Olá pessoal, sou novo no site e gostaria que alguém me ajudasse com um problema que estou tendo com o meu projeto. Estou desenvolvendo um "clone" do Ifood e ao rodar meu app ele trava e fecha no mesmo instante. Apareceu o seguinte erro:
E/dalvikvm: Could not find class 'android.os.UserManager', referenced from method com.google.android.gms.common.GooglePlayServicesUtilLight.isRestrictedUserProfile
E/ActivityThread: Failed to find provider info for com.google.android.gms.phenotype
E/dalvikvm: Could not find class 'android.app.AppOpsManager', referenced from method com.google.android.gms.common.wrappers.PackageManagerWrapper.uidHasPackageName
E/dalvikvm: Could not find class 'android.graphics.drawable.RippleDrawable', referenced from method android.support.v7.widget.AppCompatImageHelper.hasOverlappingRendering
E/AndroidRuntime: FATAL EXCEPTION: main
                  java.lang.RuntimeException: Unable to start activity ComponentInfo{br.com.ifood.cursoandroid.ifood/br.com.ifood.cursoandroid.ifood.activity.SplashActivity}: android.view.InflateException: Binary XML file line #0: Error inflating class ImageView
                      at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2059)
                      at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:2084)
                      at android.app.ActivityThread.access$600(ActivityThread.java:130)
                      at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1195)
                      at android.os.Handler.dispatchMessage(Handler.java:99)
                      at android.os.Looper.loop(Looper.java:137)
                      at android.app.ActivityThread.main(ActivityThread.java:4745)
                      at java.lang.reflect.Method.invokeNative(Native Method)
                      at java.lang.reflect.Method.invoke(Method.java:511)
                      at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:786)
                      at c
om.android.internal.os.ZygoteInit.main(ZygoteInit.java:553)
                      at dalvik.system.NativeStart.main(Native Method)
                   Caused by: android.view.InflateException: Binary XML file line #0: Error inflating class ImageView
                      at android.view.LayoutInflater.createViewFromTag(LayoutInflater.java:704)
                      at android.view.LayoutInflater.rInflate(LayoutInflater.java:746)
                      at android.view.LayoutInflater.inflate(LayoutInflater.java:489)
                      at android.view.LayoutInflater.inflate(LayoutInflater.java:396)
                      at android.view.LayoutInflater.inflate(LayoutInflater.java:352)
                      at android.support.v7.app.AppCompatDelegateImplV9.setContentView(AppCompatDelegateImplV9.java:287)
                      at android.support.v7.app.AppCompatActivity.setContentView(AppCompatActivity.java:139)
                      at br.com.ifood.cursoandroid.ifood.activity.SplashActivity.onCreate(SplashActivity.java:15)
                      at android.app.Activity.performCreate(Activity.java:5008)
                      at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1079)
                      at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2023)
                      at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:553)
                   Caused by: android.content.res.Resources$NotFoundException: Resource ID #0x7f06006c
                      at android.content.res.Resources.getValue(Resources.java:1013)
                      at android.support.v7.widget.ResourcesWrapper.getValue(ResourcesWrapper.java:208)
                      at android.support.v7.widget.AppCompatDrawableManager.loadDrawableFromDelegates(AppCompatDrawableManager.java:328)
                      at android.support.v7.widget.AppCompatDrawableManager.getDrawable(AppCompatDrawableManager.java:193)
                      at android.support.v7.widget.AppCompatDrawableManager.getDrawable(AppCompatDrawableManager.java:186)
                      at android.support.v7.content.res.AppCompatResources.getDrawable(AppCompatResources.java:100)
                      at android.support.v7.widget.AppCompatImageHelper.loadFromAttributes(AppCompatImageHelper.java:58)
                      at android.support.v7.widget.AppCompatImageView.<init>(AppCompatImageView.java:77)
                      at android.support.v7.widget.AppCompatImageView.<init>(AppCompatImageView.java:67)
                      at android.support.v7.app.AppCompatViewInflater.createImageView(AppCompatViewInflater.java:181)
                      at android.support.v7.app.AppCompatViewInflater.createView(AppCompatViewInflater.java:105)
                      at android.support.v7.app.AppCompatDelegateImplV9.createView(AppCompatDelegateImplV9.java:1035)
                      at android.support.v7.app.AppCompatDelegateImplV9.onCreateView(AppCompatDelegateImplV9.java:1092)
                      at android.view.LayoutInflater.createViewFromTag(LayoutInflater.java:675)
E/FirebaseInstanceId: Google Play services missing or without correct permission.
