Problema com o Medal of Honor Allied Assault
lmariosl
Como já disse tentei de tudo, revirei o Clube do Hardware, também fui em outros foruns mais não consegui resolver! :muro:
Meu PC:
AMD Athlon XP 2200+
Windows XP Professional
256 RAM
GeForce FX 5200 128MB atualização 66.93
DirectX 9.0c
Abaixo esta o LOG de ERRO:
--- Common Initialization ---
Medal of Honor Allied Assault 1.11 win-x86 Mar 5 2002
----- FS_Startup -----
Current search path:
C:\ARQUIV~1\EAGAME~1\MOHAA/main
C:\ARQUIV~1\EAGAME~1\MOHAA\main\pak6.pk3 (104 files)
C:\ARQUIV~1\EAGAME~1\MOHAA\main\Pak5.pk3 (259 files)
C:\ARQUIV~1\EAGAME~1\MOHAA\main\Pak4.pk3 (593 files)
C:\ARQUIV~1\EAGAME~1\MOHAA\main\Pak3.pk3 (669 files)
C:\ARQUIV~1\EAGAME~1\MOHAA\main\Pak2.pk3 (4722 files)
C:\ARQUIV~1\EAGAME~1\MOHAA\main\Pak1.pk3 (772 files)
C:\ARQUIV~1\EAGAME~1\MOHAA\main\Pak0.pk3 (11175 files)
18294 files in pk3 files
execing default.cfg
execing menu.cfg
execing newconfig.cfg
Config: unnamedsoldier.cfg
couldn't exec configs/unnamedsoldier.cfg
execing safemode.cfg
couldn't exec localized.cfg
execing autoexec.cfg
Unknown command "fov"
couldn't exec custom.cfg
...detecting CPU, found AMD w/ 3DNow!
------- Input Initialization -------
Initializing DirectInput...
Couldn't set DI coop level
Falling back to Win32 mouse support...
------- Input Initialization Complete ------- 121
You are now setup for easy mode.
----- Client Initialization -----
Called FadeSound with: 0.000000
----- Initializing Renderer ----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\system32\opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using colorsbits of 16
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 16, 16, 0 )
...23 PFDs found
...GLW_ChoosePFD failed
...23 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (3)
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
GLW_StartOpenGL() - could not load OpenGL subsystem
Amigos espero que possam me ajudar, estou louco para jogar rsrs...
A mensagem de erro parece indicar que ele está procurando drivers de vídeo de uma VGA Voodoo. Você consegue entrar em modo de segurança no jogo (geralmente os games com essa engine tem essa opção)? Se sim, tente reconfigurar o jogo.
Cara, porque você não instala o último driver da tua placa! Com ele o Medal rodou bem melhor.
Tenta esse: http://download.nvidia.com/Windows/91.47/9...nglish_whql.exe
Falô!
Além de teu micro não fechar com a conf mínima:
Pentium IV 1.5 GHz processador Athlon equivalente.
Windows XP ou 2000.
3.0 GB de espaço livre em disco rígido mais espaço adicional para jogos salvos, arquivos de troca do Windows e instalação do DirectX8.1 (incluso no CD).
512 MB de RAM ou mais.
CD-ROM ou DVD-ROM de 8X velocidades.
Placa de som compatível com DirectX 8.1.
Indispensável Placa de vídeo aceleradora 3D de 64 MB compatível com DirectX 8.1 usando um dos chipsets: ATI Radeon 8500 ou superior; NVIDIA GeForce3 ou superior (com exceção da GeForce4 MX ou outros modelos MX, que não são suportadas).
Teclado e mouse.
Valeu gandalfnho, obrigado por me responder!
Eu já tentei entrar sim pelo modo de segurança, mais também não deu certo... Eu fiz um teste no micro do meu amigo que é um AND Duron 1.1, 512 de RAM, Geforce 2 MX 400 64 mb, DirectX 9.0c e rodou legal cara sem nenhum problema rsrs
Falô!
Windows XP ou 2000.
Teclado e mouse.
Valeu GamesOfShoot por responder...
Vou baixar agora o driver da minha NVIDIA atualizado, o estranho é que estou rodando tranquilo o Need for Speed Most Wanted, Rainbow Six - Lockdown e Winning Eleven 9, sem nenhum problema sabe, ai esse MOHAA que eu pensei que não teria problema esta me dando rsrs
Você disse que meu micro não fecha com a configuração minina mais vou fazer o comparativo...
Pentium IV 1.5 GHz processador Athlon equivalente --> Tenho um AMD Athlon XP 2200+
Windows XP ou 2000 --> Tenho Win XP SP2 Professional atualizado
3.0 GB de espaço livre --> Tenho HD Samsung 80gb 7200 rpm
512 MB de RAM ou mais --> Tenho 512 RAM
CD-ROM ou DVD-ROM de 8X velocidades --> Tenho uma COMBO LG 52x
Placa de som compatível com DirectX 8.1 --> Tenho uma Compativel
Indispensável Placa de vídeo aceleradora 3D de 64 MB compatível com DirectX 8.1 usando um dos chipsets: ATI Radeon 8500 ou superior; NVIDIA GeForce3 ou superior (com exceção da GeForce4 MX ou outros modelos MX, que não são suportadas) --> Tenho uma GeForce FX 5200 128mb
Como ti falei esta rodando uns jogos mais cabulosos que o MOHAA, sem problemas...
