threads 4 (max 4)
Name Intel Core 2 Quad Q6600
Codename Kentsfield
Specification Intel® Core2 Quad CPU Q6600 @ 2.40GHz
Package (platform ID) Socket 775 LGA (0x4)
CPUID 6.F.B
Extended CPUID 6.F
Core Stepping G0
Technology 65 nm
Core Speed 1600.3 MHz
Multiplier x FSB 6.0 x 266.7 MHz
Rated Bus speed 1066.9 MHz
Stock frequency 2400 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 2 x 4096 KBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
FID range 6.0x - 9.0x
Max VID 1.225 V
Chipset
Northbridge Intel P35/G33/G31 rev. A2
Southbridge Intel 82801IR (ICH9R) rev. 02
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR2
Memory Size 3072 MBytes
Channels Dual, (Symmetric)
Memory Frequency 333.4 MHz (4:5)
CAS# latency (CL) 5.0
RAS# to CAS# delay (tRCD) 5
RAS# Precharge (tRP) 5
Cycle Time (tRAS) 15
Row Refresh Cycle Time (tRFC) 36
Command Rate (CR) 2T
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR2
Module format Regular UDIMM
Manufacturer (ID) (0000000000000000)
Size 1024 MBytes
Max bandwidth PC2-5300 (333 MHz)
Part number NETGATE-BA 01/2008
Serial number FFFFFFFF
Manufacturing date Week 165/Year 165n
Number of banks 2
Data width 64 bits
Correction None
Nominal Voltage 1.80 Volts
EPP no
XMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 3.0-3-3-9-12 @ 200 MHz
JEDEC #2 4.0-4-4-12-16 @ 266 MHz
JEDEC #3 5.0-5-5-15-20 @ 333 MHz
DMI
DMI Processor
manufacturer Intel® Corporation
model Intel® Core2 Quad CPU Q6600 @ 2.40GHz
clock speed 2400.0 MHz
FSB speed 266.0 MHz
multiplier 9.0x
DMI BIOS
vendor Intel Corp.
version DPP3510J.86A.0572.2009.0715.2346
date 07/15/2009
DMI System Information
manufacturer unknown
product unknown
version unknown
serial unknown
UUID 162E26B0-A82211DC-ADFF0013-D4D9C938
DMI Baseboard
vendor Intel Corporation
model DP35DP
revision AAD81073-207
serial USDP74900B65
DMI System Enclosure
chassis type Desktop
chassis serial unknown
DMI Port Connector
designation PRIMARY (internal)
connector On Board IDE
DMI Port Connector
designation SECONDARY (internal)
DMI Port Connector
designation ATX_PWR (internal)
DMI Extension Slot
designation PCIE X16 SLOT
type A5
populated yes
DMI Extension Slot
designation PCIE X1 SLOT 1
type A5
populated no
DMI Extension Slot
designation PCIE X1 SLOT 2
type A5
populated no
DMI Extension Slot
designation PCIE X1 SLOT 3
type A5
populated no
DMI Extension Slot
designation PCI SLOT 1
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI SLOT 2
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI SLOT 3
type PCI
width 32 bits
populated no
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 8192 MBytes
max# of devices 4
DMI Memory Device
designation J6H1
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 1024 MBytes
DMI Memory Device
designation J6H2
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 1024 MBytes
DMI Memory Device
designation J6J1
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 1024 MBytes
DMI Memory Device
designation J6J2
format DIMM
type unknown
Display Adapters
Display adapter 0
Manuf. API index 0
Display name \\.\DISPLAY1
Name NVIDIA GeForce 9600 GT
Revision A1
Codename G94
Technology 65 nm
Memory size 512 MB
Memory type GDDR3
Memory bus width 256 bits
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x10DE (0x1682)
Model ID 0x622 (0x2362)
Performance Level 3D Applications
Core clock 650.0 MHz
Shader clock 1625.0 MHz
Memory clock 900.0 MHz
Software
Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600)
DirectX Version 9.0c
Curso de Hacker Ético
CLIQUE AQUI E CONFIRA!
* Este curso não é ministrado pela equipe do Clube do Hardware.
