Problemas com Asus Striker II Formula?
Ex_t1n7o
Bios Revision= 1202
PSU ( Power Supply Unit ) = Corsair HX 620W
CPU = Q9450 Core 2 Quad 2.66 Ghz
RAM = 2x 2 GB Kingston 800 Mhz
HDD ( the one where you have your windows installation on ) = Samsung 500 GB Sata II 16 MB
VGA1 = XFX Nvidia Geforce 9800 GX2 640M 1GB DDR3
VGA2 ( if you have ) =
VGA3 ( if you have ) =
SPU ( Sound Card ) = Supreme FX II
NorthBridge Cooling = 72
SouthBridge Cooling = 57
CPU Cooling = 38
RAM Cooling =
nFORCE Chipset Drivers Version =
ForceWare/GeForce Drivers Version = 174.40
BIOS Settings
Extreme Tweaker
CPU Level Up = Auto
Memory Level Up = Auto
AI Overclock Tuner = Manual
CPU Multiplier = 8.0
FSB - Memory Clock Mode = Auto
FSB - Memory Ratio = Auto
FSB (QDR) MHz = Auto (1333.3)
MEM (DDR) MHz = Auto (800)
LDT Frequency = 5x
PCIE Bus Slot 1 & 2 MHz = 100
PCIE Bus Slot 3 MHz = 100
SPP<->MCP Ref Clock, MHz = Auto
SLI-Ready Memory = Disabled
Memory Timing Setting
P1 = ? Isso nao tem no meu BIOS
P2 = ? Isso nao tem no meu BIOS
tCL ( CAS Latency ) = Auto
tRCD = Auto
tRP = Auto
tRAS = Auto
Command Per Clock (CMD) = Auto
tRRD = Auto
tRC = Auto
tWR = Auto
tWTR = Auto
tFAW = Auto
tRD = Auto
tRTP = Auto
tRFC = Auto
tREF = Auto
Over Voltage
CPU Voltage = Auto
Loadline Calibration = Enabled
CPU PLL Voltage = Auto
CPU VTT Voltage = Auto
Memory Voltage = Auto
NB Core Voltage = Auto
SB Core Voltage = Auto
CPU GTL REF0 Ratio = Auto
CPU GTL REF1 Ratio = Auto
CPU GTL REF2 Ratio = Auto
CPU GTL REF3 Ratio = Auto
NB GTL REF Ratio = Auto
DDR3 CHA1 Ref Volt = Auto
DDR3 CHB1 Ref Volt = Auto
DDR3 CHA2 Ref Volt = Auto
DDR3 CHB2 Ref Volt = Auto
CPU Configuration
CPU Internal Thermal Control = Disabled
Limit CPUID MaxVal = Disabled
Enhanced C1 (C1E) = Disabled
Execute Disable Bit = Disabled
Virtualization Technology = Disabled
Enhanced Intel SpeedStep Tech. = Disabled
CPU Core 2 = Enabled
CPU Core 3 ( Ignore this setting, unless you have a Quad-Core CPU ) = Enabled
CPU Core 4 ( Ignore this setting, unless you have a Quad-Core CPU ) = Enabled
Spread Spectrum Control
CPU Spread Spectrum = Disabled
PCIE Spread Spectrum = Disabled
MCP PCIE Spread Spectrum = Disabled
SATA Spread Spectrum = Disabled
LDT Spread Spectrum = Disabled
Problem Description
Quando estou jogando o computador congela/trava!
Ex_t1n7o e o seguinte.. da pra você ativar quantos núcleos voce quer que o processador trabalhe, ai eu coloquei só pra trabar com 2 núcleos e ele parou de travar e deu ate para colocar a outra memoria mas sempre o asus probe ii fica apitando tensão da memoria cpu.. e mais outras coisas.. enquanto estou jogando!!
ei eu obersevei com o everest que a tensão cai!!!!!
e nao estou entendendo porque mesmo assim continua e só quando eu ativo meu processador com seus 4 núcleos ele trava!!!!!
Ahh e o problema que eu tenho é o de congelamento que nem do edson q estava dando anteriormente.. se precisar das config do meu pc aqui vaiÇ
CPU Intel Core 2 Quad 2.66 Ghz Q9450
Nvidia GF 9800 GX2 1GB DDR3
2 Memorisa Kingston DDR2 2GB 800Mhz
Fonte Corsair 620W HX
placa-mãe Asus Striker II Formula
Hard Disk Samsung 500 GB SATA II
Ta certo eu tb estava tendo.. deixe assim e ve no qq dá
CPU Level Up = Disable (não está cinza?)
Memory Level Up = Disable (não está cinza?)
