Qual note devo comprar?
Buz
Pessoal me ajude!!! Preciso comprar um note mas não sei qual é melhor...
Tenho as seguintes opções
Toshiba
Satellite A200-ST2043
CPU: Intel® Core™2 Duo Processor T7700 (2.4GHz, 4MB L2 cache, 800MHz FSB)
Operating System: Genuine Windows Vista® Home Basic 32-Bit
Office Software: Microsoft® Office 2007 Suite Ready
Memory: 2048MB PC5300 DDR2 667MHz SDRAM (1024MBx2)
LCD: 15.4" Diagonal Widescreen XGA TruBrite® display with High Brightness (1280x800)
Graphics Controller: ATI Mobility Radeon™ HD 2600 with 256MB GDDR2 discrete memory
+ up to 255MB allocated shared graphics memory using ATI HyperMemory™ technology
HDD: 160GB HDD (5400rpm, Serial-ATA)
Optical Media: HD DVD-ROM/DVD SuperMulti (+/- double layer) drive (in one optical drive), supporting 12 formats
Mini-PCI/WiFi: Intel® Wireless WiFi Link 4965 AGN (802.11a/g/n)
Bluetooth: Bluetooth® Version 2.0 +EDR
Speaker: harman/kardon® stereo speakers
USD 1.714,00
Toshiba
Tecra A9-ST9002
CPU: Intel® Core™2 Duo* Processor T7700 (2.40GHz, 4MB L2 Cache, 800MHz FSB)
Operating System: Genuine Windows Vista™ Business 32-bit
Office Software: Microsoft® Office Ready Suite 2007 (60-day trial)
LCD: 15.4" Diagonal Widescreen SXGA+ display (1680x1050)
Graphics Controller: nVIDIA® Quadro® NVS 130M with 256MB DDR SDRAM
Optical Media: DVD SuperMulti (+/-R double layer) drive
Mini-PCI/WiFi: Intel® Wireless WiFi Link 4965AGN (802.11a/g/n)
Standard Warranty: 1 Year Standard Limited Warranty
USD 1.954,00
Asus
F3Sv-C1
Intel Core 2 Duo Processors T7700 (2.40 GHz)
2048MB DDR2 667MHz (1GB x 2)+ 1GB Intel Turbo Memory
15.4" WSXGA+ (1680 x 1050)
NVIDIA GeForce G8600M GS built-in 256MB VRAM w/ DirectX 10 support
1.3 Megapixel webcam with 240 degree swivel and LED lighting
8x Super-Multi DVDRW Dual Layer with Light Scribe
160GB 5400RPM SATA
8-in-1 card reader (MMC/SD/Mini-SD/XD/Memory Stick/MS Pro/MS Duo/MS Pro Duo)
Wireless 802.11 A/B/G/N
Bluetooth V2.0 + EDR
10/100/1000, Fax Modem
BIOS Booting / HDD User Password Protection and security lock
Kensington lock hole
Trusted Platform Module
Built-in FingerPrint
Built-in Intel High Definition audio compliant audio chip
SoundBlaster Pro Compatible
Built-in stereo speakers (1.5W)
Li-ion 6-cell/4 hrs
14.2" x 10.5" x 1.1"-1.6"
6.5 lbs
Microsoft Windows Vista Home Premium
2 - Standard 2 Year Global Warranty
USD 1.549,00
Lembrando....
Toshiba tem Global Warranty no Brasil - Mas pra isso o note precisa ter Darf, ou seja, temos q pagar os impostos.
Asus não tem Global Warranty no Brasil - Se der algum pau tem que mandar pros EUA.
valeu
Eu tava pensando em ficar com o Asus por causa da resolução.
Se bem que o Toshiba tem HD-DVD.....
mas sinceramente num sei viu...
Das placas de vídeo qual a melhor?
E de marca Asus é boa num é?
cara a placa de video melhor e a da ati hd 2600, e um pouco melhor que essa 8600m GS !! Se fosse a GT seria melhor que a hd 2600!!
toshiba Tecra A9-ST9002
melhor placa de video.
ja é patamar profissional, contra as outras q você sitou pra uso domesstico.
tipo placa pra workstation mobile.
[]´s
