Como usar o RFID-RC522
Ir à solução Resolvido por mister nintendo,
Boa tarde, comprei um módulo RFID-RC522 e liguei conforme os dados abaixo:
Arduino -> RFID RC522
10 -> SDA
13 -> SCK
11 -> MOSI
12 -> MISO
- -> IRQ
GND -> GND
5 -> RST
3,3V -> 3,3V
E o código utilizado foi esse:
* File name: RFID.ino
* Creatory: Dr.Leong ( WWW.B2CQSHOP.COM )
* Creation date: 2011.09.19
* Modified by: Eng. Robson (robson.eletrô[email protected])
* Modified date: 2013.09.10
* Modified: Translation from Chinese to English (by google)
* Functional Description: Mifare1 Anti-collision find cards → → → Select card reader interface
// the sensor communicates using SPI, so include the library:
#include <SPI.h>
#define    uchar    unsigned char
#define    uint    unsigned int
//Maximum length of the array
#define MAX_LEN 16
//set the pin
const int chipSelectPin = 10;
const int NRSTPD = 5;
//MF522 Command word
#define PCD_IDLE 0x00 //NO action; Cancel the current command
#define PCD_AUTHENT 0x0E //Authentication Key
#define PCD_RECEIVE 0x08 //Receive Data
#define PCD_TRANSMIT 0x04 //Transmit data
#define PCD_TRANSCEIVE 0x0C //Transmit and receive data,
#define PCD_RESETPHASE 0x0F //Reset
#define PCD_CALCCRC 0x03 //CRC Calculate
// Mifare_One card command word
# define PICC_REQIDL 0x26 // find the antenna area does not enter hibernation
# define PICC_REQALL 0x52 // find all the cards antenna area
# define PICC_ANTICOLL 0x93 // anti-collision
# define PICC_SElECTTAG 0x93 // election card
# define PICC_AUTHENT1A 0x60 // authentication key A
# define PICC_AUTHENT1B 0x61 // authentication key B
# define PICC_READ 0x30 // Read Block
# define PICC_WRITE 0xA0 // write block
# define PICC_DECREMENT 0xC0 // debit
# define PICC_INCREMENT 0xC1 // recharge
# define PICC_RESTORE 0xC2 // transfer block data to the buffer
# define PICC_TRANSFER 0xB0 // save the data in the buffer
# define PICC_HALT 0x50 // Sleep
//And MF522 The error code is returned when communication
#define MI_OK 0
#define MI_NOTAGERR 1
#define MI_ERR 2
//------------------MFRC522 Register---------------
//Page 0:Command and Status
#define Reserved00 0x00
#define CommandReg 0x01
#define CommIEnReg 0x02
#define DivlEnReg 0x03
#define CommIrqReg 0x04
#define DivIrqReg 0x05
#define ErrorReg 0x06
#define Status1Reg 0x07
#define Status2Reg 0x08
#define FIFODataReg 0x09
#define FIFOLevelReg 0x0A
#define WaterLevelReg 0x0B
#define ControlReg 0x0C
#define BitFramingReg 0x0D
#define CollReg 0x0E
#define Reserved01 0x0F
//Page 1:Command
#define Reserved10 0x10
#define ModeReg 0x11
#define TxModeReg 0x12
#define RxModeReg 0x13
#define TxControlReg 0x14
#define TxAutoReg 0x15
#define TxSelReg 0x16
#define RxSelReg 0x17
#define RxThresholdReg 0x18
#define DemodReg 0x19
#define Reserved11 0x1A
#define Reserved12 0x1B
#define MifareReg 0x1C
#define Reserved13 0x1D
#define Reserved14 0x1E
#define SerialSpeedReg 0x1F
//Page 2:CFG
#define Reserved20 0x20
#define CRCResultRegM 0x21
#define CRCResultRegL 0x22
#define Reserved21 0x23
#define ModWidthReg 0x24
#define Reserved22 0x25
#define RFCfgReg 0x26
#define GsNReg 0x27
#define CWGsPReg     0x28
#define ModGsPReg 0x29
#define TModeReg 0x2A
#define TPrescalerReg 0x2B
#define TReloadRegH 0x2C
#define TReloadRegL 0x2D
#define TCounterValueRegH 0x2E
#define TCounterValueRegL 0x2F
//Page 3:TestRegister
#define Reserved30 0x30
#define TestSel1Reg 0x31
#define TestSel2Reg 0x32
#define TestPinEnReg 0x33
#define TestPinValueReg 0x34
#define TestBusReg 0x35
#define AutoTestReg 0x36
#define VersionReg 0x37
#define AnalogTestReg 0x38
#define TestDAC1Reg 0x39
#define TestDAC2Reg 0x3A
#define TestADCReg 0x3B
#define Reserved31 0x3C
#define Reserved32 0x3D
#define Reserved33 0x3E
#define Reserved34         0x3F
