Como escolher a melhor e mais indicada fonte para seu PC
faller
Galera,
Gostaria de algumas sugestões sobre um fonte com um bom custo/benefício q de conta com sobra para configuração abaixo:
MB Intel DP35DP
VGA HD 4870 512MB
HD SATA 500GB Barracuda 7200.11 SATA 3Gb/s (ST3500320AS)
DVD-RW
CPU C2D E7500 ou E8400 (Não deu diferença de consumo)
RAM 2x2GB 800Mhz (Escolhendo)
OBS.: Fiz um calculo no Power Supply Calculator e no consumo total deu: "Recommended Minimum PSU Wattage: * 379 w"
Abraços
Dei uma olhadas em algumas fontes:
OCZ 400W ModXStream Pro: R$ 265,
Technical
  • 400W Configuration
  • 150 x 160 x 86mm (W x L x H)
  • ATX12V v2.2 and EPS12V
  • up to 82% Efficiency
  • Overvoltage/OverPower/Short-Circuit protection
  • (.99)Active PFC
  • MTBF: 100,000 hours @ 25C
  • OCZ PowerWhisper Technology
  • Internal 140mm fan
  • 80+ Certified
  • 3 year warranty backed by OCZ's exclusive PowerSwap Warranty replacement program.
400W Connectors:
  • 1 x 20+4-pin ATX
  • 1 x 4-pin CPU
    Modular
  • 1 x 6-pin PCI-E
  • 6 x Peripheral
  • 2 x Floppy
  • 4 x SATA
OCZ 500W-700W ModXStream Pro: 500w a R$ 310, / 600w R$ 380,
Technical
  • 500W, 600W, 700W Configurations
  • Typical load 86% Efficiency
  • 80+ Certified
  • (.99)Active PFC
  • Internal 135mm fan (500W,600W,700W)
  • SLI™ Certified
500W - 700W Connectors:
  • 1 x 20/24-pin ATX
  • 1 x 8-pin CPU
  • 1x 4-pin CPU
    Modular
  • 1 x 6-pin PCI-E
  • 1 x 6+2-pin PCI-E
  • 4 x Peripheral
  • 2 x Floppy
  • 6 x SATA
OCZ 400W StealthXStream: R$ 200,
Technical
  • High efficiency:
    80% @ 115V (Typical load)
    83% @ 230V (Typical load)
  • Overvoltage/Overcurrent/Short-Circuit protection
  • Active PFC
  • MTBF:100,000 hours
  • 80+ Certified
Connectors
  • 1 x 20+4-pin ATX
  • 1 x 4-pin CPU
  • 1 x 6+2-pin PCI-E
  • 4 x SATA
  • 6 x Peripheral
  • 2 x Floppy
OCZ 500W StealthXStream: R$ 250,
Technical
  • 500W Configuration
  • 115V (Typical load)
  • Active PFC
  • Internal 120mm fan
Connectors
  • 1 x 20+4-pin ATX
  • 1 x 4-pin CPU
  • 1 x 6-pin PCI-E*
  • 3 x SATA
  • 4 x Peripheral
  • 1 x Floppy
Corsair CMPSU VX450W: R$ 285,
http://forum.clubedohardware.com.br/corsair-cmpsu-vx450w/570671
http://www.corsair.com/products/vx/default.aspx
Características principais visto o que faltou:
  • tensão de trabalho: 100V~240V
  • Certificação 80PLUS: Certificação Standard
  • eficiencia média medida pelo 80PLUS: 83.77%
Especificações principais feitas (Clube do Hardware):
  • ATX12V 2.2.
  • Potência nominal rotulada: 450 W.
  • Potência máxima medida: 571,9 W a 47,8°C.
  • Eficiência rotulada: entre 80% e 85%.
  • Eficiência medida: entre 84,3% e 88,1% em 115 V.
  • PFC ativo: Sim.
  • Conectores da placa-mãe: Um conector 20/24 pinos e um conector EPS12V que pode ser dividido em dois conectores ATX12V.
  • Conectores de alimentação da placa de vídeo: um conector de 6 pinos.
  • Conectores de alimentação para periféricos: seis, dois cabos com três conectores de alimentação para periféricos e um conector de alimentação para a unidade de disquete cada.
  • Conectores de alimentação SATA: seis, dois cabos com três conectores de alimentação SATA cada.