Over Voltage
CPU Voltage = 1.31
Memory Voltage = (cheque a voltagen de suas memos e sete elas)
não se preocupe com o asus probe ele é chato mesmo, considera umas voltagens altas mas quando na verdade são o padrão das memóriass.
quanto aos cores eu experimentei desabilitar também e continuei com o pc congelando.. ao invés de jogar para ver se o pc vai travar você pode usar o SuperPi que também faz o pc congelar
Temperatura do cpu? tem um bom cooler?
no everest ta falando 1.90 ta certo? e o meu processador é quad.. dai sera q 1.31 de tensão ta beleza mesmo?
aahh e onde baixa esse superPi?
valeu ae ex_t1nt7o pela ajuda =)
sim, tem o cooler que vem com o cpu temperatura do cpu ta beleza..
eu coloquei fiz o que você pediu no bios.. mas mesmo assim só roda com 2 núcleos.. quando libero os outros nem carrega o windows.. sera q pode ser problema no meu processador?
Eu tive problema de núcleos quando tentei um over maior 3ghz e não conseguia porque o processador tava quente o cooler tava na menor rotação, aí a placa mãe sozinha desligava os outros processadores..
o superPi pode ser baixado no www.superdownloads.com.br
se pode ser no processador claro q pode mas não sei acho que não..
qq ta falando no everest? 1.90 de q? agente coloca 1.31(como eu deixei aqui) pra ele ficar com 1.23 por aí.. seu pc veio montado? qual é temperatura q diz no processador?
denada!;)
nao.. me enganei 1.90 é do pc probe na memoria.. =)
eu mesmo montei ele.. a temperatura quando o pc esta a ha tempos ligados nao passa de 40 nao.. ta bem tranquilo a temperatura do processador..
atualizei o bios já.. continua travando quando ativo o terceiro e o quarto core... mas tirando isso o computador ta beleza...
o ruim é que paguei por um core 2 quad e so ta rodando como core 2 duo =/
quero ver como vou fazer pra ativar esses cores sem travar... o que você acha q pode ser?
Veja a temperatura de cada core separado, acho q 39 é bem quente com meu zalman aqui ele fica em 22 e os cores vão pra 74º :o
sugiro que você abra o gabinete e tente habilitar todos os cores..
Alias... A temperatura é 28.. só quando to jogando q ela sobre mais..
o pc esta aberto o tempo todo hehehe
vou tentar colocar na frente do ar condicionado e ativar os cores pra o que da..
achei o superpi no baixaki... vamos ver como funciona!
core#0 49º
core#1 48º
cpu 31º
agora ativei os ouros cores!! e deu certo irraaaa!!!!
quando executo o superpi a temperatura aumenta claro... ai vai (executando o superpi)
core#0 57 a 61 +-
core#1 52 a 54
core#2 52 a 54
core#3 57 a 58
cpu vai de 40 a 43 +-
quando o pc ta sem ser forcado como jogos ou o superpi... o cpu fica mais ou menos a 30...
sera q os travamentos eram de superaquecimento do processador?
aahhh o gabinete ta aberto claro.. e ta um pouco frio aqui também...
Q bom!
tomara q o problema não seja temperatura, porque aí você teria q comprar um cooler melhor e como você disse nem ta quente por aí.(se bem q 40..43 é até quente) o meu atinge 74º com o cpu em 22º
wuhuu! de novo q bom que conseguimos! denada
agora eu ainda to com problema com o meu, não consigo over nenhum porque trava(BlueScreen) jogando assassin's creed -_-.. mas pelo menos ta estável se alguém que estiver lendo o tópico souber algo que possa me ajudar tb seria bom.. ;)
Exausto de problemas e tentativas de correções, deixei tudo em auto e usei o "AI Overclock tunner" na bios mesmo, de pouco em pouco, primeiro 5% funcionou perfeitamente depois 10% também, e 15% também o que resulta num clock do processador de 2875 (stock 2500) depois 20% que leva o processador para 3000 e o pc chega a entrar no windows, porém não fica estável de jeito nenhum..
depois coloquei em manual e setei as memórias e sua respectiva tensão, por enquanto não travou nada e passou nos testes de estabilidade, a 2800 da pra obter uma melhora significativa no assassin's creed o que me deixa satisfeito até agora..
falaaa extinto..
como ficou seu pc ?
as memorias chegaram ?
Se precisar conectar no meu.. e ver alguma coisa.. da um toque..
Se for o caso posto fotos de como a bios está setada...
valeu brow
E Aewww galera!
Comprei minha Striker II Formula e fiquei com medo depois de ver este tópico heheh!!!