//4 bytes card serial number, the first 5 bytes for the checksum byte
uchar serNum[5];
uchar writeData[16]={0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 100}; //Initialization 100 dollars
uchar moneyConsume = 18 ; //Consumption of 18 yuan
uchar moneyAdd = 10 ; //Recharge 10 yuan
//Sector A password, 16 sectors, each sector password 6Byte
uchar sectorKeyA[16][16] = {{0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF},
//{0x19, 0x84, 0x07, 0x15, 0x76, 0x14},
uchar sectorNewKeyA[16][16] = {{0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF},
{0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xff,0x07,0x80,0x69, 0x19,0x84,0x07,0x15,0x76,0x14},
//you can set another ket , such as " 0x19, 0x84, 0x07, 0x15, 0x76, 0x14 "
//{0x19, 0x84, 0x07, 0x15, 0x76, 0x14, 0xff,0x07,0x80,0x69, 0x19,0x84,0x07,0x15,0x76,0x14},
// but when loop, please set the sectorKeyA, the same key, so that RFID module can read the card
{0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xff,0x07,0x80,0x69, 0x19,0x33,0x07,0x15,0x34,0x14},
void setup() {
Serial.begin(9600); // RFID reader SOUT pin connected to Serial RX pin at 2400bps
// start the SPI library:
SPI.begin();
pinMode(chipSelectPin,OUTPUT); // Set digital pin 10 as OUTPUT to connect it to the RFID /ENABLE pin
digitalWrite(chipSelectPin, LOW); // Activate the RFID reader
pinMode(NRSTPD,OUTPUT); // Set digital pin 10 , Not Reset and Power-down
digitalWrite(NRSTPD, HIGH);
MFRC522_Init();
Serial.println("OK");
void loop()
    uchar i,tmp, checksum1;
    uchar status;
uchar str[MAX_LEN];
uchar RC_size;
uchar blockAddr;    //Selection operation block address 0 to 63
String mynum = "";
        //Find cards, return card type
        status = MFRC522_Request(PICC_REQIDL, str);
        if (status == MI_OK)
//Serial.println("Card detected");
            //Serial.print(str[0],BIN);
//Serial.print(" , ");
            //Serial.print(str[1],BIN);
//Serial.println(" ");
        //Anti-collision, return card serial number 4 bytes
        status = MFRC522_Anticoll(str);
        memcpy(serNum, str, 5);
checksum1 = serNum[0] ^ serNum[1] ^ serNum[2] ^ serNum[3];
//Serial.println("The card's number is : ");
            Serial.print(2);
            Serial.print(serNum[0]);
            Serial.print(serNum[1],BIN);
            Serial.print(serNum[2],BIN);
            Serial.print(serNum[3],BIN);
            Serial.print(serNum[4],BIN);
Serial.print(checksum1);
            Serial.println(3);
// Should really check all pairs, but for now we'll just use the first
// if(serNum[0] == 88) {
// Serial.println("Hello Grant");
// } else if(serNum[0] == 173) {
// Serial.println("Hello David");
delay(1000);
        MFRC522_Halt();            //Command card into hibernation
* Function Name:Write_MFRC5200
* Function Description: To a certain MFRC522 register to write a byte of data
* Input Parameters:addr - register address; val - the value to be written
* Return value: None
void Write_MFRC522(uchar addr, uchar val)
    //Address Format:0XXXXXX0
    SPI.transfer((addr<<1)&0x7E);
    SPI.transfer(val);
    digitalWrite(chipSelectPin, HIGH);
* Function Name:Read_MFRC522
* Description: From a certain MFRC522 read a byte of data register
* Input Parameters: addr - register address
* Returns: a byte of data read from the
uchar Read_MFRC522(uchar addr)
    uchar val;
    //Address Format:1XXXXXX0
    SPI.transfer(((addr<<1)&0x7E) | 0x80);
    val =SPI.transfer(0x00);
    return val;
* Function Name:SetBitMask
* Description: Set RC522 register bit
* Input parameters: reg - register address; mask - set value
void SetBitMask(uchar reg, uchar mask)
uchar tmp;
tmp = Read_MFRC522(reg);
Write_MFRC522(reg, tmp | mask); // set bit mask
