Ah, sim... É que lendo seu post, parecia que você tinha dito que o GPU3 nas duas GTX 260 estava segurando o seu Phenom... :D
Eu também entendi da mesma forma que o VIX entendeu, parece que os clientes GPUs tira todo o potêncial do cliente CPU.
Falowwww ae.PANAO
GTX260 - 630/1516/1000 - WU 10513 - PPD 9221 :eek:
[07:18:33] Project: 10513 (Run 8, Clone 562, Gen 220)
[07:18:33]
[07:18:33] Assembly optimizations on if available.
[07:18:33] Entering M.D.
[07:18:39] Tpr hash work/wudata_01.tpr: 3720490248 1812140775 4239829409 4221923332 4103234991
[07:18:39]
[07:18:39] Calling fah_main args: 14 usage=100
[07:18:39]
[07:18:40] Working on Protein
[07:18:40] Client config found, loading data.
[07:18:41] Starting GUI Server
[07:19:36] Completed 1%
[07:20:31] Completed 2%
[07:21:27] Completed 3%
[07:22:23] Completed 4%
[07:23:18] Completed 5%
[07:24:14] Completed 6%
[07:25:10] Completed 7%
[07:26:05] Completed 8%
[07:27:01] Completed 9%
[07:27:57] Completed 10%
[07:28:52] Completed 11%
[07:29:48] Completed 12%
[07:30:44] Completed 13%
[07:31:39] Completed 14%
[07:32:35] Completed 15%
[07:33:31] Completed 16%
[07:34:27] Completed 17%
[07:35:22] Completed 18%
[07:36:18] Completed 19%
[07:37:14] Completed 20%
[07:38:09] Completed 21%
[07:39:05] Completed 22%
[07:40:01] Completed 23%
[07:40:56] Completed 24%
[07:41:52] Completed 25%
[07:42:48] Completed 26%
[07:43:43] Completed 27%
[07:44:39] Completed 28%
[07:45:35] Completed 29%
[07:46:30] Completed 30%
[07:47:26] Completed 31%
[07:48:22] Completed 32%
[07:49:17] Completed 33%
[07:50:13] Completed 34%
[07:51:09] Completed 35%
[07:52:04] Completed 36%
[07:53:00] Completed 37%
[07:53:56] Completed 38%
[07:54:52] Completed 39%
[07:55:47] Completed 40%
[07:56:43] Completed 41%
[07:57:39] Completed 42%
[07:58:34] Completed 43%
[07:59:30] Completed 44%
[08:00:26] Completed 45%
[08:01:21] Completed 46%
[08:02:17] Completed 47%
[08:03:13] Completed 48%
[08:04:08] Completed 49%
[08:05:04] Completed 50%
[08:06:00] Completed 51%
[08:06:55] Completed 52%
[08:07:51] Completed 53%
[08:08:47] Completed 54%
[08:09:43] Completed 55%
[08:10:38] Completed 56%
[08:11:34] Completed 57%
[08:12:30] Completed 58%
[08:13:25] Completed 59%
[08:14:21] Completed 60%
[08:15:17] Completed 61%
[08:16:12] Completed 62%
[08:17:08] Completed 63%
[08:18:04] Completed 64%
[08:18:59] Completed 65%
[08:19:55] Completed 66%
[08:20:51] Completed 67%
[08:21:46] Completed 68%
[08:22:42] Completed 69%
[08:23:38] Completed 70%
[08:24:33] Completed 71%
[08:25:29] Completed 72%
[08:26:25] Completed 73%
[08:27:21] Completed 74%
[08:28:16] Completed 75%
[08:29:12] Completed 76%
[08:30:08] Completed 77%
[08:31:03] Completed 78%
[08:31:59] Completed 79%
[08:32:55] Completed 80%
[08:33:50] Completed 81%
[08:34:46] Completed 82%
[08:35:42] Completed 83%
[08:36:37] Completed 84%
[08:37:33] Completed 85%
[08:38:29] Completed 86%
[08:39:24] Completed 87%
[08:40:20] Completed 88%
[08:41:16] Completed 89%
[08:42:11] Completed 90%
[08:43:07] Completed 91%
[08:44:03] Completed 92%
[08:44:59] Completed 93%
[08:45:54] Completed 94%
[08:46:50] Completed 95%
[08:47:46] Completed 96%
[08:48:41] Completed 97%
[07:18:33]
[07:18:39]
[07:18:39]
Eita, conseguiu empatar com GTX 285 em stock... Adicionado. :joia:
Segue os dados do note que tenho, infelizmente quando testei que foi ontem o bendito chegou a 80º dai resolvi não dar andamento com folding nele...
