Como resolver problema de "Reallocated Sector Count - failed"???
osiris2010
Estou com um problema com o meu HD, mas não sei se é grave.
Recentemente passei o HD TUNE para ver a performance e descobri algo a mais que não esperava encontrar. A mensagem de erro de Reallocated Sector Count conforme relatório abaixo:
O que significa Reallocated Sector Count? Pode comprometer o meu HD?
Obrigado.
Este foi o relatório do HD TUNE:
HD Tune: SAMSUNG HD160JJ Health
ID Current Worst Threshold Data Status
(01) Raw Read Error Rate 100 96 51 0 Ok
(03) Spin Up Time 253 253 25 5888 Ok
(04) Start/Stop Count 100 100 0 573 Ok
(05) Reallocated Sector Count 1 1 10 1017 Failed
(07) Seek Error Rate 253 253 51 0 Ok
(08) Seek Time Performance 253 253 15 0 Ok
(09) Power On Hours Count 100 100 0 1358 Ok
(0A) Spin Retry Count 253 253 51 0 Ok
(0B) Calibration Retry Count 253 253 0 0 Ok
(0C) Power Cycle Count 100 100 0 306 Ok
(BB) (unknown attribute) 98 98 0 131075 Ok
(BE) Airflow Temperature 136 94 0 34 Ok
(C2) Temperature 136 94 0 34 Ok
(C3) Hardware ECC Recovered 100 100 0 32624 Ok
(C4) Reallocated Event Count 1 1 0 1017 Ok
(C5) Current Pending Sector 253 253 0 0 Ok
(C6) Offline Uncorrectable 253 253 0 0 Ok
(C7) Ultra DMA CRC Error Count 200 200 0 0 Ok
(C8) Write Error Rate 100 98 0 0 Ok
(C9) TA Counter Detected 253 100 0 0 Ok
(CA) TA Counter Increased 253 253 0 0 Ok
Power On Time : 1358
Health Status : Failed
Alguém poderia me ajudar?
Desde já agradeço!
Encontrei esta página no site do HD Tune
1. How can I check if my hard disk is working well?
a) Check the Health screen
Here you will see S.M.A.R.T information which shows the condition of the hard disk.
The status of each parameter should be Ok.
If the parameter is highlited in yellow it means that the parameter almost reached a critical value. At this point it is highly recommended to check this parameter regulary to see if the value becomes worse.
If the parameter is highlited in red it means that the parameter has reached a critical value. In this case you should make a backup of your data and replace the hard disk.
B) Run the Error Scan
There shouldn't be any damaged (red) blocks. If there are you should backup your data and replace the hard disk.
c) Check the temperature
The temperature of the hard disk should not exceed 55°C/131°F. By default HD Tune warns you if the hard disk reaches this temperature.
In this case it's recommended to use a hard disk cooler to extend the life of the hard disk.
Acho que o HD está com a sua vida útil comprometida.
Se alguém tiver alguma opnião pode postar.
Obrigado
Esse atributo do SMART do teu HD já está com o valor além do limite considerado normal.
Você deve salvar tudo o que tem de importante em CD, DVD ou em outro HD com urgência antes que teu computador apresente problema.
Acho que esse teu HD não é mais confiável pois mesmo que venha a usar um programa para reparar os bad blocks estes podem voltar te causando problemas no sistema e novamente terá que usar o mesmo programa para reparos.
Como está o seu computador ?
Vem tendo problemas com o HD ou com o sistema ?
  • 5 meses depois...
putz to com o mesmo problema. mas eu tenho 3 hds conectados no pc e um outro novo pra instalar.. ainda bem que é o de 40gb.. mas ta durando apenas 2 anos o HD. da pra pssar um programa pra arrumar??