* Function Name: ClearBitMask
* Description: clear RC522 register bit
* Input parameters: reg - register address; mask - clear bit value
void ClearBitMask(uchar reg, uchar mask)
uchar tmp;
Write_MFRC522(reg, tmp & (~mask)); // clear bit mask
* Function Name:AntennaOn
* Description: Open antennas, each time you start or shut down the natural barrier between the transmitter should be at least 1ms interval
* Input: None
void AntennaOn(void)
    uchar temp;
    temp = Read_MFRC522(TxControlReg);
    if (!(temp & 0x03))
        SetBitMask(TxControlReg, 0x03);
* Function Name: AntennaOff
* Description: Close antennas, each time you start or shut down the natural barrier between the transmitter should be at least 1ms interval
* Input: None
void AntennaOff(void)
    ClearBitMask(TxControlReg, 0x03);
* Function Name: ResetMFRC522
* Description: Reset RC522
* Input: None
void MFRC522_Reset(void)
Write_MFRC522(CommandReg, PCD_RESETPHASE);
* Function Name:InitMFRC522
* Description: Initialize RC522
* Input: None
void MFRC522_Init(void)
    digitalWrite(NRSTPD,HIGH);
    MFRC522_Reset();
    //Timer: TPrescaler*TreloadVal/6.78MHz = 24ms
Write_MFRC522(TModeReg, 0x8D);        //Tauto=1; f(Timer) = 6.78MHz/TPreScaler
Write_MFRC522(TPrescalerReg, 0x3E);    //TModeReg[3..0] + TPrescalerReg
Write_MFRC522(TReloadRegL, 30);
Write_MFRC522(TReloadRegH, 0);
    Write_MFRC522(TxAutoReg, 0x40);        //100%ASK
    Write_MFRC522(ModeReg, 0x3D);        //CRC Initial value 0x6363    ???
    //ClearBitMask(Status2Reg, 0x08);        //MFCrypto1On=0
    //Write_MFRC522(RxSelReg, 0x86);        //RxWait = RxSelReg[5..0]
    //Write_MFRC522(RFCfgReg, 0x7F);         //RxGain = 48dB
    AntennaOn();        //Open the antenna
* Function Name:MFRC522_Request
* Description: Find cards, read the card type number
* Input parameters: reqMode - find cards way
*             TagType - Return Card Type
*                 0x4400 = Mifare_UltraLight
*                0x0400 = Mifare_One(S50)
*                0x0200 = Mifare_One(S70)
*                0x0800 = Mifare_Pro(X)
*                0x4403 = Mifare_DESFire
* Return value: the successful return MI_OK
uchar MFRC522_Request(uchar reqMode, uchar *TagType)
    uchar status;
    uint backBits;            //The received data bits
    Write_MFRC522(BitFramingReg, 0x07);        //TxLastBists = BitFramingReg[2..0]    ???
    TagType[0] = reqMode;
    status = MFRC522_ToCard(PCD_TRANSCEIVE, TagType, 1, TagType, &backBits);
    if ((status != MI_OK) || (backBits != 0x10))
        status = MI_ERR;
    return status;
* Function Name: MFRC522_ToCard
* Description: RC522 and ISO14443 card communication
* Input Parameters: command - MF522 command word,
*             sendData--RC522 sent to the card by the data
*             sendLen--Length of data sent
*             backData--Received the card returns data,
*             backLen--Return data bit length
uchar MFRC522_ToCard(uchar command, uchar *sendData, uchar sendLen, uchar *backData, uint *backLen)
uchar status = MI_ERR;
uchar irqEn = 0x00;
uchar waitIRq = 0x00;
uchar lastBits;
uchar n;
uint i;
switch (command)
case PCD_AUTHENT:        //Certification cards close
            irqEn = 0x12;
            waitIRq = 0x10;
            break;
        case PCD_TRANSCEIVE:    //Transmit FIFO data
            irqEn = 0x77;
            waitIRq = 0x30;
            break;
        default:
            break;
Write_MFRC522(CommIEnReg, irqEn|0x80);    //Interrupt request
ClearBitMask(CommIrqReg, 0x80);            //Clear all interrupt request bit
SetBitMask(FIFOLevelReg, 0x80);            //FlushBuffer=1, FIFO Initialization
    Write_MFRC522(CommandReg, PCD_IDLE);    //NO action; Cancel the current command???
