Ao executar este código no arduino apresenta error este  expected unqualified-id before 'else'  no  trecho abaixo
imprimir();       }else        {
  #include <LiquidCrystal.h>  LiquidCrystal lcd(12,11,5,4,3,2);  const int  stemp=0,bomba=0,nivel=1,OnOFF=6,red=51,green=52,blue=53,ajuste=7,potenciometro=1,botao=8;  float temperatura,tempmax,tempmin;  int tbomba;  int cont;  void imprimir();  void comparatemp();  void setup()  {   lcd.begin(16,2);   pinMode(bomba,OUTPUT);     pinMode(nivel,INPUT);   digitalWrite(nivel,HIGH);     pinMode(OnOFF,INPUT);   digitalWrite(OnOFF,HIGH);     pinMode(botao,INPUT);   digitalWrite(botao,HIGH);     pinMode(ajuste,INPUT);   digitalWrite(ajuste,HIGH);     tempmax=tempmin=analogRead(stemp)*100*0.0049;   cont=0;   analogWrite(green,0);   analogWrite(red,200);   analogWrite(blue,0);   tbomba=10000;  }  void loop()  {   if(digitalRead(OnOFF)==LOW)   {   while(digitalRead(ajuste)==LOW)   tbomba=int((analogRead(potenciometro)*10000)/1024);   lcd.clear();   lcd.setCursor(0,0);   lcd.print("T. Bomba::");   lcd.print(int(tbomba/1000));   lcd.print("s");     }   temperatura=analogRead(stemp)*100*0.0049;   comparatemp();     if((temperatura>27)&&(digitalRead(nivel)==LOW))   {   cont++;   analogWrite(green,200);   analogWrite(red,0);   analogWrite(blue,0);   digitalWrite(bomba,HIGH);   delay(tbomba/2);   analogWrite(green,0);   analogWrite(red,0);   analogWrite(blue,200);   delay(tbomba/2);   analogWrite(green,0);   analogWrite(red,200);   analogWrite(blue,0);   digitalWrite(bomba,HIGH);   digitalWrite(bomba,LOW);   }   if((digitalRead(nivel)==LOW)&&(digitalRead(botao)==LOW))   {   cont++;   analogWrite(green,200);   analogWrite(red,0);   analogWrite(blue,0);   digitalWrite(bomba,HIGH);   delay(tbomba/2);   analogWrite(green,0);   analogWrite(red,0);   analogWrite(blue,200);   delay(tbomba/2);   analogWrite(green,0);   analogWrite(red,200);   analogWrite(blue,0);   digitalWrite(bomba,HIGH);   digitalWrite(bomba,LOW);   }   imprimir();       }else        {   lcd.clear();   cont=0;   tbomba=10000;   tempmax=tempmin=analogRead(stemp)*100*0.049;   analogWrite(green,0);   analogWrite(red,200);   analogWrite(blue,0);   digitalWrite(bomba,LOW);   }  }  void imprimir()  {   lcd.clear();   lcd.setCursor(0,0);   lcd.print("MAX:");   lcd.print(tempmax);   lcd.print(" B:");   lcd.print(cont);   lcd.setCursor(0,1);   lcd.print("MIN:");   lcd.print(tempmin);    }  void comparatemp()  {   if(temperatura>tempmax)   {   tempmax=temperatura;   }   if(temperatura<tempmin)   {   tempmin=temperatura;   }  }
  • 4 anos depois...
Estou com esse erro também....
  digitalWrite(Alerta, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);                       // wait for a second
  digitalWrite(Alerta, LOW);    // turn the LED off by making the voltage LOW
  else if (state == 'x') {   // Se o estado recebido for igual a 'x', o Alerta apaga.
  digitalWrite(Ftraseiro, LOW);
  else if (state == 'V') {  // Se o estado recebido for iguala 'V', aciona a buzina.
    if (j == 0) {
      tone(buzzer, 1000);
      j = 1;
    else if (j == 1) {
      noTone(buzzer);
      j = 0;
    state = 'n';
adicionado 0 minutos depois
O erro esta na linha Buzzer