ATUTENTICACAO.ACTIVITY
import android.content.Intent;
import android.support.annotation.NonNull;
import android.support.v7.app.AppCompatActivity;
import android.os.Bundle;
import android.view.View;
import android.widget.Button;
import android.widget.EditText;
import android.widget.Switch;
import android.widget.Toast;
import com.google.android.gms.tasks.OnCompleteListener;
import com.google.android.gms.tasks.Task;
import com.google.firebase.auth.AuthResult;
import com.google.firebase.auth.FirebaseAuth;
import com.google.firebase.auth.FirebaseAuthInvalidCredentialsException;
import com.google.firebase.auth.FirebaseAuthUserCollisionException;
import com.google.firebase.auth.FirebaseAuthWeakPasswordException;
import com.google.firebase.auth.FirebaseUser;
import br.com.ifood.cursoandroid.ifood.R;
import br.com.ifood.cursoandroid.ifood.helper.ConfiguracaoFirebase;
public class AutenticacaoActivity extends AppCompatActivity {
    private Button botaoAcessar;
    private EditText campoEmail, campoSenha;
    private Switch tipoAcesso;
    private FirebaseAuth autenticacao;
    @Override
    protected void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.activity_autenticacao);
        getSupportActionBar().hide();
        inicializaComponentes();
        autenticacao = ConfiguracaoFirebase.getFirebaseAutenticacao();
        //autenticacao.signOut();
        //Verificar usuario logado
        verificarUsuarioLogado();
        botaoAcessar.setOnClickListener(new View.OnClickListener() {
            @Override
            public void onClick(View v) {
                String email = campoEmail.getText().toString();
                String senha = campoSenha.getText().toString();
                if ( !email.isEmpty() ){
                    if ( !senha.isEmpty() ){
                        //Verifica estado do switch
                        if( tipoAcesso.isChecked() ){//Cadastro
                            autenticacao.createUserWithEmailAndPassword(
                                    email, senha
                            ).addOnCompleteListener(new OnCompleteListener<AuthResult>() {
                                @Override
                                public void onComplete(@NonNull Task<AuthResult> task) {
                                    if (task.isSuccessful()){
                                        Toast.makeText(AutenticacaoActivity.this,
                                                "Cadastro realizado com sucesso!",
                                                Toast.LENGTH_SHORT).show();
                                        abrirTelaPrincipal();
                                    }else {
                                        String erroExcecao = "";
                                        try{
                                            throw task.getException();
                                        }catch (FirebaseAuthWeakPasswordException e){
                                            erroExcecao = "Digite uma senha mais forte!";
                                        }catch (FirebaseAuthInvalidCredentialsException e){
                                            erroExcecao = "Por favor, digite um e-mail válido";
                                        }catch (FirebaseAuthUserCollisionException e){
                                            erroExcecao = "Este conta já foi cadastrada";
                                        } catch (Exception e) {
                                            erroExcecao = "ao cadastrar usuário: "  + e.getMessage();
                                            e.printStackTrace();
                                                "Erro: " + erroExcecao ,
                        }else {//Login
                            autenticacao.signInWithEmailAndPassword(
                                    email, senha
                                @Override
                                                "Logado com sucesso",
                                    }else {
                                                "Erro ao fazer login : " + task.getException() ,
                    }else {
                                "Preencha a senha!",
                }else {
                            "Preencha o E-mail!",
    private void verificarUsuarioLogado(){
        FirebaseUser usuarioAtual = autenticacao.getCurrentUser();
        if( usuarioAtual != null ){
    private void abrirTelaPrincipal(){
        startActivity(new Intent(getApplicationContext(), HomeActivity.class));
    private void inicializaComponentes(){
        campoEmail = findViewById(R.id.editCadastroEmail);
        campoSenha = findViewById(R.id.editCadastroSenha);
        botaoAcessar = findViewById(R.id.buttonAcesso);
        tipoAcesso = findViewById(R.id.switchAcesso);
CONFIGURACAOFIREBASE.JAVA
import com.google.firebase.database.DatabaseReference;
import com.google.firebase.database.FirebaseDatabase;
import com.google.firebase.storage.FirebaseStorage;
import com.google.firebase.storage.StorageReference;
public class ConfiguracaoFirebase {
    private static DatabaseReference referenciaFirebase;
    private static FirebaseAuth referenciaAutenticacao;
    private static StorageReference referenciaStorage;
    public static String getIdUsuario(){
        FirebaseAuth autenticacao = getFirebaseAutenticacao();
        return autenticacao.getCurrentUser().getUid();
    //retorna a referencia do database
    public static DatabaseReference getFirebase(){
        if( referenciaFirebase == null ){
            referenciaFirebase = FirebaseDatabase.getInstance().getReference();
        return referenciaFirebase;
    //retorna a instancia do FirebaseAuth
    public static FirebaseAuth getFirebaseAutenticacao(){
        if( referenciaAutenticacao == null ){
            referenciaAutenticacao = FirebaseAuth.getInstance();
        return referenciaAutenticacao;
    //Retorna instancia do FirebaseStorage
    public static StorageReference getFirebaseStorage(){
        if( referenciaStorage == null ){
            referenciaStorage = FirebaseStorage.getInstance().getReference();
        return referenciaStorage;
Boa tarde @Vitor Rodrigues Soares
Pelo que está escrito aqui,
17 horas atrás, Vitor Rodrigues Soares disse:
Está faltando importar o android.os.UserManager, android.app.AppOpsManager e o android.graphics.drawable.RippleDrawable.