    //Writing data to the FIFO
for (i=0; i<sendLen; i++)
        Write_MFRC522(FIFODataReg, sendData);
    //Execute the command
    Write_MFRC522(CommandReg, command);
if (command == PCD_TRANSCEIVE)
        SetBitMask(BitFramingReg, 0x80);        //StartSend=1,transmission of data starts
    //Waiting to receive data to complete
    i = 2000;    //i according to the clock frequency adjustment, the operator M1 card maximum waiting time 25ms???
do
        //CommIrqReg[7..0]
        //Set1 TxIRq RxIRq IdleIRq HiAlerIRq LoAlertIRq ErrIRq TimerIRq
n = Read_MFRC522(CommIrqReg);
i--;
while ((i!=0) && !(n&0x01) && !(n&waitIRq));
ClearBitMask(BitFramingReg, 0x80);            //StartSend=0
if (i != 0)
if(!(Read_MFRC522(ErrorReg) & 0x1B))    //BufferOvfl Collerr CRCErr ProtecolErr
status = MI_OK;
if (n & irqEn & 0x01)
                status = MI_NOTAGERR;            //??
    n = Read_MFRC522(FIFOLevelReg);
    lastBits = Read_MFRC522(ControlReg) & 0x07;
if (lastBits)
                    *backLen = (n-1)*8 + lastBits;
else
                    *backLen = n*8;
if (n == 0)
                    n = 1;
if (n > MAX_LEN)
                    n = MAX_LEN;
                //Reading the received data in FIFO
for (i=0; i<n; i++)
                    backData = Read_MFRC522(FIFODataReg);
else
            status = MI_ERR;
//SetBitMask(ControlReg,0x80); //timer stops
//Write_MFRC522(CommandReg, PCD_IDLE);
return status;
* Function Name: MFRC522_Anticoll
* Description: Anti-collision detection, reading selected card serial number card
* Input parameters: serNum - returns 4 bytes card serial number, the first 5 bytes for the checksum byte
uchar MFRC522_Anticoll(uchar *serNum)
uchar status;
uchar i;
    uchar serNumCheck=0;
uint unLen;
//ClearBitMask(Status2Reg, 0x08);        //TempSensclear
//ClearBitMask(CollReg,0x80);            //ValuesAfterColl
    Write_MFRC522(BitFramingReg, 0x00);        //TxLastBists = BitFramingReg[2..0]
serNum[0] = PICC_ANTICOLL;
serNum[1] = 0x20;
status = MFRC522_ToCard(PCD_TRANSCEIVE, serNum, 2, serNum, &unLen);
        //Check card serial number
        for (i=0; i<4; i++)
             serNumCheck ^= serNum;
        if (serNumCheck != serNum)
            status = MI_ERR;
//SetBitMask(CollReg, 0x80);        //ValuesAfterColl=1
return status;
* Function Name: CalulateCRC
* Description: CRC calculation with MF522
* Input parameters: pIndata - To read the CRC data, len - the data length, pOutData - CRC calculation results
void CalulateCRC(uchar *pIndata, uchar len, uchar *pOutData)
uchar i, n;
ClearBitMask(DivIrqReg, 0x04);            //CRCIrq = 0
SetBitMask(FIFOLevelReg, 0x80);            //Clear the FIFO pointer
for (i=0; i<len; i++)
        Write_MFRC522(FIFODataReg, *(pIndata+i));
Write_MFRC522(CommandReg, PCD_CALCCRC);
    //Wait CRC calculation is complete
i = 0xFF;
do
n = Read_MFRC522(DivIrqReg);
i--;
while ((i!=0) && !(n&0x04));            //CRCIrq = 1
    //Read CRC calculation result
pOutData[0] = Read_MFRC522(CRCResultRegL);
pOutData[1] = Read_MFRC522(CRCResultRegM);
* Function Name: MFRC522_SelectTag
* Description: election card, read the card memory capacity
* Input parameters: serNum - Incoming card serial number
* Return value: the successful return of card capacity
uchar MFRC522_SelectTag(uchar *serNum)
uchar i;
    uchar status;
    uchar size;
uint recvBits;
uchar buffer[9];
buffer[0] = PICC_SElECTTAG;
buffer[1] = 0x70;
for (i=0; i<5; i++)
    buffer[i+2] = *(serNum+i);
    CalulateCRC(buffer, 7, &buffer[7]);        //??
