Irql_not_less_or_equal
Jambo
Aê galera andem pesquisando sobre esse erro e descubrir uma página em inglês da microsoft que diz:
WARNING: This article contains steps that may involve changing your BIOS or CMOS settings or that may require you to make physical changes to your computer hardware.
Incorrect changes to the BIOS of your computer can result in serious problems. Microsoft cannot guarantee that problems that result from changes to your BIOS can be resolved. Change the BIOS settings at your own risk. If you need assistance with any of these steps, contact the hardware manufacturer. Note however that making either hardware or BIOS changes to your computer may invalidate your warranty. If you do not want to make hardware changes to your computer, you can take your computer to a repair center.
SUMMARYThis article discusses how to troubleshoot the following Stop error in Windows XP:
Stop: 0x0000000A (parameter1, parameter2, parameter3, parameter4) IRQL_NOT_LESS_OR_EQUAL*** Address x has base at x - filename
The parameters refer to the specific issues that are involved:
Parameter 1 - An address that was referenced improperly
Parameter 2 - An IRQL that was required to access the memory
Parameter 3 - The type of access, where 0 is a read operation and 1 is a write operation
Parameter 4 - The address of the instruction that referenced memory in parameter 1
This article describes troubleshooting steps to take if you receive this Stop error either during or after the installation of Windows XP.
MORE INFORMATIONStop error 0x0000000A (Stop 0x0A) shows that there was an attempt in kernel mode to touch pageable memory at too high a process internal request level (IRQL). This error usually occurs when a driver uses an incorrect memory address. Other possible causes of this error are an incompatible device driver, a general hardware problem, and incompatible software.
A Stop 0x0A Error During the Installation of Windows
If you receive a Stop 0x0A error during the installation of Windows, use the following troubleshooting procedures to check hardware components.
Check the HCL
Verify that your hardware is on the Windows XP Hardware Compatibility List (HCL). If your hardware is not on the Windows XP HCL, consider obtaining hardware that is on the HCL.
For additional information about the Windows HCL, click the article number below to view the article in the Microsoft Knowledge Base:
314062 The Latest Windows XP Hardware Compatibility List
The latest HCL is available at the following Microsoft Web site:
http://www.microsoft.com/hcl/
Also, read the "Check System Compatibility" topic on the Windows XP CD-ROM to find out about potential software and hardware incompatibility.
The following troubleshooting steps can help you isolate the problem. Use the Windows XP CD-ROM to start the computer, and then follow the on-screen installation instructions.
Check Other Hardware Issues
If you continue to receive a Stop 0x0A error during the installation of Windows XP, try the following troubleshooting steps. After each step, try again to install Windows.
During the installation startup, press F5 when the "Setup is inspecting your computer's hardware configuration" message appears. When you are prompted, specify the correct computer type and hardware abstraction layer (HAL). For example, if you have a single processor, specify the "Standard PC" HAL.
Turn off the following features in the CMOS settings of your computer. Consult the hardware documentation or manufacturer for instructions.
All caching, including L2, BIOS, internal/external, and write-back caching on disk controllers
All shadowing
Plug and Play
Any BIOS-based virus protection feature
Remove all adapters and disconnect all hardware devices that are not absolutely required to start the computer and install Windows, including:
Network adapter
Internal modem
Sound card
Extra hard disks (you need at least one to complete the installation)
CD-ROM or DVD-ROM drive (if you are installing from the local hard disk)
If you are using a SCSI adapter, perform the following tasks (consult the hardware documentation for information):
Obtain the latest Windows driver from the adapter vendor.
Turn off sync negotiation on the SCSI controller.
Verify that termination and IDs of the SCSI devices are correct.
Remove all SCSI devices from the SCSI chain (except for one hard disk if you are starting from or installing to a drive that is on that disk).
If you are using IDE devices, perform the following tasks (consult the hardware documentation for more information):
Define the on-board IDE port to Primary only.
Verify that the Master/Slave/Only settings for the IDE devices are correct.
Remove all IDE devices except for the hard disk.
Check the memory SIMMs (the RAM) in the computer (consult your hardware documentation for more information):
Remove any mismatched memory SIMMs so that all the SIMMs operate at the same speed, for example 60ns or 70ns.
