estou com dificuldade para usar transition no html/css ..
<!DOCTYPE html>
<html lang="pt-br">
<head>
    <meta charset="UTF-8">
    <meta http-equiv="X-UA-Compatible" content="IE=edge">
    <meta name="viewport" content="width=device-width, initial-scale=1.0">
    <title>Meu Teste</title>
    <link rel="stylesheet" href="assets/css/style.css"></link>
</head>
<body class="main-bg" >
   <aside class="menu white-bg">
    <section class="main-content menu-content">
        <h1><a href="#">Logo</a></h1>
       <nav>
           <ul>
               <li><a href="#">Meus projetos</a></li>
               <li><a href="#">E-mail</a></li>
               <li><a href="#">Whatsapp</a></li>
               <li><a href="#">LinkedIn</a></li>
               <li><a href="#">Curriculum</a></li>
           </ul>
       </nav>
</section>
</aside>
<section class="section"></section>
</body>
</html>
--- css---
:root {
    --primary-color: #542883;
    --secodary-color: red;
    --white-color : #fff ;
    --gap: 3rem;
    --lith-gray-golor: #eee;
    margin: 0;
    padding: 0;
body {
    font-family: 'Times New Roman', Times, serif;
    font-size: 2rem;
    color:var(--primary-color);
h1, h2, h3, h4, h5, h6 {
    font-family: sans-serif;
h1 {
    font-size: 4rem;
  h2 {
    font-size: 3.6rem;
  h3 {
    font-size: 3.4rem;
  h4 {
    font-size: 3.2rem;
  h5 {
    font-size: 3rem;
  h6 {
    font-size: 2.8rem;
    text-decoration: none;
.main-bg {
    background-color: #542883;
    background-image: url("data:image/svg+xml,%3Csvg xmlns='http://www.w3.org/2000/svg' width='100%25' height='100%25' viewBox='0 0 1600 800'%3E%3Cg %3E%3Cpolygon fill='%2367348c' points='1600 160 0 460 0 350 1600 50'/%3E%3Cpolygon fill='%23763d95' points='1600 260 0 560 0 450 1600 150'/%3E%3Cpolygon fill='%2384459e' points='1600 360 0 660 0 550 1600 250'/%3E%3Cpolygon fill='%23904ca5' points='1600 460 0 760 0 650 1600 350'/%3E%3Cpolygon fill='%239C53AD' points='1600 800 0 800 0 750 1600 450'/%3E%3C/g%3E%3C/svg%3E");
    background-attachment: fixed;
    background-size: cover;
    background-position: center center;
    color: var(--white-color);
.white-bg{
 background: var(--white-color);
.main-content {
    max-width: 120rem;
    margin: 0 auto;
    padding: var(--gap);
.section {
    min-height: 100vh;
.menu {
    position:fixed;
    top: 0 ;
    left : 0 ;
    right: 0;
    width: 100%;
    border-bottom: 0.1rem solid var(--lith-gray-golor);
.menu-content {
    display: flex;
    justify-content :space-between;
    align-items: center;
    padding-top: 0;
    padding-bottom: 0;
.menu h1 {
    font-size: 2.3rem;
.menu h1 a{
    color:inherit;
.menu ul  {
    list-style: none;
    display:flex;
.menu ul li a {
    display: block;
    padding: 2rem;
    font-size: 1.8rem;
    position: relative;
.menu ul li a::after {
 content: '';
 position: absolute;
 bottom: 1rem;
 left: 50%;
 width: 0;
 height: 0.2rem;
 background:var(--secodary-color);
 transition-delay: 1s;
menu ul li a :hover::after{
    width: 50%;
    left: 25%;
Olá!
Li a questão e não entendi.
Li o código e não entendi onde a questão está.
Copiei localmente e executei e não entendi.
Afinal, onde o sr. quer usar transition?
Se puder, me ajude a entender.
@washalbano era na questão de colocar o mouse em cima do menu e ele ter um efeito, o que não estava acontecendo, apaguei tudo e fiquei tentando fazer ate funcionar, acabou funcionando, valeu por tentar ajudar
  • Moderador
@edupessoa1
3 horas atrás, edupessoa1 disse:
Por gentileza, poderia informar o que exatamente você mudou para funcionar? Sua resposta vai ajudar os demais com a mesma dúvida.