status = MFRC522_ToCard(PCD_TRANSCEIVE, buffer, 9, buffer, &recvBits);
if ((status == MI_OK) && (recvBits == 0x18))
        size = buffer[0];
else
        size = 0;
return size;
* Function Name: MFRC522_Auth
* Description: Verify card password
* Input parameters: authMode - Password Authentication Mode
0x60 = A key authentication
0x61 = Authentication Key B
BlockAddr--Block address
Sectorkey--Sector password
serNum--Card serial number, 4-byte
uchar MFRC522_Auth(uchar authMode, uchar BlockAddr, uchar *Sectorkey, uchar *serNum)
uchar status;
uint recvBits;
uchar i;
    uchar buff[12];
    //Verify the command block address + sector + password + card serial number
buff[0] = authMode;
buff[1] = BlockAddr;
for (i=0; i<6; i++)
        buff[i+2] = *(Sectorkey+i);
for (i=0; i<4; i++)
        buff[i+8] = *(serNum+i);
status = MFRC522_ToCard(PCD_AUTHENT, buff, 12, buff, &recvBits);
if ((status != MI_OK) || (!(Read_MFRC522(Status2Reg) & 0x08)))
        status = MI_ERR;
return status;
* Function Name: MFRC522_Read
* Description: Read block data
* Input parameters: blockAddr - block address; recvData - read block data
uchar MFRC522_Read(uchar blockAddr, uchar *recvData)
uchar status;
uint unLen;
recvData[0] = PICC_READ;
recvData[1] = blockAddr;
CalulateCRC(recvData,2, &recvData[2]);
status = MFRC522_ToCard(PCD_TRANSCEIVE, recvData, 4, recvData, &unLen);
if ((status != MI_OK) || (unLen != 0x90))
status = MI_ERR;
return status;
* Function Name: MFRC522_Write
* Description: Write block data
* Input parameters: blockAddr - block address; writeData - to 16-byte data block write
uchar MFRC522_Write(uchar blockAddr, uchar *writeData)
uchar status;
uint recvBits;
uchar i;
    uchar buff[18];
buff[0] = PICC_WRITE;
buff[1] = blockAddr;
CalulateCRC(buff, 2, &buff[2]);
status = MFRC522_ToCard(PCD_TRANSCEIVE, buff, 4, buff, &recvBits);
if ((status != MI_OK) || (recvBits != 4) || ((buff[0] & 0x0F) != 0x0A))
        status = MI_ERR;
for (i=0; i<16; i++)        //Data to the FIFO write 16Byte
    buff = *(writeData+i);
CalulateCRC(buff, 16, &buff[16]);
status = MFRC522_ToCard(PCD_TRANSCEIVE, buff, 18, buff, &recvBits);
            status = MI_ERR;
return status;
* Function Name: MFRC522_Halt
* Description: Command card into hibernation
* Input: None
void MFRC522_Halt(void)
    uchar status;
uint unLen;
uchar buff[4];
buff[0] = PICC_HALT;
buff[1] = 0;
status = MFRC522_ToCard(PCD_TRANSCEIVE, buff, 4, buff,&unLen);
Funciona normal, ao passar a tag, o código é exibido pelo serial monitor, porém, não consigo aplicar esse código para desempenhar uma função, como acionar um relé, apitar um buzzer...
Alguém poderia me ajudar quanto a isso?
Obrigado!
Ps: Tentei fazer sozinho isso, mas não consegui, por isso recorro a vocês.
Cara, um colega nosso do fórum fez este tutorial, o dele é pra ensinar a base pra começar a mexer no RFID, mas pelo que vi o código é bem completo e pode te ajudar em alguma coisa....
http://forum.clubedohardware.com.br/forums/topic/1061005-mini-tutorial-rfid-mikroc/
de qualquer forma eu cito ele aqui pra ter uma maior chance de ele ver seu tópico e te ajudar, já que faz um tempinho que não vejo ele por aqui :P  :P ....