Run a systems test on the memory, and remove any bad SIMMs.
Test by using different SIMMs if any are available.
Contact the manufacturer of the computer or the motherboard to see whether there are any known issues about running or installing Windows XP. The manufacturer might be able to provide guidance about the following items:
Running a diagnostics program on the computer.
Upgrading the computer BIOS, if that is applicable.
A Stop 0x0A Error After Windows XP Is Already Installed
If you receive the Stop 0x0A error after Windows XP is already installed, use the following troubleshooting procedures to check other components.
Check Third-Party Software or Drivers
If you have installed any third-party software or drivers, try removing them or disabling them so that they do not load, and then restart the computer to see whether that software or driver is causing the error. If that software or driver is causing the error, report the problem to the vendor of the software or driver.
If you are not able to start into Windows XP after you install the software or drivers, use one of the following methods to restore Windows:
Try using the Last Known Good configuration.For additional information about using the Last Known Good configuration, click the article number below to view the article in the Microsoft Knowledge Base:
307852 HOW TO: Start Your Computer with Last Known Good Configuration
Try repairing the Windows XP installation. Follow these steps:
Disable any antivirus program and BIOS-level antivirus protection. For help, refer to the relevant software manual or online help.
Make sure that the CD-ROM or DVD-ROM drive is the first priority startup device. Refer to your computer documentation for information about how to do this.
Insert the Windows XP CD into the CD-ROM or DVD-ROM drive, and then restart your computer.
When the instruction to "Press any key to boot from CD" appears, press a key to let your computer start from the Windows XP CD.
When the computer starts from the CD, the system checks your hardware and then prompts you to select one of the following options:
To set up Windows XP now, press ENTER.
To repair a Windows XP installation using Recovery Console, press R.
To quit Setup without installing Windows XP, press F3.
Press ENTER.
Press F8 to accept the Licensing Agreement.
A box lists your current Windows XP installation, and then the system prompts you to select one of the following options:
To repair the selected Windows XP installation, press R.
To continue installing a fresh copy of Windows XP without repairing, press ESC.
Press R to start the automatic repair process. After repairing Windows XP, you may need to reactivate Windows XP, if you changed some hardware.
Try using the Roll Back Driver feature. For additional information about using the Roll Back Driver feature, click the article number below to view the article in the Microsoft Knowledge Base:
283657 HOW TO: Use the Roll Back Driver Feature
Try using the Windows XP System Restore feature.For additional information about using the System Restore feature, click the article number below to view the article in the Microsoft Knowledge Base:
306084 HOW TO: Restore Windows XP to a Previous State
Try using Recovery Console.For additional information about using Recovery Console, click the article number below to view the article in the Microsoft Knowledge Base:
307654 HOW TO: Access the Recovery Console During Startup
If Windows is on a FAT partition, try booting to MS-DOS and renaming the problem software or driver.
Check Newly Installed Hardware
If you added any hardware device after Windows was installed, try removing the newly added device to see whether the Stop 0x0A error stops occurring. If removing the newly added device resolves the problem, try any or all of the following procedures:
Obtain updated drivers for the device, if any updated drivers are available.
Call the vendor of the device to see whether there are any known issues with the device.
Run diagnostics to make sure that the device is working properly.
Examine the logs under Event Viewer to see whether there is any event information that might help you determine what device or driver is causing the problem.
Additional Information
If the preceding steps do not resolve the Stop 0x0A error, and if you are running Windows on HCL-compliant hardware, refer to the following article in the Microsoft Knowledge Base:
314103 Preparation Before You Contact Microsoft After Receiving a STOP Message on a Blue Screen
You can also refer to the following pages on the Microsoft Support Site:
Troubleshoot Windows XP Professional
Troubleshoot Windows XP Home
Alguém que seja muito fera em inglês pode traduzir isto?? Por favor eu peço encarecidamente.....
</font>
ADVERTINDO: Este artigo contém passos que podem envolver mudando seu BIOS ou colocações de CMOS ou isso pode lhe exigir que faça mudanças físicas a seu hardware.
