Bom dia, quero comprar um (GTX 1050 TI 4GB) mais não sei se meu pc e compativel!
MEU COMPUTADOR
Processador: intel celeron dual E3400 2.60GHZ (Windows10)
Memoria (RAM): 6,00GB
Sistema: 64BITS
placa-mãe: G41TM-7
Memoria DDR3 2GB 1333MHZ
Fonte: 600W
Gabinete: Leadership TlG 910
PLACA DE VIDEO
Marca: GigaByte
Modelo: GV-N105TOC-4GD
 Graphics Processing: GeForce® GTX 1050 Ti
- Core Clock: Boost: 1455MHz/ Base: 1341MHz in OC Mode, Boost: 1430MHz/ Base: 1316MHz in Gaming
- Memory Clock: 7008 MHz
- Memory Size: 4 GB
- Memory Type: GDDR5
- Memory Bus: 128 bit
- Card Bus: PCI-E 3.0 x 16
- Output: Dual-link DVI-D *1, HDMI-2.0b*1 (Max Resolution: 4096x2160 @60 Hz), Display Port-1.4 *1 (Max Resolution: 7680x4320 @60 Hz)
- Digital max resolution: 7680x4320
- PCB Form: ATX
- DirectX: 12
- OpenGL: 4.5
- Recommended PSU: 300W
- Power Connectors: N/A
  • 4 anos depois...