@LuizGBarrio =D
flowww
Hum.. Acabei de ler o tópico dele, porém não consegui entender muito aqueles códigos, ainda mais que não é voltado para o arduino, e sim para o MikroC. Entendi sobre a placa, mas não sobre o código.. Ele disse nos comentários que já havia estrutura pronta na internet, que é o que eu postei acima, e funciona, porém, não consigo desempenhar uma ação justamente pelo código ser complicado (na minha opnião rsrs).
Penso que se quero desempenhar algo no código, ele estará próximo do Serial.print que imprime o valor do cartão, porém há vários prints, como se o cada print, imprimisse uma parte do código, complicando ainda mais.
Vou continuar tentando, mas gostaria de um empurrão para ajudar.
valeu!
Olá, encontrei outro código, que me parece ser mais fácil de usar. Vou postar ele aqui, e quem puder me ajudar a adaptar esse código para que ao passar um cartão específico, ele faça algo.
Inicialmente, ao passar qualquer cartão, ele apita um buzzer e imprime 5 valores DEC e 5 valores HEX. Estava pensando em uma forma de usar esses valores, que é diferente de cartão para cartão, para que quando identificado fizesse alguma ação.
Segue o código abaixo:
/*** Read a card using a mfrc522 reader on your SPI interface* Pin layout should be as follows (on Arduino Uno):* MOSI: Pin 11 / ICSP-4* MISO: Pin 12 / ICSP-1* SCK: Pin 13 / ISCP-3* SS: Pin 10* RST: Pin 9** Script is based on the script of Miguel Balboa. * New cardnumber is printed when card has changed. Only a dot is printed* if card is the same.** @version 0.1* @author Henri de Jong* @since 06-01-2013*/#include <SPI.h>#include <RFID.h>#define SS_PIN 10#define RST_PIN 9RFID rfid(SS_PIN, RST_PIN); int buzzPin = 3;// Setup variables:    int serNum0;    int serNum1;    int serNum2;    int serNum3;    int serNum4;void setup(){   Serial.begin(9600);  SPI.begin();   rfid.init();}void loop(){        if (rfid.isCard()) {        if (rfid.readCardSerial()) {            if (rfid.serNum[0] != serNum0                && rfid.serNum[1] != serNum1                && rfid.serNum[2] != serNum2                && rfid.serNum[3] != serNum3                && rfid.serNum[4] != serNum4            ) {                /* With a new cardnumber, show it. */                Serial.println(" ");                Serial.println("Card found");                serNum0 = rfid.serNum[0];                serNum1 = rfid.serNum[1];                serNum2 = rfid.serNum[2];                serNum3 = rfid.serNum[3];                serNum4 = rfid.serNum[4];                               //Serial.println(" ");                Serial.println("Cardnumber:");                Serial.print("Dec: ");		Serial.print(rfid.serNum[0],DEC);                Serial.print(", ");		Serial.print(rfid.serNum[1],DEC);                Serial.print(", ");		Serial.print(rfid.serNum[2],DEC);                Serial.print(", ");		Serial.print(rfid.serNum[3],DEC);                Serial.print(", ");		Serial.print(rfid.serNum[4],DEC);                Serial.println(" ");                                        Serial.print("Hex: ");		Serial.print(rfid.serNum[0],HEX);                Serial.print(", ");		Serial.print(rfid.serNum[1],HEX);                Serial.print(", ");		Serial.print(rfid.serNum[2],HEX);                Serial.print(", ");		Serial.print(rfid.serNum[3],HEX);                Serial.print(", ");		Serial.print(rfid.serNum[4],HEX);                Serial.println(" ");                //buzzer                analogWrite(3,20);                delay(500);                analogWrite(3,0);             } else {               /* If we have the same ID, just write a dot. */               Serial.print(".");             }          }    }        rfid.halt();}
Fico no aguardo.
Obrigado!
pra você fazer o que você quiser, me parece que é só substituir esta parte no código pela função que você quer executar.....