Mudanças incorretas para o BIOS de seu computador podem resultar em problemas sérios. A Microsoft não pode garantir que podem ser solucionados problemas que são o resultado de mudanças a seu BIOS. Mude as colocações de BIOS a seu próprio risco. Se você precisar de ajuda com quaisquer destes passos, contate o fabricante de hardware. Note aquela fabricação porém hardware ou BIOS muda a seu computador pode invalidar sua garantia. Se você não quiser fazer mudanças de hardware a seu computador, você pode levar seu computador a um centro de conserto.
Artigo de SUMMARYThis discute como para troubleshoot o erro de Parada seguinte em Windows XP:
Parada: 0x0000000A (parameter1, parameter2, parameter3, parameter4) IRQL_NOT_LESS_OR_EQUAL * * * Endereço x tem base a x - filename
Os parâmetros recorrem aos assuntos específicos que são envolvidos:
Parâmetro 1 - Um endereço que era improperly de referenced
Parâmetro 2 - Um IRQL que foi exigido ter acesso a memória
Parâmetro 3 - O tipo de acesso onde 0 são uma operação erudita e 1 é um escreva operação
Parâmetro 4 - O endereço da instrução que memória de referenced em parâmetro 1
Este artigo descreve troubleshooting pisa para levar se você ou receber este erro de Parada durante ou depois da instalação de Windows XP.
MAIS INFORMATIONStop erro 0x0000000A (0x0A de Parada) espetáculos que havia uma tentativa em modo de núcleo tocar memória de pageable a muito alto um processo nível de pedido interno (IRQL). Este erro normalmente acontece quando um motorista usar um endereço de memória incorreto. Outras possíveis causas deste erro são motorista de dispositivo incompatível, um problema de hardware geral, e software incompatível.
Um Erro de 0x0A de Parada Durante a Instalação de Windows
Se você receber um erro de 0x0A de Parada durante a instalação de Windows, use os procedimentos de troubleshooting seguintes para conferir componentes de hardware.
Confira o HCL
Verifique que seu hardware está no Windows XP Hardware Compatibilidade Lista (HCL). Se seu hardware não estiver no Windows XP HCL, considere hardware de obtenção que está no HCL.
Para informação adicional sobre o Windows HCL, clique o número de artigo abaixo ver o artigo na Microsoft Conhecimento Base:
314062 o mais Recente Windows XP Hardware Compatibilidade Lista
O mais recente HCL está disponível à Microsoft seguinte local de Web:
http://www.microsoft.com/hcl /
Também, leia para o " Cheque tópico de Compatibilidade " De sistema no Windows XP CD-ROM descobrir sobre software potencial e incompatibilidade de hardware.
Os passos de troubleshooting seguintes podem lhe ajudar a isolar o problema. Use o Windows XP CD-ROM para começar o computador, e então siga as instruções de instalação de em-tela.
Confira Outros Assuntos de Hardware
Se você continuar recebendo um erro de 0x0A de Parada durante a instalação de Windows XP, tente os passos de troubleshooting seguintes. Depois de cada passo, tente instalar o Windows novamente.
Durante o startup de instalação, imprensa F5 quando a " Organização está inspecionando que o mensagem de configuração " de hardware de seu computador se aparece. Quando você é incitado, especifique o tipo de computador correto e camada de abstração de hardware (HAL). por exemplo, se você tiver um único processador, especifique o " PC " HAL Standard.
Vire fora as características seguintes nas colocações de CMOS de seu computador. Consulte a documentação de hardware ou fabricante para instruções.
Todo o caching, inclusive L2, BIOS, internal/external, e caching de escrever-parte de trás em controladores de disco,
Tudo que sombreiam
Tomada e Jogo
Qualquer característica de proteção de vírus BIOS-baseada
Remova todos os adaptadores e desconecte todos os dispositivos de hardware que não são exigidos começar o computador e instalar o Windows absolutamente, enquanto incluindo:
Adaptador de rede
Modem interno
Cartão são
Discos rígidos extras (você precisa um pelo menos para completar a instalação)
CD-ROM ou DVD-ROM dirigem (se você está instalando do disco rígido local)
Se você estiver usando um adaptador de SCSI, execute as tarefas seguintes (consulte a documentação de hardware para informação):
Obtenha o mais recente motorista de Windows do vendedor de adaptador.
