Macro para abrir,alterar cabeçalho e rodapé, proteger, salvar e sair dos vários arquivos doc e docx na pasta/subpastas. ERRO LOOP?
cmalves
Boa tarde
Fiz uma macro no word e fui aperfeiçoando com ajuda de foruns na internet. Então encontrei uma macro que faz LOOP (http://www.biblesupport.com/topic/1633-running-a-macro-on-all-files-in-a-folder/). Mas não consegui adaptar na minha. Gostaria que algum colega expert me ajudasse nesta demanda.
Obs: Sou leigo em VBA, se possível me informar a solução completa.
Estou enviando também o anexo
Tenham um excelente fim de semana
Grato a Todos
Clovis
Sub DoLangesNow()
Dim file
Dim path As String
' Path to your folder. MY folder is listed below. I bet yours is different.
' make SURE you include the terminating "\"
'YOU MUST EDIT THIS.
path = "C:\CLOVIS\"
'Change this file extension to the file you are opening. .htm is listed below. You may have rtf or docx.
file = Dir(path & "*.doc")
Do While file <> ""
Documents.Open FileName:=path & file
' This is the call to the macro you want to run on each file the folder
'YOU MUST EDIT THIS. lange01 is my macro name. You put yours here.
Call Macro4
' Saves the file
If ActiveDocument.Saved = False Then ActiveDocument.Save
Application.Quit SaveChanges:=wdPromptToSaveChanges
' set file to next in Dir
file = Dir()
Loop
End Sub
Sub Padronizacao()
       If ActiveWindow.View.SplitSpecial <> wdPaneNone Then
        ActiveWindow.Panes(2).Close
    End If
    If ActiveWindow.ActivePane.View.Type = wdNormalView Or ActiveWindow. _
        ActivePane.View.Type = wdOutlineView Then
        ActiveWindow.ActivePane.View.Type = wdPrintView
    End If
    ActiveWindow.ActivePane.View.SeekView = wdSeekCurrentPageHeader
        Selection.Find.ClearFormatting
    Selection.Find.Replacement.ClearFormatting
With Selection.Find
        .Text = "LOJA MODELO"
        .Replacement.Text = "LOJA DALAS"
.Forward = True
        .Wrap = wdFindContinue
        .Format = False
        .MatchCase = False
        .MatchWholeWord = False
        .MatchWildcards = False
        .MatchSoundsLike = False
        .MatchAllWordForms = False
    End With
    Selection.Find.Execute Replace:=wdReplaceAll
    ActiveWindow.ActivePane.View.SeekView = wdSeekMainDocument
End Sub
Sub ENDERECO_NEW()
    End If
    End If
    ActiveWindow.ActivePane.View.SeekView = wdSeekCurrentPageFooter
    With Selection.Find '..................................................10
        .Text = "AVENIDA CANADÁ" '11
'2º) DIGITE ENDEREÇO DA NOVA LOJA
        .Replacement.Text = "AVENIDA ESTADOS UNIDOS " '...12
.Forward = True '..............13
        .Wrap = wdFindContinue '.......14
        .Format = False '..............15
        .MatchCase = False '...........16
        .MatchWholeWord = False '......17
        .MatchWildcards = False '......18
        .MatchSoundsLike = False '.....19
        .MatchAllWordForms = False '...20
    End With '...................................................21
        Selection.Find.Execute Replace:=wdReplaceAll '...........22
        ActiveWindow.ActivePane.View.SeekView = wdSeekMainDocument '...........23 adicionado
        End Sub '..............................................................24 adicionado
Sub rodape2()
' rodape2 Macro
' cdfdfd
 ActiveWindow.ActivePane.View.SeekView = wdSeekCurrentPageFooter '......7
    With Selection.Find
        .Text = _
            "Fone:55 (65)1233-5414 - E-mail: virtuas@clovis.gov.br CEP: 78010-200"
'3º) DIGITE TELEFONE E E-MAIL DA NOVA LOJA
        .Replacement.Text = "Fone:55 (65)4747-7895 - E-mail: best@clovis.gov.br"
        .Forward = True
        .Format = False
        .MatchCase = False
    End With
End Sub
Sub Macro4()
Call Padronizacao
Call ENDERECO_NEW
Call rodape2
'ActiveDocument.Protect Password:="123", NoReset:=False, Type:=wdAllowOnlyFormFields
'On Error Resume Next
End Sub
ESLOW.rar
Altere essas duas coisas
Sub DoLangesNow()
Dim file
Dim path As String
path = "C:\CLOVIS\"
Do While file <> ""
Call Macro4
' Saves the file
Application.ActiveDocument.Close SaveChanges:=wdPromptToSaveChanges
file = Dir()
Loop
End Sub
Sub Padronizacao()
    End If
    End If
With Selection.Find
.Forward = True
        .Format = False
        .MatchCase = False
    End With
End Sub
Sub ENDERECO_NEW()
    End If
    End If
Sub rodape2()
' rodape2 Macro
' cdfdfd
    With Selection.Find
        .Text = _
        .Forward = True
        .Format = False
        .MatchCase = False
    End With
End Sub
Sub Macro4()
Call Padronizacao
Call ENDERECO_NEW
Call rodape2
'APAGUE ESSAS DUAS LINHAS EM VERMELHO ABAIXO
End Sub
Bruno
Funcionou perfeitamente o código que você me enviou. Só para finalizar, é possível inserir algum comando para que a macro faça alterações nas SUB-PASTAS também???
