Review placa M4A785TD-V EVO e questões tecnicas
Bom acabou de chegar a minha mobo M4A785TD-V EVO e gostaria de criar esse tópico para sanar dúvidas, postagem de problemas e opiniões sobre essa placa mãe!
Vamos aos detalhes dessa placa:
M4A785TD-V EVO
CPU
AMD Socket AM3 ;Phenom™II /Athlon™II /Sempron™ 100 Series Processors
AMD Cool 'n' Quiet™ Technology
Supports 45nm CPU
Chipset
AMD 785G/SB710
System Bus
Up to 5200 MT/s HyperTransport™ 3.0
Memory
4 x DIMM, Max. 16 GB, DDR3 1800(O.C.)*/1600(O.C.)/1333/1066/800 ECC,Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*Due to OS limitation, when installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Install a 64-bit WindowsWindows® OS when you want to install 4GB or more memory on the motherboard.
Expansion Slots
2 x PCIe 2.0 x16 (blue @ x16 mode,gray @ x4 mode)
1 x PCIe x1
3 x PCI
Multi-GPU Support
ATI® CrossFireX™ Technology
VGA Integrated ATI Radeon™ HD 4200 GPU
SidePort Memory - onboard 128MB DDR3 1333 memory
- Supports HDMI™ Technology with max. resolution up to 1920 x 1200 (1080P)
- Supports Dual-link DVI with max. resolution up to 2560x1600 @60Hz
- Supports D-Sub with max. resolution up to 2048x1536 @85Hz
- Hybrid CrossFireX™ Support
- Dual independent displays support with HDMI / DVI and D-Sub
- Supports Microsoft® DirectX 10.1, OpenGL 2.0, Shader Model 4.1
- Hardware Decode Acceleration for H.264,você-1, and MPEG-2
- Maximum shared memory of 512MB
Storage
SB710 Chipset
1 xUltraDMA 133/100/66 for up to 2 PATA devices
5 xSATA 3 Gb/s ports Support RAID 0,1,10,JBOD
1 x eSATA 3Gb/s port
LAN
RTL8112L Gigabit LAN controller featuring AI NET 2
Audio
VT1708S 8-Channel High Definition Audio CODEC
- Supports Jack-Detection, Multi-Streaming, and Front Panel Jack-Retasking
- Optical S/PDIF Out ports at back I/O
IEEE 1394 VT6308P controller supports 2 x 1394a ports (1 at mid-board; 1 at back panel)
USB 12 USB 2.0/1.1 ports (6 ports at mid-board, 6 ports at back panel)
ASUS Unique Features
ASUS Power Solutions:
- 8+2 Phase Power Design
ASUS Green Design:
- EPU
Express Gate
ASUS Quiet Thermal Solution:
- ASUS Fanless Design: Stylish heat sink solution
- ASUS Q-Fan
ASUS EZ DIY:
- ASUS CrashFree BIOS 3
- ASUS MyLogo 2
- ASUS EZ Flash 2
Overclocking Features
Intelligent overclocking tools
- Turbo V
- GPU NOS (*GPU NOS does not take effect under Hybrid CrossFireX mode.)
- Turbo Key
SFS (Stepless Frequency Selection)
- FSB tuning from 200MHz up to 550MHz at 1MHz increment
- PCI Express frequency tuning from 100MHz up to 150MHz at 1MHz increment
Overclocking Protection
- ASUS C.P.R.(CPU Parameter Recall)
Special Features
100% All High-quality Conductive Polymer Capacitors
AMD OverDrive Support*
*Advanced cooling system is required when advanced overclock functions of AMD OverDrive are enabled.
Back Panel I/O Ports
1 x PS/2 Keyboard/Mouse Combo port
1 x DVI
1 x D-Sub
1 x HDMI
1 x External SATA
1 x S/PDIF Out (Optical)
1 x IEEE 1394a
1 x LAN(RJ45) port
6 x USB 2.0/1.1
8 -Channel Audio I/O
Internal I/O Connectors
3 x USB connectors (6 ports)
1 x COM connector
1 x IDE connector
5 x SATA connectors
1 x CPU Fan connector
1 x Chassis Fan connectors
1 x Power Fan connector
Front panel audio connector
1 x IEEE 1394a connector
1 x S/PDIF Out Header
1x LPT connector
24-pin ATX Power connector
4-pin ATX 12V Power connector
System Panel
BIOS
8 Mb Flash ROM AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.3, ACPI 2.0a, ASUS EZ Flash 2, ASUS CrashFree BIOS 3
Manageability
WOL by PME,WOR by PME,WOR by Ring,PXE
Accessories
User's manual
1 x I/O Shield
1 x UltraDMA 133/100/66 cable
4 x SATA cable(s)
1 x Q-Connector
Support Disc
ASUS PC Probe II
Express Gate
Anti-virus software (OEM version)
ASUS Update
AMD OverDrive Utility (AOD)
Form Factor ATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )
Componentes instalados (no dia do teste):
processador: AMD Athlon II X2 240 2.8Ghz
Memória: DDR3 1Gb Markvision 1333Mhz CL9
HD: Maxtor 160Gb 8Mb Buffer
Placa de video: ATI 4850 1Gb GDDR3
Fonte: C3 Tech DSA 5060V
Drive de CD/DVD: LG GSA H55N
Gabinete: Satellite 580K Black
Farei aqui um teste básico de overclock com essa placa mãe para ver o potencial dela e qual a temperatura que ela chega!!