Vire fora negociação de sync no controlador de SCSI.
Verifique aquela terminação e Id dos dispositivos de SCSI estão corretos.
Remova todos os dispositivos de SCSI do SCSI encadeie (com exceção de um disco rígido se você é a partir de ou instalando a um passeio que está naquele disco).
Se você estiver usando dispositivos de IDE, execute as tarefas seguintes (consulte a documentação de hardware para mais informação):
Defina o em-tábua que IDE só aportam para Primário.
Verifique que as colocações de Master/Slave/Only para os dispositivos de IDE estão corretas.
Remova todos os dispositivos de IDE com exceção do disco rígido.
Confira a memória SIMMs (o CARNEIRO) no computador (consulte sua documentação de hardware para mais informação):
Remova alguma memória de mismatched SIMMs de forma que todo o SIMMs opere à mesma velocidade, por exemplo 60ns ou 70ns.
Faça um teste de sistemas na memória, e remova qualquer SIMMs ruim.
Teste usando SIMMs diferente se qualquer estiver disponível.
Contate o fabricante do computador ou o placa-base para ver se há qualquer assunto conhecido quase correndo ou instalando Windows XP. O fabricante poderia poder prover orientação sobre os artigos seguintes:
Correndo um programa de diagnósticos no computador.
Melhorando o computador BIOS, se isso é aplicável.
Um Erro de 0x0A de Parada depois que Windows XP Já seja Instalado
Se você recebe o erro de 0x0A de Parada que depois que Windows XP já é instalado, use os procedimentos de troubleshooting seguintes para conferir outros componentes.
Confira Software de Terço-festa ou Motoristas
Se você instalou qualquer software de terço-festa ou motoristas, tentou os removendo ou os incapacitando de forma que eles não carregam, e então reiniciou o computador para ver se aquele software ou o motorista está causando o erro. Se aquele software ou o motorista está causando o erro, informe o problema ao vendedor do software ou motorista.
Se você não pode começar em Windows XP que depois que você instalar o software ou motoristas, use um dos métodos seguintes para restabelecer o Windows:
Prova que usa o Último configuration.For Bom Conhecido informação adicional sobre usar a Última configuração Boa Conhecida, clique o número de artigo abaixo ver o artigo na Microsoft Conhecimento Base:
307852 COMO PARA: Comece Seu Computador com Última Configuração Boa Conhecida
Prova que conserta o Windows instalação de XP. Siga estes passos:
Incapacite qualquer programa anti-vírus e BIOS-nível proteção anti-vírus. Para ajuda, recorra ao software pertinente ajuda manual ou on-line.
Tenha certeza que o CD-ROM ou passeio de DVD-ROM é o primeiro dispositivo de startup de prioridade. Recorra a sua documentação de computador para informação aproximadamente como fazer isto.
Insira o Windows XP CD no CD-ROM ou DVD-ROM dirijam, e então reinicie seu computador.
Quando a instrução para Apertar qualquer chave para calçar as botas de CD " se aparecer, aperte uma chave para deixar seu computador começar do Windows XP CD.
Quando o computador começa do CD, os cheques de sistemas seu hardware e então lembretes você para selecionar um das opções seguintes:
Para montar Windows XP agora, ENTRA imprensa.
Consertar um Windows instalação de XP que usa Consolo de Recuperação, imprensa R.
Deixar Organização sem instalar Windows XP, imprensa F3.
Imprensa ENTRA.
Aperte F8 para aceitar o Acordo de Licenciamento.
Uma caixa lista seu Windows atual instalação de XP, e então os lembretes de sistemas você para selecionar um das opções seguintes:
Consertar o Windows selecionado instalação de XP, imprensa R.
Continuar instalando uma cópia fresca de Windows XP sem consertar, imprensa ESC.
Aperte R para começar o processo de conserto automático. Depois de consertar Windows XP, você pode precisar reativar Windows XP, se você mudasse algum hardware.