Se for possível, será melhor ainda.
Por enquanto
Muito Obrigado
Clovis
Veja se funciona
Sub DoLangesNow()Dim fileDim path As StringDim strFolder As StringDim strSubFolder As StringDim strFile As StringDim colSubFolders As New CollectionDim varItem As Variant     strFolder = "C:\CLOVIS\"     strSubFolder = Dir(strFolder & "*", vbDirectory)     Do While Not strSubFolder = ""         Select Case strSubFolder             Case ".", ".."                              Case Else                  colSubFolders.Add Item:=strSubFolder, Key:=strSubFolder         End Select                  strSubFolder = Dir     Loop         For Each varItem In colSubFolders                      strFile = Dir(strFolder & varItem & "*.doc")         Do While strFile <> ""         Set file = Documents.Open(FileName:=strFolder & _                 varItem & "\" & strFile)         Call Macro4         ActiveDocument.Save         ActiveDocument.Close                  strFile = Dir                  Loop         Next varItem End Sub
Prezado colega
Primeiramente, boa tarde e uma ótima semana para nós.
Desculpe-me ter demorado responder. O problema é que tentei executar em casa no final de semana e quando a executo, a tela somente pisca, mas não executa nenhuma ação. Então tentei aqui no serviço e acontece a mesma coisa, ou seja, a tela dá uma piscada, mas não faz nenhuma ação e nenhum tipo de erro acontece. Será que falta habilitar algo no Word/macro???
Minha versão do Word é 2007.
Continuo agradecendo me desculpando por estar dando um pouco de trabalho.
No aguardo
CLOVIS
Segue script completo
Sub DoLangesNow()
Dim file
Dim path As String
     strFolder = "C:\Users\Desktop\Clovis"
             Case ".", ".."
             Case Else
         End Select
          strSubFolder = Dir
     Loop
         Call Macro4
         ActiveDocument.Save
         strFile = Dir
         Loop
         Next varItem
 End Sub
Sub Padronizacao()
    End If
    End If
With Selection.Find
.Forward = True
        .Format = False
        .MatchCase = False
    End With
End Sub
Sub ENDERECO_NEW()
    End If
    End If
Sub rodape2()
' rodape2 Macro
' cdfdfd
    With Selection.Find
        .Text = _
        .Forward = True
        .Format = False
        .MatchCase = False
    End With
End Sub
Sub Macro4()
Call Padronizacao
Call ENDERECO_NEW
Call rodape2
'If ActiveDocument.Saved = False Then ActiveDocument.Save
'Application.Quit SaveChanges:=wdPromptToSaveChanges
End Sub
Qual seu windows? 7? xp?
tem certeza que a pasta é essa?
pois se for no windows 7 não existe esta pasta.
só para garantir coloque a pasta CLOVIS dentro do C:\ e troque o     strFolder = "C:\Users\Desktop\Clovis"       para
strFolder = "C:\Clovis"
falou.
Sim
Windows7 Professional de 32 bits.
Desculpe!
Corrigindo o que já tinha postado, consigo executar normalmente a macro anterior que faz alterações tanto na pasta "C:\CLOVIS" como na pasta "C:\Users\Desktop\Clovis", automaticamente, ou seja, abre cada documento word, faz as devidas alterações e fecha, isto utilizando o penúltimo código, mas não entra nas sub-pastas.
Já o último código, quando é executado, a tela somente pisca, mas não faz nenhuma  alteração.
Obrigado
Clovis