Mais antes vamos dar uma olhada na construção e layout dessa placa?
Vemos nessa imagem o painel traseiro dessa placa que é repleto de recursos e conectores como HDMI, DVI e RGB (saidas de video) e 8 canais de audio analógico + uma porta de audio Digital que é chamada de SPDIF, 6 postas USB (com suporte a mais 6 internamente), uma porta PS2 para um teclado ou um mouse sendo disponivel assim usar o outro somente por via USB, uma porta RJ 45 para conexão de cabo de rede, uma porta eSata para conectar HD externo e uma porta IEEE 1394, completando esse magnifico painel traseiro repleto de conetores!!
Agora vamos no conteudo da placa olhando a fundo essa placa tem também varios recursos entre eles 10 fases de energia na linha do processador sendo dividido 8 para o processador e 2 para as memórias fazendo o sistema de 8+2 fases, temos também todos os capacitores sólidos que aumenta a vida da placa e ajuda a reduzir o calor gerado por ela, muitas pessoas e alguns Reviews condenam a posição das portas SATA que fica quase na mesma linha do Slot PCI-E 16x atrapalhando assim a conexão dos cabos quando é usada uma placa de video TOP que tenha um tamanho estendido, mas se observarmos bem as portas SATAS estão acima da linha do PCI-E 16x sendo de fácil instalação os cabos Sata, o único ponto que na minha opinião foi mal projetado foi a posição da porta IDE que é na parte inferior da placa e os periféricos como grav. de DVD sempre ficam na parte superior da placa e tendo uma placa de video grande dificulta a posição do cabo IDE que fica expremido entre a placa de video e o HD quando se tem um HD posicionado na parte inferior do gabinete, e falando de porta IDE essa placa como só tem uma porta só é posivel instalar 2 periféricos nessa porta como dois leitores óticos ou um leitor ótico e um HD ou dois HD's periféricos a mais terão que ser padrões SATA
OBS: Essa placa suporta a CrossfireX da seguinte forma, geralmente o CrossfireX funciona com cada slot a no minimo 8x e essa placa funciona com o slot azul em 16X e o cinza a 4x podendo comprometer o desempenho da placa instalada no slot PCI-E Cinza que funciona a 4X em cerca de 8%!!
Aqui um teste na pratica do amigo Fabio que fez CrossfireX com Duas ATI HD5770, exelentes resultados!!
Obrigado Fabio!!
http://forum.clubedohardware.com.br/showpost.php?p=4535086&postcount=3096
Overclock
Amigos(as) para o momento só posso fazer um teste que é no Athlon II X2 240 que é o único processador que tenho em mãos, atualizando, conseguimos um Athlon II X3 425 que ativando a função Advanced Clock Calibration ou famoso ACC obtivemos um ótimo resultado!!
Teste Overclock a 3.4Ghz!
http://forum.clubedohardware.com.br/showpost.php?p=4068906&postcount=96
Obs: problema contido nesse post ja foi corrigido!
Teste Overclock a 3.5Ghz
Teste overclock a 3.6Ghz
http://forum.clubedohardware.com.br/showpost.php?p=4092673&postcount=175
Teste overclock a 3.7
http://forum.clubedohardware.com.br/showpost.php?p=4147043&postcount=463
Em relação a memória, os overclock's fora feitos em 1333Mhz com latencias de 9-9-9-22 1T e que agora consegui colocar a 1376Mhz com 8-8-8-20 1T o que ja obteve melhora!
Temos aqui um over pelo nosso amigo Jonny.br em suas memórias G.Skill Eco, que é simplesmente magnifico mostrando o ganho em cada frequencia e latencia!!
Obrigado Jonny.br pela colaboração!!!
http://forum.clubedohardware.com.br/showpost.php?p=4488628&postcount=2740
E acima temos uma foto da Bios com o Processador Athlon II X3 425 que se transformou em Phenom II X4 B25, com a função ACC ativado na opção ALL CORES e Unleashing mode também ativado na opção 4 cores Operation, abaixo temos um teste de estabilidade do processador com o 4° núcleo desbloqueado!!!
http://forum.clubedohardware.com.br/showpost.php?p=4157227&postcount=582
Agora faremos alguns testes com o video onboard dessa placa o ATI HD4200!!
