Qual fonte ideal para usar nesse Desktop
Detalher tem walter cooler H50
Total tem 5 cooler 120mm
Atx 500w Gamer Super Silenciosa PFC Ativo Bivolt
sir é possiver fazer overclock
Driver Easy TXT Report
Binaries
Driver Easy version            v5.6.14
Overview
    Machine                PEGATRON - IPMH61P1
    Operating System        Microsoft Windows 7 Ultimate  (64-bit) Service Pack 1
    Memory                16 GB
    Processor            Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz
    Motherboard            PEGATRON CORPORATION - IPMH61P1
    Video Cards            Radeon RX 570 Series
    Monitors            W2252
    Hard Disk            KINGSTON SA400S37120G ATA Device (120,0 GB)
    Network Card            RAS Async Adapter
CPU
Processor
    Name                Intel Core i7 2600
    Code Name            Sandy Bridge
    TDP                95 W
    Package                Socket 1155 LGA
    Technology            32 nm
    Core Voltage            1,2 V
    Specification            Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz
    Family                6
    Model                --
    Stepping            --
    Ext. Family            --
    Ext. Model            --
    Revision            D2
    Instructions            MMX , SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, x86-64, NX, VMX, AES, AVX
Clocks
    Core Speed            3591,4 MHz
    Multiplier            x 36
    Bus Speed            99,8 MHz
    QPILink                --
Cache
    L1 Data                4 x 32 KBytes
    L1 Inst                4 x 32 KBytes
    Level 2                4 x 256 KBytes
    Level3                8192 KBytes
Motherboard
Motherboard
    Manufacturer            PEGATRON CORPORATION
    Model                IPMH61P1        1.01
    Chipset                Intel        Sandy Bridge
    Revision            09
    Southbrige            Intel        H61
    Revision            B3
    LPCIO                --
BIOS
    Core Speed            American Megatrends Inc.
    Version                0302
    Date                07/03/2012
Graphic Interface
    Version                --
    Transfer Rate            --
    Max. Supported            --
Memory
General
    Type                DDR3
    Size                16384 MBytes
    Channel#            --
    DC Model            --
    NB Frequency            --
Timings
    DRAM Frequency            665,1 MHz
    FSB:DRAM            --
    CAS# Latency(CL)        9 clocks
    RAS# to CAS# Delay(tRCD)    9 clocks
    RAS# Precharge(tRP)        9 clocks
    Cycle Time(rRAS)        24 clocks
    Bank Cycle Time(tRC)        --
    Command Rate(CR)        1 clocks
Graphics
GPU
    Name                Radeon RX 570 Series
    Code Name            Polaris
    Technology            14 nm
    Revision            --
Clocks
    Core                --
    Shader                --
    Memory                --
Memory
    Size                4096 MBytes
    Type                8
    Bus Width            --