 /* With a new cardnumber, show it. */Serial.println(" ");Serial.println("Card found");serNum0 = rfid.serNum[0];serNum1 = rfid.serNum[1];serNum2 = rfid.serNum[2];serNum3 = rfid.serNum[3];serNum4 = rfid.serNum[4];//Serial.println(" ");Serial.println("Cardnumber:");Serial.print("Dec: ");        Serial.print(rfid.serNum[0],DEC);Serial.print(", ");        Serial.print(rfid.serNum[1],DEC);Serial.print(", ");        Serial.print(rfid.serNum[2],DEC);Serial.print(", ");        Serial.print(rfid.serNum[3],DEC);Serial.print(", ");        Serial.print(rfid.serNum[4],DEC);Serial.println(" ");Serial.print("Hex: ");        Serial.print(rfid.serNum[0],HEX);Serial.print(", ");        Serial.print(rfid.serNum[1],HEX);Serial.print(", ");        Serial.print(rfid.serNum[2],HEX);Serial.print(", ");        Serial.print(rfid.serNum[3],HEX);Serial.print(", ");        Serial.print(rfid.serNum[4],HEX);Serial.println(" ");//buzzeranalogWrite(3,20);delay(500);analogWrite(3,0);
ela fica no código onde eu tentei destacar e coloquei umas setas......
 /*** Read a card using a mfrc522 reader on your SPI interface* Pin layout should be as follows (on Arduino Uno):* MOSI: Pin 11 / ICSP-4* MISO: Pin 12 / ICSP-1* SCK: Pin 13 / ISCP-3* SS: Pin 10* RST: Pin 9** Script is based on the script of Miguel Balboa.* New cardnumber is printed when card has changed. Only a dot is printed* if card is the same.** @version 0.1* @author Henri de Jong* @since 06-01-2013*/#include <SPI.h>#include <RFID.h>#define SS_PIN 10#define RST_PIN 9RFID rfid(SS_PIN, RST_PIN); int buzzPin = 3;// Setup variables:int serNum0;int serNum1;int serNum2;int serNum3;int serNum4;void setup(){ Serial.begin(9600);SPI.begin();rfid.init();}void loop(){if (rfid.isCard()) {if (rfid.readCardSerial()) {if (rfid.serNum[0] != serNum0&& rfid.serNum[1] != serNum1&& rfid.serNum[2] != serNum2&& rfid.serNum[3] != serNum3&& rfid.serNum[4] != serNum4) {------------->/* With a new cardnumber, show it. */                     Serial.println(" ");                     Serial.println("Card found");                     serNum0 = rfid.serNum[0];                     serNum1 = rfid.serNum[1];                     serNum2 = rfid.serNum[2];                     serNum3 = rfid.serNum[3];                     serNum4 = rfid.serNum[4];                     //Serial.println(" ");                     Serial.println("Cardnumber:");                     Serial.print("Dec: ");                             Serial.print(rfid.serNum[0],DEC);                     Serial.print(", ");                             Serial.print(rfid.serNum[1],DEC);                     Serial.print(", ");                             Serial.print(rfid.serNum[2],DEC);                     Serial.print(", ");                             Serial.print(rfid.serNum[3],DEC);                     Serial.print(", ");                             Serial.print(rfid.serNum[4],DEC);                     Serial.println(" ");                     Serial.print("Hex: ");                             Serial.print(rfid.serNum[0],HEX);                     Serial.print(", ");                             Serial.print(rfid.serNum[1],HEX);                     Serial.print(", ");                             Serial.print(rfid.serNum[2],HEX);                     Serial.print(", ");                             Serial.print(rfid.serNum[3],HEX);                     Serial.print(", ");                             Serial.print(rfid.serNum[4],HEX);                     Serial.println(" ");                     //buzzer                     analogWrite(3,20);                     delay(500);                     analogWrite(3,0); <----------------------} else {/* If we have the same ID, just write a dot. */Serial.print(".");}}}rfid.halt();}
substitua ai a função que você quer fazer que me parece que pode dar certo
flowwww
@mister nintendo
Olá, sinto muito, mas antes de você postar esse código, achei este site:
http://www.instructables.com/id/Security-System-and-Access-Control-with-Arduino-an/step2/Stuff-and-Materials/
Consegui fazer o que queria com o código que veio nele, e funciona muito bem. Mas muito obrigado pela ajuda, deixarei como resolvido nesse seu último post.
valeu!