  • Proteções: sobretensão (OVP, não testada), subtensão (UVP, não testada), sobrecarga de corrente (OCP, testada e funcionando), sobrecarga de potência (OPP, testada e funcionando) e curto-circuito (SCP, testada e funcionando).
  • Garantia: Cinco anos nos EUA. No Brasil a garantia dependerá do distribuidor e/ou do lojista.
  • Verdadeiro fabricante: Seasonic.
Quanto a potência:
  • Potência combinada nos 12V ou potência nos 12V: 396W (33A)
  • Mínima potência combinada máxima nos 12V recomendada: 368W (30,6A)
  • Potência combinada nos 12V, 5V, 3.3V recomendada: 350W
  • Potência nominal combinada total: 450W
  • Quantidade de linhas 12V: 1 linha
OBS: Eu considerei uma carga nos 5V e 3.3V de 72W para elas juntas.
A carga das linhas auxiliares fazem 10W, o que faz 450W-10= 440W sobrando para as outras linhas que são 3.3V, 5V e 12V.
A potência combinada mínima é feita com 72W considerados como eu disse acima que faz 440W-72W = 368W (30,6A) nos 12V.
Despreza-se o fato da fonte fornecer potência a mais que a etiqueta.
Quanto aos conectores:
  • Número de conectores 4-pin (molex): 6x conectores e 2x floopy divididos em 2x chicotes
  • Número de conectores SATA: 6x conectores SATA divididos em 2x chicotes
  • Conector para processador: 4+4 pinos que podem servir de ATX12V(4 pinos) ou EPS12V(8 pinos)
  • Conector para placa-mãe: 20+4 pinos
  • Conectores para placa de vídeo PCI-Ex: 1x 6-pin PCI-Ex
OBS.: Os preços foram retirado do site BoaDica que reune preços de lojas aqui do RJ
Olá pessoal
estou querendo fazer umas melhorias no PC
e gostaria de saber qual fonte devo comprar
A configuração que pretendo é essa:
Processador: Core 2 Duo 3.0 Ghz
Memoria Ram :4 gb DDR2
Monitor 18.5 " samsung
HD SATA de 160 GB
Placa de Video Geforce 9800 1GB DDR3 256 bits
DVD RW
Leitor de Cartão
Olá pessoal
HD SATA de 160 GB
DVD RW
Leitor de Cartão
Uma Fonte Seventeam 450~600 watts REAIS é o que esta precisando.
Abaixo, citei 3 opções, que fica a sua escolha, sendo que qualquer uma rodaria sua máquina tranquilo e sem extresse.
- Fonte Seventeam 500W Real ST-500P-CG ATX 12V- V2.2 BLACK (AQUI)
- Fonte Seventeam St 500p-cg St 500watts Sli Nvidia Pci-e (AQUI)
- Fonte Atx 2.2 Seventeam St-450-pag 450w Reais Pci E (AQUI)
Esses links, só para tu ter uma noção visual do que estou falando!
BOA ESCOLHA!
Ola amigos do clube.
Ontem comprei um pc com as seguintes configurações:
Intel Core 2 Duo 7500
4 GB RAM
500 GB HD
DVD RW
Placa mãe GigaByte(não sei o modelo)
Placa de video GForce 8500 de 512mb
Placa PCTV da Multilazer.
E um cooler para refrigeração.
Minha duvida esta na fonte uns me disseram que deveria ser uma de fonte de 500 de potencia real. O gabinete vem com uma de 450. A vendedora durante a negociação, disse que a fonte de 500 para essa configuração não era nescessaria, e agora?
Eu pego a maquina amanha, o que os mais esperientes me diriam? Tudo bem do jeito que esta? Ou é bom trocar a fonte?
Muito obrigado.
4 GB RAM
500 GB HD
DVD RW
Muito obrigado.
qual é o modelo da fonte que vem?
4 GB RAM
500 GB HD
DVD RW
Muito obrigado.
Realmente esse PC não precisa de uma fonte de 500W. Mas existe uma diferença abismal entre uma fonte de qualidade de 500W e uma fonte genérica que diz fornecer 500W.
Você pode comprar uma boa fonte de 360W e já suporta muito bem ele.
Mas, repetindo a pergunta, qual o modelo da fonte que já vem nele?
Para a minha infelicidade, eu não sei o modelo, sei apenas que é a fonte que acompanha o gabinete, que é dos mais simples. Sei tambem que a potencia é de 450w.