Teste com o video Onboard no Jogo Call Of Duty Word At War
http://forum.clubedohardware.com.br/showpost.php?p=4054064&postcount=16
Teste com o video Onboard no jogo Half Life2 Episode 1
http://forum.clubedohardware.com.br/showpost.php?p=4055566&postcount=30
Teste com o video Onboard no jogo Need For Speed Undercover e over no video Onboard!
http://forum.clubedohardware.com.br/showpost.php?p=4055769&postcount=38
Todos realizados por mim!!
Alguns Reviews
Bit-Tech.net
TrustedReviews
Overclock 3D
IXBTLabs
Qualquer dúvida estamos ae ^^!
Amigo Nascarbr uma diferença que voce postou não existe, pois nenhuma das duas placas tanto a "V EVO" quanto a "M EVO" possui suporte a Cross Firex
Amigos um milagre de por ACC no SB 700 foi feito pela Biostar, vou procurar saber o modelo e posto aqui!!
Amigo Burning o desempenho dessa placa mãe com o video onboard eu não sei pois o teste que fiz foi com a minha 4850 instalada, mas creio que ela tenha um desempenho muito bom com o video onboard sim, inclusive ela tem uma facilidade para overclockar o video on com o GPU NOS que chegando a 700Mhz consegue ser exepcionalmente excelente para um video onboard!!
Amigo Jonny, realmente veio o SB 750 pois o CPU-Z é atualizado e o Everest tambem, pois ambos programas ja reconhecem o soquet como AM3 e o SB710 foi lançado antes do soquet AM3!
  • Moderador
Tem razão. Quero saber sobre a M EVO, pois pretendo fazer a seguinte troca de Combo:
Sai: M3A78 / Athlon X2 4800 / 2Gb DDR2 800 / 8600GT
Entra: M4A785TD-M EVO / Athlon II X2 240 / 2Gb DDR3 1333
Claro que a falta de VGA é temporária. Pretendo pegar uma 4770 ou 5770.
Vou dar minha pequena contribuição aqui também.
Bom, sou iniciante no quesito overclock, e ando meio sem tempo para ler e aprender.
Já peço desculpas ao Ramon, pois não deu tempo de fazer testes(nem de aprender) como eu havia lhe falado.
Para jogos, testei alguns, como Batman AA, Mirror's Edge, Call Of Juarez Bount In Blood, Borderlands, Devil May Cry 4, testei Prototype também mas aqui dizia que o modelo não era suportado, só consegui jogar quando chegou a minha placa de video. Quanto a esses jogos, só o Call Of Juarez ficou difícil de jogar mesmo nas mais baixas configurações, os outros rodaram bem, batman no low, Mirror's Edge mid/high, Borderlands low, DMC4 low.
Quanto ao over, ainda não tive tempo, assim que tiver eu posto aqui.
Ah, aqui tanto no CPU-Z e no Everest também mostram SB750(CPU-Z 1.53 - Everest 5.30)
Boa tarde pessoal,
Tudo bom?
Estou penando para conseguir fazer funcionar nessa placa-mãe minhas memórias DDR3-1333 (7-7-7-20) @1.65v OCZ Platinum LowVoltage.
Tudo está em "stock" e as memórias estão setadas manualmente conforme as especificações citadas anteriormente.
O problema é que só consegui "estabilizar" (entre aspas pois apresenta erro ao rodar o Prime95 em Blend Mode) o sistema utilizando 1.8v nas memórias. Mais acredito que isso possa danificar as mesmas com o tempo, não?
Atualmente estou utilizando as memórias em 1066 (6-6-6-15) @1.65v, pois apesar de ter apertado os timmings consegui manter a tensão no recomendado pelo fabricante.
Alguém tem essas memórias instaladas nessa placa-mãe?
Muito obrigado pela ajuda.
[]'s
Bom amigo memórias de baixa tensão (low-voltage) tem que verificar se ela é oficilmente aprovada para rodar nessa placa, pois não é qualquer placa mãe que roda bem com esses tipos de memórias, tenta deixar tudo em AUTO e aumenta a tensão para 1.8 que é tensão normal de um pente de memória para ver se ela não funciona!
Olá Amigo Ramon Neves!Gostária de 2 favores seus!
o primeiro seria me passar a loja onde foi compra e o preço pois já vi lojas onde ela estava por 320 porém estão esgotadas e só se encontra por 399!!
o segundo é se você consegue rodar o GTA IV no video on board!
vi videos do youtube que conseguiram rodar com o seu video on e seu processador!
avor teste!agradeço!
Bom Amigos fiz um pequeno teste no video onboard com o jogo Call Of Duty Word at War nas configurações graficas assim:
Resolução: 800x600
Anti Alising: off
Filtering Anisotropic: 16X
e demais opções desligadas
em stock:
FPS: 18
Fiz um pequeno over de 500Mhz (que é o clock original) para 606Mhz!
