Tópico Central - Mod 6800GS para Ultra Extreme
Edu_Gnipper
Bom pessoal tenho a seguinte placa:
Descrição dela pelo RivaTuner:
$ffffffffff ----------------------------------------------------------------
$ffffffffff Display adapter information
$0000000000 Description : NVIDIA GeForce 6800 XT
$0000000001 Vendor ID : 10de (NVIDIA)
$0000000002 Device ID : 0048
$0000000003 Location : bus 1, device 0, function 0
$0000000004 Bus type : AGP revision 3.0
$0000000005 AGP status : enabled
$0000000006 AGP rate : 4x 8x supported, 8x selected
$0000000007 AGP SBA : hardwired, enabled
$0000000008 AGP FW : supported, enabled
$0000000009 Base address 0 : fb000000 (memory range)
$000000000a Base address 1 : c0000000 (memory range)
$000000000b Base address 2 : fa000000 (memory range)
$000000000c Base address 3 : none
$000000000d Base address 4 : none
$000000000e Base address 5 : none
$ffffffffff NVIDIA specific display adapter information
$0100000000 Graphics core : NV40 revision A1 (12pp,5vp)
$0100000001 Hardwired ID : 0041 (ROM strapped to 0048)
$0100000002 Memory bus : 128-bit
$0100000003 Memory type : DDR3 (RAM configuration 06)
$0100000004 Memory amount : 262144KB
$0100000005 Core clock : 351.000MHz
$0100000006 Memory clock : 401.625MHz (803.250MHz effective)
$0100000007 Reference clock : 27.000MHz
$010000000b HW masked units : pixel 1100b, vertex 101000b
Agora pergunto se eu fizer o que esta descrito aqui nesse tutorial também vai dar certo ou esta placa não é comptaivel?
Parece que sua XT já esta com os pipes ativados.
Olha a descrição da minha.
$0100000000 Graphics core : NV41 revision A2 (8pp,4vp)
$0100000001 Hardwired ID : 00c0 (ROM strapped to 00c3)
$0100000002 Memory bus : 256-bit
$0100000003 Memory type : DDR3 (RAM configuration 05)
$0100000006 Memory clock : 501.188MHz (1002.375MHz effective)
$010000000c HSI bridge : BR02 PCIE-to-AGP
Mas fiz o que manda aqui e ela passou para isso:
$0100000000 Graphics core : NV40 revision A1 (16pp,6vp)
Incrível cara!!
Agora teste no 3dmark e olhe o quanto que aumentou!
Fala ai pra gente!
Abraço
Incrível cara!!
Fala ai pra gente!
Abraço
Cara com os pipes em 12pp 5vp ela deu 42,614 e com 16pp e 6vp ela deu 43229
Esta certo isso ? Da pouca diferença assim ?
Para testar joguei NFSU2 por uns 20 minutos e rodou tudo de boa.
Com essa config do jeito que esta preciso colocar outro cooler nela ou o original que vem nela da conta do recado ?
Tem mais alguma coisa que posso mudar para melhorar mais ?
você tem sorte. Eu tenho uma placa dessa e só consegui ativar 12pp e 6vp. Ela rodou tudo de boa mesmo, ou seja, sem nenhuma falha na imagem nem nada? você habilitou todas as opções do jogo? Digo isso, pois na minha placa quando joguei o FIFA 06 ela ficou perfeita, mas quando rodei o NFSC apareceram diversos artefatos.
Quanto ao cooler, acho melhor você trocar. Comprei um da Extream http://www.extream.com.br/produtos-pages/col-plvid-01_cu.htm.
Ainda não instalei, pois estou meio sem tempo, por isso não posso te dar mais detalhes.
Quanto a melhora de desempenho, você pode tentar fazer um over maior.
Espero ter ajudado.
A pouca diferença se devo ao gargalo do seu processador e da placa mãe. Quando você trocar os 2, vai melhorar consideravelmente. Acredito eu que deve dar em torno de 60mil pontos ou mais.
Abraço
Espero ter ajudado.
Boa tarde raolcars.
Joguei com as opções de video 1024x768 com tudo no máximo e funcionou de boa. Agora a noite vou testar com NFSC pois tenho ele instalado em casa tb. O que você chama de artefatos ? Você sabe alguma loja onde posso encontrar esse cooler ? Outra coisa ela não tem como medir a temperatura dela não ?
Olá araojr.
