O que é e como corrigir DEFERRED TRANSMITIONS ?
Mendao
Bom dia, pessoal !
Estou tendo problemas de upload na minha conexão . Estou há meses tentando solucionar isso com a velox e nada ate agora.
"fuçando" o Modem que tenho, um 3COM 812, descobri a tela abaixo com alteração no tal DEFERRED TRANSMITIONS.
Fiz uma pesquisa no google e achei isso :
Deferred transmissions/collisions: Why is there a significant
increase in the number of deferred transmissions and collisions on my
network?
Answer: On IEEE802.3/Ethernet networks, a collision occurs when two
or more stations try to transmit data simultaneously. A deferred
transmission occurs if the network is busy when a station attempts to
transmit data. The number of collisions and deferred transmissions on a
node is directly related to the network load. As the network load
increases, the number of collisions and deferred transmissions also
increase.
When high-performance systems are placed on a LAN with
lower-performance systems (HP or non-HP systems), it is possible for the
high-performance systems to use a higher percentage of the LAN
bandwidth with network traffic intensive applications.
High-performance systems generate network traffic at a 10Mbits/s link
rate, and lower-performance systems cannot match this rate. Heavily
loaded LAN networks can result in lower throughput performance on
lower-performance systems.
" Deferred Transmissions
A count of frames for which the first transmission attempt on a particular interface is delayed because the medium is busy. The count represented by an instance of this object does not include frames involved in collisions."
Li, traduzi mas nao entendi nada ... será que algum colega poderia explicar-me do que se trata ? Seria este o meu problema com o Velox ?
Ninguem pra ajudar ? Continuo com problemas na Net , principalmente em jogos. Meu sinal Upload parece que é todo picotado !!