Outra duvida, antes eu ligava meu monitor no proprio gabinete, monitor CRT, a vendedora disse que os novos gabinetes não tem a saida de energia para o monitor. Então existe um capo para que eu possa adaptar a entrada de energia do monitor a uma domada?
Obrigado, e desculpem não poder dar mais detalhes do modelo da fonte.
Para a minha infelicidade, eu não sei o modelo, sei apenas que é a fonte que acompanha o gabinete, que é dos mais simples. Sei também que a potencia é de 450w.
Se a fonte é das que já vem com o gabinete, então com certeza é uma fonte ruim. Recomendo trocá-la por uma das seguintes:
- OCZ400SXS;
- Corsair CX400;
- Zalman 360APS
- 3RSystem IceAge 450W;
- C3Tech DSA-5060 (apenas se realmente não puder pegar uma das anteriores)
Fique com a que ficar mais barata para o seu bolso.
No caso da tomada para o monitor, as fontes modernas já não tem mais essa saída de energia. Neste caso basta você ligar o monitor diretamente na tomada como qualquer outro aparelho, apenas atentando-se para a tensão ser compatível.
Abraço
- OCZ400SXS;
- Corsair CX400;
- Zalman 360APS
Abraço
Liguei para a vendedora e pedi para ela verificar o modelo da fonte.
Já na questão da tomada, o cabo do monitor é um cabo femea de 3 fendas retas. Então creio que vou precisar de um adaptador.
Obrigado mais uma vez.
Descobri, a fonte segundo a vendedora é uma Colermaster de 450w, foi o que ela me disse.
Obrigado.
Bom amigo minha configuração e a da assinatura pois minha HD 58xx queimo ai ja sabe ne, vou ter que usar outra placa pois to sem grana e so tenho essa pra comprar sera que minha fonte suporta essa quente pressão que e 3870x2?
Aguenta sim amigo, com uma boa tranquilidade até. Mas você sabe que essa fonte ão é das melhores né?
Olá, estou montando um pc com a seguinte configuração:
Mb: M4A785TD-V EVO
CPU: Phenom II X4 955
GPU: XFX HD 4870
RAM: 4GB DDR3 1333mhz OCZ GOLD ( 2x2 )
Gostaria de saber se essa fonte aguenta.
Fonte Thermaltake 550W Purepower 550W W0330RU - BOX
http://www.pichau.com.br/ecommerce_site/produto_12583_4109_Fonte-Thermaltake-550W-Purepower-550W-W0330RU-B0X
:D
Boa tarde pra todo mundo aqui. Primeiro quero dizer que até uns meses atrás eu não entendia praticamente nada de computador (não que entenda muito agora :D), então não quero ser julgado pelos erros que cometi no passado (especialmente depois que descobri que fiz muita m... besteira).
Meu computador, depois de anos de uso, parou de funcionar, tela preta total, creio que seja ou processador ou placa mãe, o resto já trocaram pra testar e nada de funcionar. Depois disso passei meses procurando uma boa configuração nova pra gastar um bom dinheiro agora e não mais tão cedo.
Fechei com: i5 750 ; Asus P7P55 Pro; Cooler Master Hyper 212 plus; 2x2GB DDR3 1600; Placa de Video Shaphire Vapor X HD5770;
Bom, havia trocado de fonte há pouco tempo atrás, cerca de um ano, na época em que não entendia nada do assunto. O técnico que trabalha pro meu pai me veio com essa aqui "Switching power supply PSN - 505S2" e disse que era muito boa, entenda que eu também tinha um Athlon XP 64 3.2 GHz com 2 Gb ddr400 e uma placa de video AGP até então.
Peguei uma configuração moderna, mas mais leve, achando que a fonte aguentaria e querendo dar uma economizada nos watts, essa VGA aí consome bem menos, mas nos testes de Power Supply minha configuração nova bate 300W sem over.
É "dito" que essa fonte teria 500w reais, mas depois de ler bastante aqui comecei a ficar preocupado, li vários posts do Faller, sobre estabilizadores (que usava até então), régua de proteção (ainda tenho que comprar, pois fazer uma, acho que não vai dar certo pra mim:p) e finalmente fontes. Descobri que não devia ter matado tantas aulas de eletricidade, se é que alguém ensina isso!