P6025
i5-520M @2.4GHz(clock padrão) - turboboost para 2.66GHz(automatico) - 2x2GB Win 7 -> TPF: ~9mim:00seg, PPD: 3.469,86
P6025
Já está na tabela... :joia:
Ae galera agora o valor do meu novo brinquedo.
Lenovo Z460
Core i5 460M rodando no turbo 2660 mhz, 3 gb ddr 3 1066, win7 home basic.
WU 6701 (é uma merd4).:(
TPF - 22min e 27 segs PPD estimado 2347.
As temps estão ótimas 58 graus com o suporte com 3 fans claro.
Falou ae.PANAO.
Lenovo Z460
Falou ae.PANAO.
Adicionado. :joia:
Se você usa Windows 7 Home Basic mesmo que você tenha 4 Gb ele só reconhece 3 Gb certo?
Nas informações do sitema diz que tem 4gb mas que utilizável e apenas 3.80 gb. Esse Win é o home basic mas é a versão 64 bits.
Falou ae.PANAO.
Ola pessoal.
Comentei uns dias atrás sobre o baixo rendimento do cliente SMP quando está rodando o cliente GPU3 junto, fiz alguns testes e segue abaixo os resultados:
Sem cliente GPU ele rende aprox. 36.500ppd na 2684 com 4.15Ghz.
I7 980x com 4,15Ghz rodando apenas um cliente: GTS 450 32.464ppd
I7 980x com 4,15Ghz rodando dois clientes: GTS 450 e GTX 570 22.461ppd
Portanto cliente GPU3 está "atrapalhando" bastante o cliente SMP, uma alternativa para diminuir a perca é deixar 2 núcleos só para o cliente GPU, mas mesmo assim haverá diminuição considerável de rendimento do cliente SMP.
Ola pessoal.
Informação muito importante, obrigado por compartilhar :D, cara faz muito tempo que não uso GPU3, ele também consome 3% da CPU ou mais? O jeito é deixar as VGA's rodando numa máquina com processador fraco exclusivamente só pra rodar clientes GPU.
Bom ponto. Nao compensaria usar só o cliente GPU2? Um celeron 430 aguentaria duas vgas?
Pras GTX séria 4xx do Fernando somente o GPU3 que funciona, das GTX 2xx pra baixo funciona o GPU2, e acho que esse Celerom aguenta duas VGA's sim.
O Cristiano como você fez para colocar essa porrada de clientes Hfm? Aqui Eu uso um para cada micro.
Falou ae.PANAO.
Esses clientes são do Fernando, que bom se fossem meus, mas para adicionar mais de um cliente é só ir no menu Clients > Add Client, descrever as configurações e mandar carregar o log da pasta de onde ele está instalado. Acredito que para colocar mais de 1 cliente SMP o fernando compartilhou na rede as pastas do folding das máquinas e em uma das máquinas foi adicionando e carregando os logs pela rede.
Tendeu, com meu conhecimento de info é uma beleza a rede daqui so serva para conectar os 3 Pcs na net apenas nada de comunicação de um pro outro.
Falou ae.PANAO.
Panão, tenho 16 clientes no HFM, mas te digo, se a rede for entre XP e Seven é muito chato, mas Seven - Seven é moleza, só ir na pasta onde está o folding em cada PC e mandar compartilhar, vai pedir pra escolher um usuário pra compartilhar pode escolher "todos" ou "convidados" e pode ser somente "leitura", o local da pasta do folding também influencia na rede, se colocar na raiz do c: é mais fácil, se estiver em meus documentos ele compartilha tudo na pasta do usuário e se tiver na pasta arquivo de programas, as vezes não compartilha, bem entojadinho esse Seven, mas é bom.
Cristiano acho que os 3% já foi superado a algum tempo, a queda com dois clientes GPU3 foi enorme.
O GPU2 ainda não testei, mas me pareceu ser bem melhor nesse sentido, tanto que minha VGA preferida para F@H hoje é a GTX 295 :D
Eriberto como o Cristiano disse, não tem como usar GPU2 nas GTx 4xx e GTX 5XX.
Mas se for investir em VGA é melhor mesmo deixar um processador fraco com várias VGA'S.
Panao eu uso o compartilhamento da pasta no windows e adiciono mais um cliente no HFM, da forma como o pessoal já explicou.
Hoje de madrugada estava estudando os programas que vem pré-instalado no note e vi a porrada de programas inúteis que ficam gastando uma parte do potêncial do processador. Fui jogando um monte de coisa fora e a velocidade como todo do note melhorou bastante, tanto que teve um aumento no PPD.
Agora na 6701 TPF 21min e 3 segs PPD 2548, apesar que fazendo as contas com o log o tempo é ainda menor mas sei lá.
Falou ae.PANAO.
Essa 295 faz quantos pontos e bebe quanto? Acho que é um boa mesmo para o folding.
