Vaio VGNFW35GB para design gráfico o que vcs me dizem?
mizerko
Gente gostaria de uma ajuda para um notebook. Irei usar para trabalho gráfico (Adobe suite CS4, Corel X4 e 3dMax para modelagem). Alguem poderá me dar um opinião sobre esta configuração?
Obrigado!
Operating System
Operating SystemGenuine Windows Vista® Home Premium 32-bit (English Version) with Service Pack 1Language PackHong Kong Chinese, Simplified Chinese, Arabic, ThaiLanguage Interface PackVietnamese
Architecture
Processor TechnologyIntel® Centrino® 2 Processor TechnologyProcessor NameIntel® Core™2 Duo Processor P8600 (2.40 GHz)*1*2Network ConnectionIntel® WiFi Link 5100ChipsetMobile Intel® PM45 Express ChipsetProcessor System Bus1066 MHzMemory Bus800 MHzCache Memory3 MB
Main Memory
Pre-installed/Max3 GB DDR2 SDRAM*3*4SO-DIMM Slots2 SO-DIMM slots (The pre-installed memory module uses two)
Hard Disk Drive
Hard Disk Drive400 GB*5 (Serial ATA, 5400 rpm)
Optical Disc Drive
DriveDVD±RW/±R DL/RAM DriveMaximum Reading SpeedDVD+R: 8x (SL), 6x (DL)/DVD-R: 8x (SL), 6x (DL)/DVD+RW: 8x/DVD-RW: 8x/DVD-ROM: 8x/DVD-RAM: 5x/CD-ROM: 24x/CD-R: 24x/CD-RW: 24xMaximum Writing SpeedDVD+R: 8x (SL), 6x (DL)/DVD-R: 8x (SL), 6x (DL)DVD+RW: 8x/DVD-RW: 6x/DVD-RAM: 5x/CD-R: 24x/CD-RW: 24x
Graphics
Graphics AcceleratorATI Mobility Radeon™ HD 3470Dedicated Video Memory256 MB
Display
Type16.4" wide (WXGA++: 1600 x 900) TFT colour display (Clear Bright LCD [Rich Colour])
Interface
USBHigh Speed USB 2.0 x 3i.LINK(IEEE 1394)4 pin (S400) x 1Network (RJ-45)Connector10Base-T/100Base-TX / 1000Base-T x 1Display Output ConnectorAnalogue RGB, mini D-sub 15 pin x 1HeadphoneStereo mini jack x 1MicrophoneStereo mini jack x 1HDMI In/Out ConnectorOutput x 1ModemV.92 and V.90 Compliant x 1Memory Stick SlotMemory Stick (Standard/Duo Size compatible, MagicGate compatible, Memory Stick PRO compatible, High-speed data transfer compatible)*6SD Memory Card SlotSD Memory Card*7 (SDHC compatible, MMC compatible)PC Card SlotExpressCard™/34 x 1DC INx 1
Wireless Connection
Wireless LAN TypeIntegrated Wireless LAN IEEE 802.11a/b/g/Draft n*8Wireless LAN Data Ratemaximum 11Mbps (802.11b)/54 Mbps (802.11a/g) 300 Mbps (Draft 802.11n)*9Wireless LAN Frequency5 GHz (802.11a/Draft n), 2.4 GHz (802.11b/g/Draft n)BluetoothBluetooth standard Ver. 2.1+EDR
Camera
Front Side CameraEffective pixels: 1280 x 1024
Audio
Sound ChipIntel® High Definition Audio compatible , 3D audio (Direct Sound 3D support)SpeakerBuilt-in stereo speakersMicrophoneBuilt-in monaural microphone
Keyboard/Input Device
KeyboardApprox. 19 mm key pitch/2 mm keystroke , 86keysTouchpadIntelligent Touchpad
Battery Life*10
Bundled BatteryVGP-BPS13/S Lithium-ion battery: up to 2.5 hours of useOptional Long BatteryVGP-BPL13 Lithium-ion battery: up to 4.5 hours of use
Size
Dimensions (WxHxD)384 x 29.0 -37.0 x 261 mmWeight3.1 kg (including the supplied battery)
Included Software
AV EntertainmentWindows® Media center SP1Video Edit/PlaybackVAIO Movie Story, Adobe® Premiere® Elements® 7, VAIO Edit Components, WinDVD for VAIODVD CreationClick to Disc, Click to Disc EditorMusicVAIO MusicBox, SonicStage Mastering StudioStill Image/PhotoPMB (Picture Motion Browser), Windows® Photo Gallery, Adobe® Photoshop® Elements® 7Home NetworkVAIO Media plusWord Processor / Spreadsheet60-Day Trial Version of Microsoft® Office Professional 2007*11ToolRoxio Easy Media Creator, Adobe® Reader® 9, McAfee PC SecurityCenter 90-day Free Trial*12UtilitiesVAIO Control Center, VAIO Presentation Support, VAIO Launcher, WebCam Companion, Magic-i™ Visual EffectsSupportVAIO Recovery Center, VAIO Update, VAIO Data Restore Tool
Supplied Accessories
AC AdaptorAC Adaptor (VGP-AC19V24)BatteryLithium-ion battery (VGP-BPS13/S)*13
Acho que a Sony não tem esquema de garantia internacional, melhor verificar. Entra em contato com suporte da Sony e pergunta.
HP eu sei que não tem, só dão garantia para modelos nacionais.
Que tem garantia internacional e alto padrão de qualidade que eu conheço é Gateway e Asus, mas dae você precisa pagar todos os impostos e tal pra valer a garantia.