Tem como você medir a temperatura da GPU (processador da placa de vídeo).
para isto você pode verificar usando um programa chamado EVEREST (http://www.lavalys.com/downloads/everestultimate400.zip) ou então olhar nas propriedades de vídeo, na aba da GeForce, como mostra a figura abaixo:
Olá araojr.
Cara o meu software da Geforce não tem essa opção ai não
Espero ter ajudado.
Cara joguei NFSC ontem cerca de 2hs e nao deu alteração nenhuma joguei com resolução de 1024x768 com tudo no maximo tem uma outra opção la mas nao testei com ela ainda mas ficou tudo numa boa. Do jeito que rodou ontem para mim esta ótimo.
Então realmente você tem sorte. Meus parabéns, você pegou uma placa com um potencial incrível. No outro post você perguntou o que são artefatos, certo? Então, são falhas na imagem, como por exemplo, uma televisão em que o canal tem aqueles "chuviscos".
Essa placa infelizmente não tem sensor de temperatura. Já tentei de tudo e acho que não tem mesmo. Quanto ao cooler, está difícil de achar mesmo. Na maioria das lojas só tem o de alumínio. Tenta ver na Noli e na Smartdata se já chegou ou compra o de alumínio mesmo que já tem um bom desempenho como o colega do link abaixo relatou.
http://forum.clubedohardware.com.br/review-cooler-extream/430196
Um abraço e espero ter ajudado.
Cara ajudou sim e muito, aproveito e agradeço a ajuda de todos que me ajudaram e peço desculpas por ter incomodado vocês.
E quais programas posso usar para capturar umas telas e mostrar para vocês verem se esta tudo certinho mesmo ?
As telas que você quer capturar são iguais as que o tiao_cachaca postou? Se sim, é só escolher a tela que você quer, apertar a tecla "Print screen", abrir o Paint ou outro programa do genero e mandar colar. Depois é só salvar e postar.
Se não for isso que você quer, tente ser mais específico para podermos ajudar.
Quero saber qual programa usar para poder mostrar para vocês como esta a config da minha placa para vocês poderem ver se esta tudo certinho mesmo. Saber capturar a tela e etc eu sei. E queria saber tb como colocar a imagem igual ele colocou no post.
Agora entendi...
Baixa o programa Everest (http://www.lavalys.com/products/download.php?ps=UE〈=en). Depois de instalar, vá na aba Monitor e em seguida GPU. Ele vai te mostrar todos os dados referentes a sua placa, aí é só capturar a tela.
Para colocar imagem no post, na tela de resposta do tópico, vá em opções adicionais e depois em gerenciar imagens. Depois é só colocar o link de hospedagem ou pedir para procurar no seu micro.
Espero ter ajudado.
Agora entendi...
Espero ter ajudado.
Segue imagem de tela capturada do Everest.
Da para melhorar mais alguma coisa?
uahahu. Que isso cara!!
voce quase conseguiu transformar sua XT numa GT. Se ela fosse 256bit e dder 3, ela viraria uma GT.
Já está ótimo!!
Acho que forçar ela mais que isto pode danificar. Tente melhorar pelo overclock.
Mas agora, pra ter um desempenho bom mesmo, voce tem que trocar de computador.
Abraço
Concordo com o tiao_cachaca. Essa placa é espetacular. Tá realmente demais.
Quanto a melhorar mais, acredito que só com overclock mesmo. Com um over mais alto, garanto que o desempenho será ainda melhor.
Uma abraço.
E ai pessoal estou aqui de volta.
Pessoal consegui melhorar mais um pouquinho a minha 6800XT agora ela esta assim:
16PP
6VP
390/800
No Aquamark3 esta dando 45883
Por enquanto foi o máximo que consegui com o que possuo que é:
ASUS P4V800D-X || P4 2.8 Northwood @ 2.900|| Memoria: 2 x 512 DDR 400 Dual Channel Samsung || Placa de Video Zogis 6800XT AGP 8x 256MB 128 Bits || HD 40GB Seagate Barracuda 7200 RPM || Gravador de DVD LG || Monitor 15 LCD LG Flatron || Home Theater 5.1 || WIN XP Prof SP2
16PP
6VP
390/800
Ola amigo, acredito que pra melhorar agora, só trocando sua placa-mãe e processadores, pois o grande gargalo é eles.
Parabens, muito boa sua vga
Amigo, voce poderia postar um print da parte que voce habilita o pixel no Riva tuner?
Abraço