Vamos ao que interessa andei pesquisando sobre a fonte e descobri o seguinte:
Fonte de Energia CWT 500W Real Black PSN-505S2
FONTE ATX 500W PSN-505S2 20+4P C3T
Referência 405060003340
Fabricante CWT
Padrão ATX 24 pinos Pentium 4 /AMD
Potência real 500W
tensão 115~230v chaveado
Freqüência 60/50Hz
Controle temperatura Não
Ventiladores 1 120x120mm na parte inferior.
Conectores
4 Conectores ATA / IDE
1 Conectores de Floppy
1 Conector P4 (12V+12V)
1 Conector SATA
1 Conector ATX 20+4 pinos
Tensão de saída -5V Não possui
Alimentação para monitor Não
Botão Liga-Desliga Sim.
Cabo de força certificado Inmetro
Ela vem com esse "selo" na lateral http://img236.imageshack.us/i/dsc00078dn5.jpg/
Se não der pra ver, acho que o importante é isso:
12v1- 12A (14A peak) 12v2 - 15A (17A peak)
+3.3v- 18A (25A peak) +5V 28 A (25A peak)
Sobre o interior dela teve um colega num outro fórum que a abriu e escreveu isso:
Eu tenho uma destas, e já abri para fuçar.
O PCB dela é bem completo, possuindo lá todos os espaços para os componentes de filtragem, que
não estão lá! Tem lá local para 2 bobinas de ferrite, na minha opinião só peca nesse aspecto,
curiosamente o varistor vem de fábrica. O dobrador de tensão é formado por 2 grandes
capacitores de 680uF, as genéricas não costumam ultrapassar os 470uF. Utiliza um circuito
retificador, ao invés de uma ponte retificadora com diodos, que é o normal de fontes genéricas
(Goldship, por exemplo).
Vários reguladores da ST Micro, não verifiquei suas capacidades. Um grande transformador para a
linha de 12v, 2 pequenos, um que se destina aos 5v e 3,3v (creio eu) e outro do circuito de
regulagem. O transformador de 12v é bem grande, achei pequeno o para a linha de 5v, talvez
porque hoje a corrente solicitada nessa linha seja muito pequena, comparando-se com anos atras.
Nas saídas, a velha bobina de ferrite com todas as saídas enroladas. Depois dela, cada saída
possui sua própria bobina com núcleo de ferrite individual, todos os capacitores das saídas são
de 2200uF, é notável a falta de um capacitor e uma bobina que está no projeto marcado no PCB,
olhando com mais atenção nota-se que é da saída de -5v, que a maioria das fontes não oferece
mais, por falta de uso mesmo.
Eu uma rápida pesquisa na internet descobri que essa fonte é fabricada pela CWT.
Tirando a ausência do filtro, essa fonte é boa, muito melhor que qualquer fonte genérica que se
encontra por aí. "
Confesso que não entendi muita coisa, mas fiquei feliz pelo tal "varistor" e por descobrir que foi feita por uma boa fábrica. Mas juntando meu parco conhecimento de eletricidade e matematica, fiquei preocupado com algo:
É dito que atualmente o que importa são os 12v certo, então fiz
P= V x A para aqueles dados, 12v1- 12A (14A peak) 12v2 - 15A (17A peak)
12 x 12 = 144, 12 x 15 = 180 Pt= 324W
Essa fonte teria então a potência total de 324W, não sendo portanto indicada pra minha configuração moderna que bate 300W, e outra coisa, essas 2 saídas de 12V a V1 e V2 são igualmente usadas, ou será que uma delas é "sobrecarregada"?
Moral da história, será que realmente preciso de uma fonte nova, ou uma boa régua dá conta do recado. Já gastei muito dinheiro, mas também não sou ****** de atirá-lo pela janela ao usar uma fonte que não presta para meu alvo, mas como tem muita gente que diz que essa fonte é até bem razoável, queria saber a opinião do Faller, que pelo que pude constatar entende do assunto, ou de alguém que também se julgue qualificado a opinar. Se tiver que trocar de fonte pretendo por logo uma de 750W, mesmo sabendo que vou prejudicar sua eficiencia, mas não quererei trocá-la por anos a fio. Pensei na "C3 Tech" 750 Watts PSH-750V, que teve bons reviews, seria igual a Corsair THX 750W, meu alvo original, mas mais barata.
Muito obrigado pra quem teve saco de ler até aqui, conto com a ajuda de vocês! (acho que de tanto que li aqui me empolguei!)