Prova que usa o Rolo Atrás característica de Motorista. Para informação adicional sobre usar o Rolo Atrás característica de Motorista, clique o número de artigo abaixo ver o artigo na Microsoft Conhecimento Base:
283657 COMO PARA: Use o Rolo Atrás Motorista Feature
Prova que usa o Windows XP Sistema Restabelece feature.For informação adicional sobre usar o Sistema Restabeleça característica, clique o número de artigo abaixo ver o artigo na Microsoft Conhecimento Base:
306084 COMO PARA: Restabeleça Windows XP a um Estado Prévio
Prova que usa Recuperação Console.For informação adicional sobre usar Consolo de Recuperação, clique o número de artigo abaixo ver o artigo na Microsoft Conhecimento Base:
307654 COMO PARA: Tenha acesso o Consolo de Recuperação Durante Startup
Se o Windows estiver em uma partição GORDA, tente calçando as botas a MS-DOS e renomeando o software de problema ou motorista.
Confira Hardware Recentemente Instalado
Se você somasse qualquer dispositivo de hardware que depois que o Windows foi instalado, tente removendo o dispositivo recentemente somado para ver se o erro de 0x0A de Parada deixa de acontecer. Se removendo o dispositivo recentemente somado solucionar o problema, tente qualquer ou todos os procedimentos seguintes:
Obtenha os motoristas atualizados para o dispositivo, se qualquer atualizasse que os motoristas estão disponíveis.
Chame o vendedor do dispositivo para ver se há qualquer assunto conhecido com o dispositivo.
Corra diagnósticos para ter certeza que o dispositivo está trabalhando corretamente.
Examine os troncos debaixo de Espectador de Evento ver se há que dispositivo qualquer informação de evento que poderia o ajudar determina ou o motorista está causando o problema.
Informação adicional
Se os passos precedendo não solucionam o erro de 0x0A de Parada, e se você for o Windows corrente em hardware HCL-complacente, recorra ao artigo seguinte na Microsoft Conhecimento Base:
314103 preparação Antes de Você Contatasse a Microsoft Depois de Receber uma Mensagem de PARADA em uma Tela Azul
Você também pode recorrer às páginas seguintes no Microsoft Apoio Local:
Troubleshoot o Windows XP Profissional
Troubleshoot Windows XP Casa
Olha o q eu pude arranjar foi isso... será q ajuda? sim mais vê só! http://support.microsoft.com/default.aspx?...kb;pt-br;311564
http://support.microsoft.com/default.aspx?...kb;PT-BR;310064
Essas páginas tem informações sobre esse erro
Talvez meu problema seja o CD que não dá boot, vou pegar um que dar boot prá ver se resolve o meu problema..Segundo este documento aí em cima.
Perae.. tu leu aquela "solução" ali?
Basicamente, caso teu sistema já esteja instalado, tenta remover algum recente software ou hardware que tenha sido colocado.
Se é na instalação do sistema que dá, tenta reinstalar tudo do zero com todos os hardwares não essenciais desinstalados.
Tenta, também, tirar todo tipo de cache da bios.
Tenta, ainda, usar o system restore ou ultima boa configuração conhecida.
Tenta, claro, corrigir pelo Recovery Console.
Tenta fazer upgrades dos drivers.
Caso ainda não tenha solucionado teu tão bem localisado e documentado problema, tenta ligar para o suprte tecnico do seu vendedor e descobrir se existe algum problema com os drivers dele.
Caso tu tenha cuidadosamente efetuado TODOS os procedimentos acima (!!!), pode teantar também reportar o erro para a MS de forma que corrijam em uma futura versão (vale lembrar que devido a abrangencia desse erro o log que tu criar não será o suficiente...)
E pronto. Solucionado o irql_not_less_or_equal. Caso não tenha solucionado com todo o passo a passo que foi fornecido, questione tua capacidade tecnica......
  • 5 anos depois...
Olá a todos,
Estou com um problema no hd,
ele tá compartido, consigo acessar no que nao tem o sistema operacional, mais quando acesso "C" vem essa mensagem e nao me deixa voltar a instalar o windows, o problema começo quando eu troquei o hd e instalei o windows pro, só q por motivos de virus voltei a instalar, e foi depois disso q tá inassecivel, depois de pressionar o "F8" aceitando terminos da microsoft, vem a maldita pagina azul do tal erro
se alguem tem alguma noção do que devo fazer seria muito bem vindo
Falou
