TV LED 42'' LG - USB - Legenda errada
Galera, comprei uma tv da LG com entrada USB e tentei assistir um seriado usando o HD externo. O video abriu direitinho, embora tenha percebido umas travadas as vezes, mas a legenda fica totalmente errada. Ex: "The book is on the table" fica "$*Y#*$(!&55*#!&$(*!&_%&%".
OBS: Filme e legenda com mesmo nome, na mesma pasta. Filme .mkv e legenda .srt.
Arquivo .mkv:
File size : 1.46 GiB
Duration : 1h 1mn
Overall bit rate : 3 386 Kbps
Encoded date : UTC 2010-02-22 21:41:29
Writing application : no_variable_data
Writing library : no_variable_data
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 1mn
Bit rate : 2 994 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.135
Stream size : 1.26 GiB (87%)
Writing library : x264 core 85 r1442tw
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=30 / sliced_threads=0 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=6 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / wpredp=0 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=2994 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : No
Forced : No
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : A_AC3
Duration : 1h 1mn
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 169 MiB (11%)
Default : Yes
Forced : No
Arquivo .srt:
General
Complete name : C:\Users\PHRC\Desktop\New folder\Game.of.Thrones.S01E01.720p.HDTV.x264.srt
Format : SubRip
File size : 38.8 KiB
Text
Format : SubRip
Compression mode : Lossless
Link da TV: http://www.lg.com/us/tvs/lg-42LS5700
Alguem sabe como arrumar? Valeu.
É só com esse arquivo de vídeo?
Tenho uma lg também, e roda tudo direitinho, porém, não são todas as tvs, ou modelos, que rodam .mkv direitinho. A minha roda, mas dependendo do encode, não consigo avançar o filme, apenas reproduzi-lo. Teste com outros arquivos usando h264 ou x264, como este mkv, pode ser só um caso isolado. Também existe a possibilidade de ser a codificação da legenda usada pelo televisor, nesse caso, entre no menu durante a reproducção e procure alguma opção para mudar isso, é uma configuração muito comum em DVDS de mesa. abraço
O filme ta com o mesmo nome da legenda só com a extensão diferente:
Game.of.Thrones.S01E01.720p.HDTV.x264.mkv
Game.of.Thrones.S01E01.720p.HDTV.x264.srt ?
Você já tentou salvar a legenda com outra extensão tipo: sub? Já tentou converter o mkv para avi?
Tente ler o manual para ver se sua te suporta legendas para o formato mkv....
