Plugar Realtek em Receiver
Avanrj
Senhores,
Eu tenho uma DG33FB com esta configuração:
Desktop Board Features
This chapter briefly describes the features of Intel® Desktop Board DG33FB. Table 1
summarizes the major features of the Desktop Board.
Table 1. Feature Summary
Form Factor ATX (320.04 millimeters [11.60 inches] x 243.84 millimeters
[9.60 inches])
Processor Support for an Intel® processor in the LGA775 package
Main Memory • Four 240-pin, DDR2 1.8 V (only) SDRAM Dual Inline Memory Module
(DIMM) sockets
• 800/667 MHz single or dual channel DDR2 SDRAM interface
• Support for up to 8 GB of system memory
Chipset Intel® G33 Express Chipset consisting of:
• Intel G33 Express Chipset Graphics and Memory Controller Hub
(GMCH)
• Intel® 82801IH I/O Controller Hub (ICH9DH)
Graphics • Intel G33 Express Chipset with Intel® Graphics Media Accelerator
3100 (Intel® GMA 3100)
• One PCI Express* x16 connector supporting PCI Express graphics
cards
Audio • 6-channel (5.1) onboard subsystem, featuring:
Intel® High Definition Audio interface
RealTek* ALC888 audio codec
Expansion
Capabilities
• One PCI Express x16 connector
• Three PCI Express x1 connectors
• Three PCI connectors
Legacy I/O Support Legacy I/O Controller that provides:
― One diskette drive interface
― One serial port header
― PS/2* keyboard and mouse ports
Peripheral
Interfaces
• Up to 12 USB 2.0 ports
― Six ports routed to the back panel
― Six ports routed to three USB headers
• Up to two IEEE 1394a ports
― One port routed to the back panel
― One port routed to an IEEE 1394a header
• Four Serial ATA (SATA) channels (3.0 Gb/s), via the ICH9DH
• One IDE interface with ATA-66/100 support (two devices)
E tudo que fala sobre o Audio é o seguinte:
Audio Subsystem
The onboard audio subsystem consists of the following:
• Intel ICH9DH I/O controller hub
• RealTek ALC888 audio codec
• Back panel audio connectors
• Intel High Definition audio front panel audio header
The audio subsystem supports the following features:
• A signal-to-noise (S/N) ratio of 95 dB
• Independent multi-streaming 5.1 audio (using the back panel audio connectors)
and stereo (using the Intel High Definition front panel audio header).
Related Links:
Go to the following link or pages for more information about:
• Installing the front panel audio solution, page 46
• The location of audio connectors, Figure 24 on page 49
Page 46
Installing a Front Panel Audio Solution for Intel® High
Definition Audio
Figure 23, B shows the location of the front panel audio header. Table 5 shows the pin
assignments for the front panel audio header.
Table 5. Front Panel Audio Header Signal Names for Intel High Definition
Audio
Pin Signal Name Pin Signal Name
1 PORT 1L 2 GND
3 PORT 1R 4 PRESENCE#
5 PORT 2R 6 SENSE1_RETURN
7 SENSE_SEND 8 KEY (no pin)
9 PORT 2L 10 SENSE2_RETURN
To install the cable that connects the front panel audio solution to the front panel
audio header, follow these steps:
1. Observe the precautions in "Before You Begin" on page 25.
2. Turn off all peripheral devices connected to the computer. Turn off the computer
and disconnect the AC power cord.
3. Remove the cover.
4. Install a correctly keyed and shielded front panel audio cable.
Figure 24 / Page 49:
Connecting to the Flexible Audio System
After installing the RealTek audio driver from the Intel Express Installer CD-ROM, the
multi-channel audio feature can be enabled. Figure 24 shows the back panel audio
connectors. The default connector assignments are shown in the table.
NOTE
The back panel line out connector is designed to power either headphones or amplified
speakers only. Poor audio quality may occur if passive (non-amplified) speakers are
connected to this output.
A grande pergunta é: se é 5.1 e só tem três plugues estéreos disponíveis como se faz a distribuição para encaixar no Receiver, na entrada 5.1 (MULTI CH INPUT), mantendo o microfone?
Cara, não entendi direito sua pergunta. Sua placa de som on-board tem 3 saídas (5.1) somente? não tem entrada microfone ou line-in independente não? mic seria compartilhado com uma das saídas é?
Mostrar mais
Mostrar mais