Abraços!
Tirando a ausência do filtro, essa fonte é boa, muito melhor que qualquer fonte genérica que se encontra por aí. "
Como dizia o meu amigo.. tirando todos os defeitos, o que sobra é bom...
Ela em sua etiqueta que jamais seria editada pela CWT (olha ai a qualidade das fontes CWT: http://www.cwt.com.tw/english/2_product/01_list2.php?MainID=1 ) mas sim pode ser derivada de um esquemático da CWT...
Ela apesar de não declarar a potência de modo combinado em 12 Volts, poderia ter no máximo dos máximos a chance de entregar 12 A + 15 A = 17 A
Isso faz dela uma fonte que se comparada com fontes modernas com potência alocada nas tensões corretas daria uma potência útil total de (27A x 12 V ) + 60 Watts = 384 Watts
Com essa potência dai eu diria possível tocar sem preocupação uma config que drenasse até 300 Watts.. No limite de segurança...
Na dúvida leia: Como saber a Máxima Potência Útil de uma fonte??
Abraço...
Muito obrigado mesmo Faller, li o outro tópico, mas agora estou com uma bela preocupação na cabeça, realmente acho muito difícil eu bater esses 300w de pico, nem costumo jogar no PC, mas, depois de ler as limitações de carga total e de 12V das etiquetas das fontes que você me passou, fico pensando se o fabricante não "esqueceu" de escrever ali : Limite de xx amperes nas linhas de 12v!
Será isso comum? Ou, geralmente, se já expuseram todos aqueles dados, não omitiriam tal limitação. Sei que é praticamente impossível responder isso, mas por experiência, se tem etiqueta com dados, eles devem ser "completos" né?
Abraço.
Belo tópico ... Olá, minha gente está é primeira vez que participo do Forum ... Por favor estou em dúvida ... Alguém conhece a Fonte >> WiseCase 500W real WSCW-500 20/24 1 sata c/cabo 1*8 - Fnmt0003 << Não encontrei em teste e nem em qualquer resultado, estou para comprar ... Obrigado !!! :confused:
Eu evitaria essa fonte, não a conheço bem, mas se não me engano ela não é boa não.
http://www.cyberhardware.com.br/produto/Corsair-750W-TX-Series.html
ou essa seria melhor?
http://www.cyberhardware.com.br/produto/Satellite-1000W-SL-X1000.html
essas fonte aguentaria uma hd5970 com q9550 + a minha config a baixo né?
meu pc: placa-mãe GA-P35-DS3 , Intel C2D e6550 a 3.01ghz (cooler IceAge 120 Plus ), 2x2gb ddr2 800mhz Corsair XMS2 PC6400, fonte huntkey 450w, hd ide samsung 160 gigas cache de 8 megas, placa de video ATI RADEON HD4850 Sapphire,e Gabinete Sunbeam Acrylic Case III
Essa sua config, mesmo com Q9550 + HD5970 não chegará a demandar 340 Watts isso no pico do pico de sua exigência.. Para que sua nova fonte opere numa região segura, confortável e com muita sobra de potência, a adoção de uma fonte de 340/0,70 = 486 Watts
Diria, uma fonte de 500 ou 550 Watts sobraria ai... Recomendo uma Corsair VX550 ou HX520 se desejares uma fonte modular..
Veja ai para acreditar: http://www.extreme.outervision.com/PSUEngine
Abraço...
olá.. gostaria de saber qual fonte comprar para essa configuração:
processador Core i5-750
placa mãe LGA1156
placa de vídeo nvidia geforce 6800 xt
2x memória ddr 3 - 1333
4 hds + 1 drive de cd
trabalhando com vídeo e edição de imagem..
não estou disposto a pagar muito pela fonte..
obrigado !
Abraço...
que outra fonte nessa faixa de preço nesse site do cyberhardware você recomendaria? (claro uma que sirva a hd5970)
Essa, como já sugeri: http://www.cyberhardware.com.br/produto/Corsair-550W-VX-Series.html
Ou essa daqui, já com extrema folga para uma config que demandará menos de 340 Watts: http://www.cyberhardware.com.br/produto/Corsair-650W-TX-Series.html
Mais potência que isso já é jogar dinheiro no lixo, sem nenhum benefício, pois não vai fazer sua config render mais nem tampouco será garantia de maior longevidade da fonte...
Abraço...