Porém, somente no mês que vem poderei fazer minha maquina funcionar, pois preciso comprar minha fonte e memória que meu amigo vai buscar em Portugal...
Aí tb vou ajudá-los com os testes!
Acho que seria muito bom se todos colocassem as configs que estão usando, desta forma as coisas ficariam um pouco mais esclarecidas.
Aqui vai um Overview que achei muito bom!
http://www.overclock3d.net/reviews.php?/cpu_mainboard/asus_striker_ii_formula_780i_socket_775_motherboard/11
Abraços!!!
Ex_t1n7o
Problemas de congelamento podem ser causados pela fonte, meu amigo tinha problemas de congelamento, testamos um monte de peça, e quando trocamos a fonte descobrimos...
Após fazer algumas pesquisas aqui percebi que sua fonte segundo o overview:
https://www.clubedohardware.com.br/printpage/1503
Possui linhas de 12v com apenas 22a
Agora analisando as especificações de sua placa de vídeo observe:
475W PCI Express®-compliant system power supply with a combined 12V current rating of 26A or more (Minimum system power requirement based on a PC configured with an Intel Core®2 Duo E4500 processor)
É necessário uma fonte com linhas de 26a
Meu amigo tinha uma Seventeam 750 reais e não acreditou tb, mas depois que pegamos uma Corsair 750... Batata... Nunca mais congelou!
Observe as especificações da Corsair:
+3,3v = 24A
+ 5v = 28A
+12v = 60A
-12V = 0,8A
+5Vsb = 3A
Seria muito bom se tivesse como você testar usando uma fonte com mais de 26a, talvez essa seja a solução!
Abraços!
2 a 0 que o problema é a fonte...
O Speedin tem uma Corsair 620w
http://www.e-coyote.com.br/produtos/detalhes/fonte-corsair-620w-hx-modular-series-atx-2-2-sli-
Vejam as especificações:
12V1: 18A
12V2: 18A
12V3: 18A
Tenho a GeForce 9800gx2 igual a do Speedin (Minimum recommended power supply with +12 Volt current rating of 28 Amp Amps.) e a testei com a fonte do meu primo Corsair 750w... Joguei por uma semana e nada de problemas
A config é
e8400
GeForce 9800gx2
Corsair 750w
2x2gb Corsair Dominator 1066
.wysiwyg { PADDING-RIGHT: 0px; PADDING-LEFT: 0px; BACKGROUND: #f5f5ff; PADDING-BOTTOM: 0px; MARGIN: 5px 10px 10px; FONT: 10pt verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif; COLOR: #000000; PADDING-TOP: 0px } .wysiwyg A:link { COLOR: #22229c } .wysiwyg_alink { COLOR: #22229c } .wysiwyg A:visited { COLOR: #22229c } .wysiwyg_avisited { COLOR: #22229c } .wysiwyg A:hover { COLOR: #ff4400 } .wysiwyg A:active { COLOR: #ff4400 } .wysiwyg_ahover { COLOR: #ff4400 } .wysiwyg { PADDING-RIGHT: 0px; PADDING-LEFT: 0px; BACKGROUND: #f5f5ff; PADDING-BOTTOM: 0px; MARGIN: 5px 10px 10px; FONT: 10pt verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif; COLOR: #000000; PADDING-TOP: 0px } .wysiwyg A:link { COLOR: #22229c } .wysiwyg_alink { COLOR: #22229c } .wysiwyg A:visited { COLOR: #22229c } .wysiwyg_avisited { COLOR: #22229c } .wysiwyg A:hover { COLOR: #ff4400 } .wysiwyg A:active { COLOR: #ff4400 } .wysiwyg_ahover { COLOR: #ff4400 } P { MARGIN: 0px } .inlineimg { VERTICAL-ALIGN: middle } Opa..
Legal Vampire ótimas observações,
porém o Edson tem a mesma fonte q eu e não tem mais problemas, e ele diz com as voltagens combinadas de no mínimo 26 as minhas combinadas dão 44, assim que tiver a oportunidade testo outra, mas acho q não acontecerá, porque sou o único "hardwaremaníaco" por aqui.
Abraço.
ps: você poderia ter falado em um post só né, acho q fica mais organizado o tópico,já que sabe editá-los tb, só uma sugestão ;)
Continuo achando q o problema de congelamento é da fonte...
o luiztamura tb tem uma fonte com menos Amperes do que o mínimo requisitado pelo site da placa de video.
O fato é que eu não tenho problemas de congelamento, e tenho a mesma placa mãe e memórias que vocês...
Já todos que usam fontes abaixo do recomendado pelo site da placa de video tem problemas ou já tiveram problemas com congelamento.
