Como faço para altera a data fixa 28/02/2017
para data atual - 1 dia
Alguma dica...
echo off
set antes=%date%
echo 28/02/2017  | date
set hora=%time%
echo 05:00:00,49 | time
start /MIN C:\Geral\7\abrir.bat
msg/time:120 /w * "1 minutos. Aguarde..."
ping localhost -n 120
echo %antes% | date
echo %hora% | time
exit
Seria algo assim que está precisando?
@Echo off
:: Check WMIC is available
WMIC.EXE Alias /? >NUL 2>&1 || GOTO s_error
:: Use WMIC to retrieve date and time
FOR /F "skip=1 tokens=1-6" %%G IN ('WMIC Path Win32_LocalTime Get Day^,Hour^,Minute^,Month^,Second^,Year /Format:table') DO (
   IF "%%~L"=="" goto s_done
      Set _yyyy=%%L
      Set _mm=00%%J
      Set _dd=00%%G
      Set _hour=00%%H
      SET _minute=00%%I
:s_done
:: Pad digits with leading zeros
      Set _mm=%_mm:~-2%
      Set _dd=%_dd:~-2%
      Set _hour=%_hour:~-2%
      Set _minute=%_minute:~-2%
:: Display the date/time in ISO 8601 format:
Set _isodate=%_dd%/%_mm%/%_yyyy% %_hour%:%_minute%
Echo %_isodate%
GOTO:EOF
:s_error
Echo Based on the sorted date code by Rob van der Woude.
Mostrar mais
Mostrar mais