E obtive um pouco mais de Frames Por Segundo(FPS)
Forçando mais um pouco conseguimos colocar a 702Mhz, se tornando assim o melhor video onboard do momento, HD4200 a 700Mhz!
No jogo conseguimos um pouco mais de desempenho, rompendo a barreira dos 30FPS em campo aberto no jogo!
Agora amigo rubens99_9 eu comprei essa placa fora do nosso país e saiu para mim no valor de R$175, agora infelizmente não vou poder testar o GTA IV por que não tenho esse jogo aqui, agora tentei instalar o Crisys Warhead mais por falta de memória instalada ele não rodou!! agora tenho os jogos Half Life todos do segundo episódio, Call of Duty 4, Mass Efect, NFS undecover o que os amigos quizerem eu testo mais só pode ser um desses jogos que mencionei acima ok?
Montei um PC com essa placa hoje.
Estou com HD4870, Phenon X3 720 e 2x2GB Kingston 1333 DDR3.
Só que esta travando quando tento colocar os dois pentes de memoria.
Com um vai beleza, mas quando tento com 2, ja tentei com e sem dual channel e continua travando.
Alguem tem uma ideia do que pode estar ocorrendo ?
A placa realmente é excelente e tem vairas conexões. Comprei na Santa Efigenia.
Bom dia Pessoal,
Posso dizer que essa placa é bem interessante...
Minha configuração
Asus MA4785TD-v Evo
Phenom II X3 720
Cooler IceAge Prima Boss
2x 2GB DDR3-1333 OCZ (7-7-7-20) @1.65v
HD 1TB Seagate 7200.12
Gabinete Gladiator 600
Fonte Corsair 550vx
Ventilação (Entrando: 140mm + 2x 120mm || Saindo: 3x 120mm)
Testes até o momento...
Estou usando o Prime95 em modo Blend para testar a estabilidade.
- As memórias em 1333 não funcionam com a tensão original e colocando em 1.8v apresentam erro no Prime95.
- Usando as memórias como 1066, apertei os timmings para 6-6-6-15 @ 1.65v e funciona normal.
- Por um tempo utilizei o ACC para desbloquear o 4º núcleo e funcionou normal, assim que resolver o problema das memórias em 1333 ou quem sabe em 1600... volto a testar com o 4º núcleo ativo.
- Subi o clock no NB (NorthBridge) de 2000 (padrão) para 2600 @ 1.35v e funcionou normal e isso gerou uma queda na latencia das memórias de 54ms para 44ms... :lol:
- Existem muitas configurações diferentes utilizadas pelos usuários dos foruns (brasil, portugual e coisas que o google encontra...rs). O interessante é que essa plataforma permite diferentes focos em performance e isso é muito bom.
Fotos e informações mais detalhadas estão sendo escritas nesse "artigo"...
http://www.forumpcs.com.br/viewtopic.php?t=261612
[]'s e vamos tentar nos ajudar a configurar as mais diferentes coisas que essa placa oferece...
  • Moderador
Quem me dera se fosse tão fácil assim!! rsrsrs
Mas calma vou postar mais jogos, e galera o meu X3 720 ta chegando para postar o famoso teste de desbloqueio do 4 núcleo, espero que esse núcleo esteja perfeito!!
O que fará com o Athlon II X2 240, quando chegar o X3 720?
Bom dia Graziani,
Algumas informações importantes:
- O manual da placa está errado, pois para funcionar em dual channel você deve colocar os pentes preferencialmente nos slots pretos.
- Na bios tem um menu de memórias onde você define a forma de funcionamento, deixe como "ungadged = always".
- Você configurou as memórias (timmings e tensão) na mão? Faça isso, pois assim garante que estão funcionando corretamente.
- Se conseguir chegar no windows, instale o Prime95 para testar a estabilidade e o CPU-Z para verificar se as configurações que você colocou na BIOS estão realmente funcionando.
- É bastante importante gravar um cd com o MemTest+ v4.0 ou superior e deixar ele testando suas memórias. Para isso, lembre de definir na BIOS que o boot deve ser feito pelo cd-rom e deixe o teste rodando por umas 3 horas...
[]'s
Bom dia Graziani,
[]'s
Oi Playmobil,
Super obrigado pela ajuda.Hoje de manhã, coloquei as memorias nos bancos e sem alterar nada esta funcionando sem travar até o momento. Pode ser a temperatura ?. Estou usando o Windows 7 32 bits.
Tem algum setup especial que eu posso / devo fazer na placa ? Estou usando tudo default. Posso te mandar por MP o resultado do arquivo do CPU-Z sobre as memorias ? Não sei setar manualmente.
Muito obrigado mesmo, mais uma vez
